    MMM-MotionEye - surveillance video stream on your mirror!
    70 Posts 15 Posters 99.3k Views 15 Watching
    • SnilleS Offline
      Snille Module Developer
      Hi @emos I’m also using different cameras from the same MotionEye install.
      I have my cameras set on different ports like this.
      http://MotionEyeOS:8081
      http://MotionEyeOS:8082
      http://MotionEyeOS:8083
      I think that the default way…
      Then you have the motiontrigger url like this in MotionEyeOS/Camera (for example):
      http://MagicMirror:8080/motioneye/1
      http://MagicMirror:8080/motioneye/2
      http://MagicMirror:8080/motioneye/3
      That’s it. :)
      E 1 Reply Last reply Reply Quote -1
      • E Offline
        emos @Snille
        @Snille
        My second camera is a remote camera, not a local one on my LAN.
        Also http://MagicMirror:8080/motioneye/1 and http://MagicMirror:8080/motioneye/2 is the same livestream. changing from motioneye/1 to motioneye/2 does nothing.
        SnilleS 1 Reply Last reply Reply Quote 0
        • SnilleS Offline
          Snille Module Developer @emos
          @emos you need to add it in to MotionEyeOS. So it knows about it. I have 3 cameras in the same way. You can add any “network-camera”.
          rtsp://yourcam:port/whatever-format in the “add” dialog in MotionEyeOS. :)
          • E Offline
            emos @Snille
            @Snille
            Camera is added to MotionEye
            Under MotionEyeOS Settings>Video Device>Camera ID the ID is 1 and 2 :/
            • SnilleS Offline
              @emos Here is one of mine: 0_1486731274088_Cam01.png
              • E Offline
                emos @Snille
                Only thing thats not identical is under video streaming > Useful URLs.
                As you can see that under cam ID 2 (left one) is that streaming URL are missing… don’t know if this is a deal breaker or how to change it… :/
                • SnilleS Offline
                  @emos Hmm… I wounder if it is because you use an http link? Can you try to change it to an rtsp link?
                  • E Offline
                    emos
                    can i use rtsp for another MotionEye cam? Does it even have rtsp? :o
                    • SnilleS Offline
                      @emos Nah, you only need to use rtsp for the “network” cameras. The right one you have looks like a “locally” connected camera?
                      • E Offline
                        emos
                        the right one is local, correct
                        • W Offline
                          Woody
                          Hi Cato, thanks for this Module, I installed it and it works like a charm. One thing I like to ask you is the positioning of the module. I tried to arrange the module appearence pixel-precise with the help of the custom.ccs but was not successful. I added this to the custom.css and deleted the position definition in the config.js. Any idea what went wrong here :question: :question: :question:
                          .MMM-MotionEye {
                           left : 700px;
                           top: 1500px;
                            Cato Module Developer
                            I’m really not sure since I’m not very deep into CSS. I would have to test it this weekend. By schedule is pretty tight…
                            I assume you have a very large screen since you’re putting Motion-Eye 1500 pixels down on it?!? :smiley:
                            • W Offline
                              Woody
                              Of cause, I’ve a more or less large screen but this is only one of some other positions I tried without success to prevent overlapping with other modules.
                              Would be great if you could help with this of cause spezific problem.
                              Thx in advance…
                                Binog
                                Hey there. My problem is, that I do not get an image one the screen, when using autohide.
                                It works without using autohide.
                                Is it true, that it appears - using autohide - if a motion is recognized?
                                So motioneye is recognizing correctly, but obviously it does not parse the info to the module.
                                this is my config:
                                	   module: 'MMM-MotionEye',
                                	   position: 'middle_center',
                                	        url: "http://motioneye:8081",
                                	        autoHide: true,
                                	        autoHideDelay:"10000",
                                	        debug: true,
                                	        animationSpeed: "2000",
                                	        width: "300",
                                Can someone please post a screenshot of the motioneye-config (as seen above) how the settings should be set?
                                Thank You very much !!
                                  A Former User
                                  Hi all,
                                  Just started my adventure with the MagicMirror, running into some problems with streaming 2 ipcams into MM.
                                  I installed Motioneye in the Rpi and also in the MM module.
                                  Both ipcams are visable when i log into Motioneye (in my case: 192.168.1.105:8765) but only a small icon appears in the MagicMirror.
                                  My config is:
                                  {                       module: 'MMM-MotionEye',
                                  			position: 'bottom_right',
                                  			url: "http://192.168.1.105:8765/motioneye/1",
                                  			debug: true,
                                  I have tried all above mentioned ideas but to no succes.
                                  The cams are installed in Motioneye with:
                                  http://192.168.1.102:88/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=XXX&pwd=XXX
                                  RTSP give me an error.
                                  Hope someone can help me out…
                                    Binog
                                    I have that more often than I can believe. That normally means motioneye crashed,. or something. there is no connection between MM and Motioneye.
                                    I do the login ins my http://IP:8081 an see if it is running,. normally then MM reloads the full image.
                                    Give it a try!
                                    BTW is there a way to let motioneye run through pm2 ?
                                      Binog
                                      Change Your port in the config.js from 8765 to 8081
                                        A Former User @Binog
                                        @Binog
                                        Thanks, but still no succes, and would not know why it would work because i have nothing running on 8081?
                                        MM runs on 8080 and Motioneye runs on 8765
                                          Binog
                                          Have a look in motioneye under Videostreaming -> Streaming Port. Use that one,. with me it is 8081. and the snapshot port is 8765.
                                          Hopefully that helps.
                                            Seems many missunderstand the URL-parameter. This is the Streaming URL you have to find in MotionEye. It is not the URL of MagicMirror or the motion detection url you configure in MotionEye.
                                            As described in the README.md:
                                            url
                                            Video Streaming URL. You find it in Motion Eye in the Video Streaming Section under Usefull URLs by by clicking the Streaming URL link. It should look something like this: http://motioneye:8081 (probably an IP instead of hostname).
                                            Open that URL in a browser and you should get a single animated JPEG. If not, then you have found the wrong URL!
                                            The URL that looks like this: http://magicmirror:8080/motioneye/1 has nothing to do with what image is visible in the module. This is an triggering URL for showing the image if it’s hidden and a motion that MotionEye detects. It should be configured in MotionEye and not this module. Skip this step unless you know what you are doing…
                                            • 2 / 4
