    MMM-MotionEye - surveillance video stream on your mirror!
    70 Posts 15 Posters 102.5k Views 15 Watching
    • SnilleS
      Snille Module Developer
      Hi again, It would be cool to be able to hide the camera manually… For example visit another link… Say http://MagicMirror:8080/motioneye/1/hide
      Right? :)
      • SnilleS
        Fixed. Just sent you a PR. :)
        Check it, I’m fairly new to Node.js so it may not be the best solution. :)
        • L
          lolobyte
          Hi @Snille
          before i made a MM2, i started with a motion cam. It’s running now roundabout a half year outside from 30 ° to -20 ° C.
          I tried to insert my IP and port, but it don’t’ run.
          Any proposal to try a forensic research where to find the shitty error?
            Cato Module Developer @Snille
            @Snille Had some comments. Fix those and I’ll merge it :)
            SnilleS 1 Reply Last reply Reply Quote 0
              Cato Module Developer @lolobyte
              @lolobyte First question: What motion software do you use?
              • SnilleS
                Snille Module Developer @Cato
                @Cato Great! Thanks for fixing my mistakes. :)
                • L
                  lolobyte @Cato
                  @Cato
                  Hi, that’s the info of help.
                  Downloaded from
                  https://www.dropbox.com/s/xdfcxm5hu71s97d/motion-mmal.tar.gz
                  pi@raspi3-MM2:~ $ motion -h
                  motion Version mmaltest, Copyright 2000-2005 Jeroen Vreeken/Folkert van Heusden/Kenneth Lavrsen
                  usage: motion [options]
                  Possible options:
                  -n Run in non-daemon mode.
                  -s Run in setup mode.
                  -c config Full path and filename of config file.
                  -d level Log level (1-9) (EMR, ALR, CRT, ERR, WRN, NTC, ERR, DBG, ALL). default: 6 / NTC.
                  -k type Type of log (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). default: ALL.
                  -p process_id_file Full path and filename of process id file (pid file).
                  -l log file Full path and filename of log file.
                  -m Disable motion detection at startup.
                  -h Show this screen.
                  Motion is configured using a config file only. If none is supplied,
                  it will read motion.conf from current directory, ~/.motion or /etc.
                    @lolobyte You will have to install motionEyeOS or motionEye to use this module. Please read pre-requisites.
                    • L
                      lolobyte @Cato
                      @Cato
                      Thank you for your answer.
                      I just tried MotionEyeOS before i went to Motion.
                      In my eyes it wasn’t configurable with my desired functionality.
                      I just hoped there is a possibility to implement foreign streams.
                        @lolobyte As long as the software can provide a “motion jpeg”-stream, it can be supported.
                        Basically, you can test it your selv by making a local .html-file with <img src="xxxxx" />
                        • E
                          emos
                          For some reason i just get a “broken” picture icon, and if i try to open http://MotionEyeIP/motioneye/1 the site just says:
                          {"error": "not found"}
                          I have disable the password for the ‘Surveillance Username’ so no login is required.
                          I know the cam is available and motioneyos is working as normal. If i open http://192.168.1.200:8080/picture/1/current/ in my browser i can see the last snapshot, but not doing me any good…
                          Any suggestion?
                          	module: 'MMM-MotionEye',
                          	position: 'bottom_right',
                          		url: "http://192.168.1.200:8080/motioneye/1",
                          		debug: false
                          S C 2 Replies Last reply Reply Quote 0
                            shashank @emos
                            @emos hi, try changing the port (8080) in MM or camera , both MM and camera with 8080 will not work
                              Cato Module Developer @emos
                              @emos The URL you are using in your config seems to be the “web hook”-URL that you have to configure inside MotionEye if you want to automatically show video stream when motion is detected.
                              The URL should be configured like this (from documentation): Video Streaming URL. You find it in Motion Eye in the Video Streaming Section under Usefull URLs by by clicking the Streaming URL link. It should look something like this: http://motioneye:8081 (probably an IP instead of hostname).
                              • E
                                emos
                                reinstalled motioneye on my other r.pi and now im able to view a stream from http://MotionEyeOS:8081, but only from cam 1.
                                With http://MotionEyeOS:8081/motioneye/2 i still just get cam 1. Get the feeling im not understanding something.
                                			position: 'lower_third',
                                				url: "http://192.168.1.200:8081/motioneye/2",
                                				autoHide: false,
                                				debug: false
                                • SnilleS
                                  Hi @emos I’m also using different cameras from the same MotionEye install.
                                  I have my cameras set on different ports like this.
                                  http://MotionEyeOS:8082
                                  http://MotionEyeOS:8083
                                  I think that the default way…
                                  Then you have the motiontrigger url like this in MotionEyeOS/Camera (for example):
                                  http://MagicMirror:8080/motioneye/2
                                  http://MagicMirror:8080/motioneye/3
                                  That’s it. :)
                                  E 1 Reply Last reply Reply Quote -1
                                  • E
                                    emos @Snille
                                    @Snille
                                    My second camera is a remote camera, not a local one on my LAN.
                                    Also http://MagicMirror:8080/motioneye/1 and http://MagicMirror:8080/motioneye/2 is the same livestream. changing from motioneye/1 to motioneye/2 does nothing.
                                    • SnilleS
                                      Snille Module Developer @emos
                                      @emos you need to add it in to MotionEyeOS. So it knows about it. I have 3 cameras in the same way. You can add any “network-camera”.
                                      rtsp://yourcam:port/whatever-format in the “add” dialog in MotionEyeOS. :)
                                      • E
                                        emos @Snille
                                        @Snille
                                        Camera is added to MotionEye
                                        Under MotionEyeOS Settings>Video Device>Camera ID the ID is 1 and 2 :/
                                        • SnilleS
                                          @emos Here is one of mine: 0_1486731274088_Cam01.png
                                          • E
                                            emos @Snille
                                            Only thing thats not identical is under video streaming > Useful URLs.
                                            As you can see that under cam ID 2 (left one) is that streaming URL are missing… don’t know if this is a deal breaker or how to change it… :/
                                            • 2 / 4
