    MMM-MotionEye - surveillance video stream on your mirror!
    70 Posts 15 Posters 103.2k Views 15 Watching
    • CatoC
      Cato Module Developer @Snille
      @Snille Ok found the bug - update to 1.1.0 as instructed in README.md in GitHub.
      Reply Quote 3
      • SnilleS
        Snille Module Developer
        Hi again, It would be cool to be able to hide the camera manually… For example visit another link… Say http://MagicMirror:8080/motioneye/1/hide
        Right? :)
        • SnilleS
          Fixed. Just sent you a PR. :)
          Check it, I’m fairly new to Node.js so it may not be the best solution. :)
          CatoC 1 Reply Last reply
          • lolobyteL
            lolobyte
            Hi @Snille
            before i made a MM2, i started with a motion cam. It’s running now roundabout a half year outside from 30 ° to -20 ° C.
            I tried to insert my IP and port, but it don’t’ run.
            Any proposal to try a forensic research where to find the shitty error?
            • CatoC
              @Snille Had some comments. Fix those and I’ll merge it :)
              SnilleS 1 Reply Last reply
              • CatoC
                Cato Module Developer @lolobyte
                @lolobyte First question: What motion software do you use?
                lolobyteL 1 Reply Last reply
                • SnilleS
                  Snille Module Developer @Cato
                  @Cato Great! Thanks for fixing my mistakes. :)
                  • lolobyteL
                    lolobyte @Cato
                    @Cato
                    Hi, that’s the info of help.
                    Downloaded from
                    https://www.dropbox.com/s/xdfcxm5hu71s97d/motion-mmal.tar.gz
                    pi@raspi3-MM2:~ $ motion -h
                    motion Version mmaltest, Copyright 2000-2005 Jeroen Vreeken/Folkert van Heusden/Kenneth Lavrsen
                    usage: motion [options]
                    Possible options:
                    -n Run in non-daemon mode.
                    -s Run in setup mode.
                    -c config Full path and filename of config file.
                    -d level Log level (1-9) (EMR, ALR, CRT, ERR, WRN, NTC, ERR, DBG, ALL). default: 6 / NTC.
                    -k type Type of log (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). default: ALL.
                    -p process_id_file Full path and filename of process id file (pid file).
                    -l log file Full path and filename of log file.
                    -m Disable motion detection at startup.
                    -h Show this screen.
                    Motion is configured using a config file only. If none is supplied,
                    it will read motion.conf from current directory, ~/.motion or /etc.
                    • CatoC
                      @lolobyte You will have to install motionEyeOS or motionEye to use this module. Please read pre-requisites.
                      • lolobyteL
                        lolobyte @Cato
                        @Cato
                        Thank you for your answer.
                        I just tried MotionEyeOS before i went to Motion.
                        In my eyes it wasn’t configurable with my desired functionality.
                        I just hoped there is a possibility to implement foreign streams.
                        • CatoC
                          @lolobyte As long as the software can provide a “motion jpeg”-stream, it can be supported.
                          Basically, you can test it your selv by making a local .html-file with <img src="xxxxx" />
                          • E
                            emos
                            For some reason i just get a “broken” picture icon, and if i try to open http://MotionEyeIP/motioneye/1 the site just says:
                            {"error": "not found"}
                            I have disable the password for the ‘Surveillance Username’ so no login is required.
                            I know the cam is available and motioneyos is working as normal. If i open http://192.168.1.200:8080/picture/1/current/ in my browser i can see the last snapshot, but not doing me any good…
                            Any suggestion?
                            	module: 'MMM-MotionEye',
                            	position: 'bottom_right',
                            		url: "http://192.168.1.200:8080/motioneye/1",
                            		debug: false
                            S CatoC 2 Replies Last reply
                              shashank @emos
                              @emos hi, try changing the port (8080) in MM or camera , both MM and camera with 8080 will not work
                              • CatoC
                                Cato Module Developer @emos
                                @emos The URL you are using in your config seems to be the “web hook”-URL that you have to configure inside MotionEye if you want to automatically show video stream when motion is detected.
                                The URL should be configured like this (from documentation): Video Streaming URL. You find it in Motion Eye in the Video Streaming Section under Usefull URLs by by clicking the Streaming URL link. It should look something like this: http://motioneye:8081 (probably an IP instead of hostname).
                                • E
                                  emos
                                  reinstalled motioneye on my other r.pi and now im able to view a stream from http://MotionEyeOS:8081, but only from cam 1.
                                  With http://MotionEyeOS:8081/motioneye/2 i still just get cam 1. Get the feeling im not understanding something.
                                  			position: 'lower_third',
                                  				url: "http://192.168.1.200:8081/motioneye/2",
                                  				autoHide: false,
                                  				debug: false
                                  D 1 Reply Last reply
                                  • SnilleS
                                    Hi @emos I’m also using different cameras from the same MotionEye install.
                                    I have my cameras set on different ports like this.
                                    http://MotionEyeOS:8082
                                    http://MotionEyeOS:8083
                                    I think that the default way…
                                    Then you have the motiontrigger url like this in MotionEyeOS/Camera (for example):
                                    http://MagicMirror:8080/motioneye/2
                                    http://MagicMirror:8080/motioneye/3
                                    That’s it. :)
                                    E 1 Reply Last reply
                                    Reply Quote -1
                                    • E
                                      emos @Snille
                                      @Snille
                                      My second camera is a remote camera, not a local one on my LAN.
                                      Also http://MagicMirror:8080/motioneye/1 and http://MagicMirror:8080/motioneye/2 is the same livestream. changing from motioneye/1 to motioneye/2 does nothing.
                                      • SnilleS
                                        Snille Module Developer @emos
                                        @emos you need to add it in to MotionEyeOS. So it knows about it. I have 3 cameras in the same way. You can add any “network-camera”.
                                        rtsp://yourcam:port/whatever-format in the “add” dialog in MotionEyeOS. :)
                                        • E
                                          emos @Snille
                                          @Snille
                                          Camera is added to MotionEye
                                          Under MotionEyeOS Settings>Video Device>Camera ID the ID is 1 and 2 :/
                                          • SnilleS
                                            @emos Here is one of mine: 0_1486731274088_Cam01.png
                                            • 2 / 4
