    MMM-MotionEye - surveillance video stream on your mirror!
    70 Posts 15 Posters 103.2k Views 15 Watching
    • CatoC
      Cato Module Developer @Snille
      @Snille I don’t remember if “motion jpeg” is enabled by default in Motion Eye. Can you check your settings in Motion Eye? I’m at work now and have no change to check myself…
      (Maybe it has another name)
      • SnilleS
        Snille Module Developer
        @Cato There is not a specific “mjpeg” option as I can find. However on the “?” on the “Streaming URL” it says: “A URL that provides MJPEG stream of the camera” and that’s the URL I used…
        CatoC 1 Reply Last reply
        • CatoC
          @Snille Ok found the bug - update to 1.1.0 as instructed in README.md in GitHub.
          Reply Quote 3
          • SnilleS
            Hi again, It would be cool to be able to hide the camera manually… For example visit another link… Say http://MagicMirror:8080/motioneye/1/hide
            Right? :)
            • SnilleS
              Fixed. Just sent you a PR. :)
              Check it, I’m fairly new to Node.js so it may not be the best solution. :)
              • lolobyteL
                lolobyte
                Hi @Snille
                before i made a MM2, i started with a motion cam. It’s running now roundabout a half year outside from 30 ° to -20 ° C.
                I tried to insert my IP and port, but it don’t’ run.
                Any proposal to try a forensic research where to find the shitty error?
                • CatoC
                  @Snille Had some comments. Fix those and I’ll merge it :)
                  SnilleS 1 Reply Last reply
                  • CatoC
                    Cato Module Developer @lolobyte
                    @lolobyte First question: What motion software do you use?
                    lolobyteL 1 Reply Last reply
                    • SnilleS
                      Snille Module Developer @Cato
                      @Cato Great! Thanks for fixing my mistakes. :)
                      • lolobyteL
                        lolobyte @Cato
                        @Cato
                        Hi, that’s the info of help.
                        Downloaded from
                        https://www.dropbox.com/s/xdfcxm5hu71s97d/motion-mmal.tar.gz
                        pi@raspi3-MM2:~ $ motion -h
                        motion Version mmaltest, Copyright 2000-2005 Jeroen Vreeken/Folkert van Heusden/Kenneth Lavrsen
                        usage: motion [options]
                        Possible options:
                        -n Run in non-daemon mode.
                        -s Run in setup mode.
                        -c config Full path and filename of config file.
                        -d level Log level (1-9) (EMR, ALR, CRT, ERR, WRN, NTC, ERR, DBG, ALL). default: 6 / NTC.
                        -k type Type of log (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). default: ALL.
                        -p process_id_file Full path and filename of process id file (pid file).
                        -l log file Full path and filename of log file.
                        -m Disable motion detection at startup.
                        -h Show this screen.
                        Motion is configured using a config file only. If none is supplied,
                        it will read motion.conf from current directory, ~/.motion or /etc.
                        • CatoC
                          @lolobyte You will have to install motionEyeOS or motionEye to use this module. Please read pre-requisites.
                          • lolobyteL
                            lolobyte @Cato
                            @Cato
                            Thank you for your answer.
                            I just tried MotionEyeOS before i went to Motion.
                            In my eyes it wasn’t configurable with my desired functionality.
                            I just hoped there is a possibility to implement foreign streams.
                            • CatoC
                              @lolobyte As long as the software can provide a “motion jpeg”-stream, it can be supported.
                              Basically, you can test it your selv by making a local .html-file with <img src="xxxxx" />
                              • E
                                emos
                                For some reason i just get a “broken” picture icon, and if i try to open http://MotionEyeIP/motioneye/1 the site just says:
                                {"error": "not found"}
                                I have disable the password for the ‘Surveillance Username’ so no login is required.
                                I know the cam is available and motioneyos is working as normal. If i open http://192.168.1.200:8080/picture/1/current/ in my browser i can see the last snapshot, but not doing me any good…
                                Any suggestion?
                                	module: 'MMM-MotionEye',
                                	position: 'bottom_right',
                                		url: "http://192.168.1.200:8080/motioneye/1",
                                		debug: false
                                S CatoC 2 Replies Last reply
                                  shashank @emos
                                  @emos hi, try changing the port (8080) in MM or camera , both MM and camera with 8080 will not work
                                  • CatoC
                                    Cato Module Developer @emos
                                    @emos The URL you are using in your config seems to be the “web hook”-URL that you have to configure inside MotionEye if you want to automatically show video stream when motion is detected.
                                    The URL should be configured like this (from documentation): Video Streaming URL. You find it in Motion Eye in the Video Streaming Section under Usefull URLs by by clicking the Streaming URL link. It should look something like this: http://motioneye:8081 (probably an IP instead of hostname).
                                    • E
                                      emos
                                      reinstalled motioneye on my other r.pi and now im able to view a stream from http://MotionEyeOS:8081, but only from cam 1.
                                      With http://MotionEyeOS:8081/motioneye/2 i still just get cam 1. Get the feeling im not understanding something.
                                      			position: 'lower_third',
                                      				url: "http://192.168.1.200:8081/motioneye/2",
                                      				autoHide: false,
                                      				debug: false
                                      D 1 Reply Last reply
                                      • SnilleS
                                        Hi @emos I’m also using different cameras from the same MotionEye install.
                                        I have my cameras set on different ports like this.
                                        http://MotionEyeOS:8082
                                        http://MotionEyeOS:8083
                                        I think that the default way…
                                        Then you have the motiontrigger url like this in MotionEyeOS/Camera (for example):
                                        http://MagicMirror:8080/motioneye/2
                                        http://MagicMirror:8080/motioneye/3
                                        That’s it. :)
                                        E 1 Reply Last reply
                                        Reply Quote -1
                                        • E
                                          emos @Snille
                                          @Snille
                                          My second camera is a remote camera, not a local one on my LAN.
                                          Also http://MagicMirror:8080/motioneye/1 and http://MagicMirror:8080/motioneye/2 is the same livestream. changing from motioneye/1 to motioneye/2 does nothing.
                                          • SnilleS
                                            Snille Module Developer @emos
                                            @emos you need to add it in to MotionEyeOS. So it knows about it. I have 3 cameras in the same way. You can add any “network-camera”.
                                            rtsp://yourcam:port/whatever-format in the “add” dialog in MotionEyeOS. :)
                                            • 2 / 4
