    MMM-MotionEye - surveillance video stream on your mirror!
    70 Posts 15 Posters 101.6k Views 15 Watching
      shashank @Cato
      @Cato Hi, i could not able to find the instructions to install MotionEye on raspberry Pi 3 jessie/pixel , could you please help me with instruction guide or any url reference which worked for you.
      Shashank
        chrisfoerg
        https://github.com/ccrisan/motioneye
          shashank @chrisfoerg
          @chrisfoerg hi i tried installing successfully using below wiki url, i am able to view camera on motioneye software, on Magic Mirror camera is blank, i tried with both url and web hock
          https://github.com/ccrisan/motioneye/wiki/Install-On-Raspbian
          module: ‘MMM-MotionEye’,
          position: ‘top_right’,
          url: “http://192.168.1.6:8081/motioneye”,
          width: “400px”,
          autoHide: true,
          autoHideDelay: 60000,
          debug: false
          and also tried this
          position: ‘top_left’,
          url: “http://192.168.1.6:8081”,
          width: “400px”,
          autoHide: false,
          debug: false
          shashank
            chrisfoerg
            I didn’t install it on my own, sorry. Did you try localhost?
              @chrisfoerg , with localhost in chromium i can view the image, in MM it is blank with localhost instead of IP
                chrisfoerg
                with debug: true, do you get any warnings?
                  Cato Module Developer
                  Have you installed Motion Eye on a different Raspberry Pi than the one you are running Magic Mirror on?
                  The motion trigger URL should not use same port as the video feed URL like it seems you have in your config. The last URL seems most correct. What happen when you open that in any browser?
                  • SnilleS Offline
                    Snille Module Developer
                    Hi, thank you for this module! :)
                    I’m currently trying to add my Bird Nest Camera(s) to my Mirror. But I can’t get the picture to show up.
                    Running MM v2.1.1 (development)
                    And Node.js v7.4.0
                    My in my config:
                    			module: 'MMM-MotionEye',
                    			position: 'middle_center',
                    			classes: "default everyone",
                    			header: "Holk 1",
                    				url: "http://10.0.0.136:8081",
                    				width: "640px",
                    				debug: true
                    My mirror is on: 10.0.0.112
                    IP Whitelist is (although that should not matter in this case):
                    	ipWhitelist: [
                    		"127.0.0.1",
                    		"::ffff:127.0.0.1",
                    		"::1",
                    		"::ffff:10.0.0.1/120"
                    The picture do show up if I “browse” to it in Midori on the local Consol:
                    The pm2 log shows no errors:
                    0|mm       | Connecting socket for: calendar
                    0|mm       | Starting node helper for: calendar
                    0|mm       | Connecting socket for: newsfeed
                    0|mm       | Starting module: newsfeed
                    0|mm       | Connecting socket for: email
                    0|mm       | email helper started ...
                    0|mm       | Connecting socket for: MMM-NetworkScanner
                    0|mm       | Starting module: MMM-NetworkScanner
                    0|mm       | Connecting socket for: MMM-MotionEye
                    0|mm       | Starting module: MMM-MotionEye
                    0|mm       | Connecting socket for: MMM-Remote-Control
                    0|mm       | Starting node helper for: MMM-Remote-Control
                    What Have I forgotten?
                    Thank you.
                    Best regards Snille
                      Cato Module Developer @Snille
                      @Snille Can you try another position (and maybe size): bottom_right / 400px
                      • SnilleS Offline
                        @Cato Nope, same thing. The header shows up, but no picture…
                          @Snille I don’t remember if “motion jpeg” is enabled by default in Motion Eye. Can you check your settings in Motion Eye? I’m at work now and have no change to check myself…
                          (Maybe it has another name)
                          • SnilleS Offline
                            @Cato There is not a specific “mjpeg” option as I can find. However on the “?” on the “Streaming URL” it says: “A URL that provides MJPEG stream of the camera” and that’s the URL I used…
                              @Snille Ok found the bug - update to 1.1.0 as instructed in README.md in GitHub.
                              • SnilleS Offline
                                Hi again, It would be cool to be able to hide the camera manually… For example visit another link… Say http://MagicMirror:8080/motioneye/1/hide
                                Right? :)
                                • SnilleS Offline
                                  Fixed. Just sent you a PR. :)
                                  Check it, I’m fairly new to Node.js so it may not be the best solution. :)
                                  • L Offline
                                    lolobyte
                                    Hi @Snille
                                    before i made a MM2, i started with a motion cam. It’s running now roundabout a half year outside from 30 ° to -20 ° C.
                                    I tried to insert my IP and port, but it don’t’ run.
                                    Any proposal to try a forensic research where to find the shitty error?
                                      @Snille Had some comments. Fix those and I’ll merge it :)
                                      SnilleS 1 Reply Last reply Reply Quote 0
                                        Cato Module Developer @lolobyte
                                        @lolobyte First question: What motion software do you use?
                                        • SnilleS Offline
                                          Snille Module Developer @Cato
                                          @Cato Great! Thanks for fixing my mistakes. :)
                                          • L Offline
                                            lolobyte @Cato
                                            @Cato
                                            Hi, that’s the info of help.
                                            Downloaded from
                                            https://www.dropbox.com/s/xdfcxm5hu71s97d/motion-mmal.tar.gz
                                            pi@raspi3-MM2:~ $ motion -h
                                            motion Version mmaltest, Copyright 2000-2005 Jeroen Vreeken/Folkert van Heusden/Kenneth Lavrsen
                                            usage: motion [options]
                                            Possible options:
                                            -n Run in non-daemon mode.
                                            -s Run in setup mode.
                                            -c config Full path and filename of config file.
                                            -d level Log level (1-9) (EMR, ALR, CRT, ERR, WRN, NTC, ERR, DBG, ALL). default: 6 / NTC.
                                            -k type Type of log (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). default: ALL.
                                            -p process_id_file Full path and filename of process id file (pid file).
                                            -l log file Full path and filename of log file.
                                            -m Disable motion detection at startup.
                                            -h Show this screen.
                                            Motion is configured using a config file only. If none is supplied,
                                            it will read motion.conf from current directory, ~/.motion or /etc.
                                            • 1 / 4
