    MMM-MotionEye - surveillance video stream on your mirror!
    70 Posts 15 Posters 97.8k Views 15 Watching
    • SnilleS Offline
      Snille Module Developer
      Hi, thank you for this module! :)
      I’m currently trying to add my Bird Nest Camera(s) to my Mirror. But I can’t get the picture to show up.
      Running MM v2.1.1 (development)
      And Node.js v7.4.0
      My in my config:
      			module: 'MMM-MotionEye',
      			position: 'middle_center',
      			classes: "default everyone",
      			header: "Holk 1",
      				url: "http://10.0.0.136:8081",
      				width: "640px",
      				debug: true
      My mirror is on: 10.0.0.112
      IP Whitelist is (although that should not matter in this case):
      	ipWhitelist: [
      		"127.0.0.1",
      		"::ffff:127.0.0.1",
      		"::1",
      		"::ffff:10.0.0.1/120"
      The picture do show up if I “browse” to it in Midori on the local Consol:
      The pm2 log shows no errors:
      0|mm       | Connecting socket for: calendar
      0|mm       | Starting node helper for: calendar
      0|mm       | Connecting socket for: newsfeed
      0|mm       | Starting module: newsfeed
      0|mm       | Connecting socket for: email
      0|mm       | email helper started ...
      0|mm       | Connecting socket for: MMM-NetworkScanner
      0|mm       | Starting module: MMM-NetworkScanner
      0|mm       | Connecting socket for: MMM-MotionEye
      0|mm       | Starting module: MMM-MotionEye
      0|mm       | Connecting socket for: MMM-Remote-Control
      0|mm       | Starting node helper for: MMM-Remote-Control
      What Have I forgotten?
      Thank you.
      Best regards Snille
      CatoC 1 Reply Last reply Reply Quote 0
      • CatoC Offline
        Cato Module Developer @Snille
        @Snille Can you try another position (and maybe size): bottom_right / 400px
        • SnilleS Offline
          @Cato Nope, same thing. The header shows up, but no picture…
          • CatoC Offline
            @Snille I don’t remember if “motion jpeg” is enabled by default in Motion Eye. Can you check your settings in Motion Eye? I’m at work now and have no change to check myself…
            (Maybe it has another name)
            • SnilleS Offline
              @Cato There is not a specific “mjpeg” option as I can find. However on the “?” on the “Streaming URL” it says: “A URL that provides MJPEG stream of the camera” and that’s the URL I used…
              • CatoC Offline
                @Snille Ok found the bug - update to 1.1.0 as instructed in README.md in GitHub.
                • SnilleS Offline
                  Hi again, It would be cool to be able to hide the camera manually… For example visit another link… Say http://MagicMirror:8080/motioneye/1/hide
                  Right? :)
                  • SnilleS Offline
                    Fixed. Just sent you a PR. :)
                    Check it, I’m fairly new to Node.js so it may not be the best solution. :)
                    • lolobyteL Offline
                      lolobyte
                      Hi @Snille
                      before i made a MM2, i started with a motion cam. It’s running now roundabout a half year outside from 30 ° to -20 ° C.
                      I tried to insert my IP and port, but it don’t’ run.
                      Any proposal to try a forensic research where to find the shitty error?
                      • CatoC Offline
                        @Snille Had some comments. Fix those and I’ll merge it :)
                        SnilleS 1 Reply Last reply Reply Quote 0
                        • CatoC Offline
                          Cato Module Developer @lolobyte
                          @lolobyte First question: What motion software do you use?
                          lolobyteL 1 Reply Last reply Reply Quote 0
                          • SnilleS Offline
                            Snille Module Developer @Cato
                            @Cato Great! Thanks for fixing my mistakes. :)
                            • lolobyteL Offline
                              lolobyte @Cato
                              @Cato
                              Hi, that’s the info of help.
                              Downloaded from
                              https://www.dropbox.com/s/xdfcxm5hu71s97d/motion-mmal.tar.gz
                              pi@raspi3-MM2:~ $ motion -h
                              motion Version mmaltest, Copyright 2000-2005 Jeroen Vreeken/Folkert van Heusden/Kenneth Lavrsen
                              usage: motion [options]
                              Possible options:
                              -n Run in non-daemon mode.
                              -s Run in setup mode.
                              -c config Full path and filename of config file.
                              -d level Log level (1-9) (EMR, ALR, CRT, ERR, WRN, NTC, ERR, DBG, ALL). default: 6 / NTC.
                              -k type Type of log (COR, STR, ENC, NET, DBL, EVT, TRK, VID, ALL). default: ALL.
                              -p process_id_file Full path and filename of process id file (pid file).
                              -l log file Full path and filename of log file.
                              -m Disable motion detection at startup.
                              -h Show this screen.
                              Motion is configured using a config file only. If none is supplied,
                              it will read motion.conf from current directory, ~/.motion or /etc.
                              • CatoC Offline
                                @lolobyte You will have to install motionEyeOS or motionEye to use this module. Please read pre-requisites.
                                • lolobyteL Offline
                                  lolobyte @Cato
                                  @Cato
                                  Thank you for your answer.
                                  I just tried MotionEyeOS before i went to Motion.
                                  In my eyes it wasn’t configurable with my desired functionality.
                                  I just hoped there is a possibility to implement foreign streams.
                                  • CatoC Offline
                                    @lolobyte As long as the software can provide a “motion jpeg”-stream, it can be supported.
                                    Basically, you can test it your selv by making a local .html-file with <img src="xxxxx" />
                                    • E Offline
                                      emos
                                      For some reason i just get a “broken” picture icon, and if i try to open http://MotionEyeIP/motioneye/1 the site just says:
                                      {"error": "not found"}
                                      I have disable the password for the ‘Surveillance Username’ so no login is required.
                                      I know the cam is available and motioneyos is working as normal. If i open http://192.168.1.200:8080/picture/1/current/ in my browser i can see the last snapshot, but not doing me any good…
                                      Any suggestion?
                                      	position: 'bottom_right',
                                      		url: "http://192.168.1.200:8080/motioneye/1",
                                      		debug: false
                                      S CatoC 2 Replies Last reply Reply Quote 0
                                        shashank @emos
                                        @emos hi, try changing the port (8080) in MM or camera , both MM and camera with 8080 will not work
                                        • CatoC Offline
                                          Cato Module Developer @emos
                                          @emos The URL you are using in your config seems to be the “web hook”-URL that you have to configure inside MotionEye if you want to automatically show video stream when motion is detected.
                                          The URL should be configured like this (from documentation): Video Streaming URL. You find it in Motion Eye in the Video Streaming Section under Usefull URLs by by clicking the Streaming URL link. It should look something like this: http://motioneye:8081 (probably an IP instead of hostname).
                                          • E Offline
                                            emos
                                            reinstalled motioneye on my other r.pi and now im able to view a stream from http://MotionEyeOS:8081, but only from cam 1.
                                            With http://MotionEyeOS:8081/motioneye/2 i still just get cam 1. Get the feeling im not understanding something.
                                            			position: 'lower_third',
                                            				url: "http://192.168.1.200:8081/motioneye/2",
                                            				autoHide: false,
                                            				debug: false
                                            • 1 / 4
