    MMM-MotionEye - surveillance video stream on your mirror!
    70 Posts 15 Posters 96.9k Views 15 Watching
    • CatoC Offline
      Cato Module Developer
      ‘MMM-MotionEye’ is a module for displaying a camera stream from Motion Eye on your MagicMirror².
      (Motion Eye is a free surveillance software that is highly recommended!)
      Example
      Installation instructions:
      [card:CatoAntonsen/MMM-MotionEye]
        shashank @Cato
        @Cato Hi, i could not able to find the instructions to install MotionEye on raspberry Pi 3 jessie/pixel , could you please help me with instruction guide or any url reference which worked for you.
        Shashank
          chrisfoerg
          https://github.com/ccrisan/motioneye
            shashank @chrisfoerg
            @chrisfoerg hi i tried installing successfully using below wiki url, i am able to view camera on motioneye software, on Magic Mirror camera is blank, i tried with both url and web hock
            https://github.com/ccrisan/motioneye/wiki/Install-On-Raspbian
            module: ‘MMM-MotionEye’,
            position: ‘top_right’,
            url: “http://192.168.1.6:8081/motioneye”,
            width: “400px”,
            autoHide: true,
            autoHideDelay: 60000,
            debug: false
            and also tried this
            position: ‘top_left’,
            url: “http://192.168.1.6:8081”,
            width: “400px”,
            autoHide: false,
            debug: false
            shashank
              chrisfoerg
              I didn’t install it on my own, sorry. Did you try localhost?
                @chrisfoerg , with localhost in chromium i can view the image, in MM it is blank with localhost instead of IP
                  chrisfoerg
                  with debug: true, do you get any warnings?
                  • CatoC Offline
                    Have you installed Motion Eye on a different Raspberry Pi than the one you are running Magic Mirror on?
                    The motion trigger URL should not use same port as the video feed URL like it seems you have in your config. The last URL seems most correct. What happen when you open that in any browser?
                    • SnilleS Offline
                      Snille Module Developer
                      Hi, thank you for this module! :)
                      I’m currently trying to add my Bird Nest Camera(s) to my Mirror. But I can’t get the picture to show up.
                      Running MM v2.1.1 (development)
                      And Node.js v7.4.0
                      My in my config:
                      			module: 'MMM-MotionEye',
                      			position: 'middle_center',
                      			classes: "default everyone",
                      			header: "Holk 1",
                      				url: "http://10.0.0.136:8081",
                      				width: "640px",
                      				debug: true
                      My mirror is on: 10.0.0.112
                      IP Whitelist is (although that should not matter in this case):
                      	ipWhitelist: [
                      		"127.0.0.1",
                      		"::ffff:127.0.0.1",
                      		"::1",
                      		"::ffff:10.0.0.1/120"
                      The picture do show up if I “browse” to it in Midori on the local Consol:
                      The pm2 log shows no errors:
                      0|mm       | Connecting socket for: calendar
                      0|mm       | Starting node helper for: calendar
                      0|mm       | Connecting socket for: newsfeed
                      0|mm       | Starting module: newsfeed
                      0|mm       | Connecting socket for: email
                      0|mm       | email helper started ...
                      0|mm       | Connecting socket for: MMM-NetworkScanner
                      0|mm       | Starting module: MMM-NetworkScanner
                      0|mm       | Connecting socket for: MMM-MotionEye
                      0|mm       | Starting module: MMM-MotionEye
                      0|mm       | Connecting socket for: MMM-Remote-Control
                      0|mm       | Starting node helper for: MMM-Remote-Control
                      What Have I forgotten?
                      Thank you.
                      Best regards Snille
                      CatoC 1 Reply Last reply Reply Quote 0
                      • CatoC Offline
                        Cato Module Developer @Snille
                        @Snille Can you try another position (and maybe size): bottom_right / 400px
                        • SnilleS Offline
                          @Cato Nope, same thing. The header shows up, but no picture…
                          • CatoC Offline
                            @Snille I don’t remember if “motion jpeg” is enabled by default in Motion Eye. Can you check your settings in Motion Eye? I’m at work now and have no change to check myself…
                            (Maybe it has another name)
                            • SnilleS Offline
                              @Cato There is not a specific “mjpeg” option as I can find. However on the “?” on the “Streaming URL” it says: “A URL that provides MJPEG stream of the camera” and that’s the URL I used…
                              • CatoC Offline
                                @Snille Ok found the bug - update to 1.1.0 as instructed in README.md in GitHub.
                                • SnilleS Offline
                                  Hi again, It would be cool to be able to hide the camera manually… For example visit another link… Say http://MagicMirror:8080/motioneye/1/hide
                                  Right? :)
                                  • SnilleS Offline
                                    Fixed. Just sent you a PR. :)
                                    Check it, I’m fairly new to Node.js so it may not be the best solution. :)
                                    • lolobyteL Offline
                                      lolobyte
                                      Hi @Snille
                                      before i made a MM2, i started with a motion cam. It’s running now roundabout a half year outside from 30 ° to -20 ° C.
                                      I tried to insert my IP and port, but it don’t’ run.
                                      Any proposal to try a forensic research where to find the shitty error?
                                      • CatoC Offline
                                        @Snille Had some comments. Fix those and I’ll merge it :)
                                        SnilleS 1 Reply Last reply Reply Quote 0
                                        • CatoC Offline
                                          Cato Module Developer @lolobyte
                                          @lolobyte First question: What motion software do you use?
                                          lolobyteL 1 Reply Last reply Reply Quote 0
                                          • SnilleS Offline
                                            Snille Module Developer @Cato
                                            @Cato Great! Thanks for fixing my mistakes. :)
                                            • 1 / 4
