    MMM-NetworkScanner
    networkscannerstatusmac address
    117 Posts 32 Posters 258.9k Views 33 Watching
    • I
      ianperrin @DevilRev
      @DevilRev there no such thing as a stupid question so keep asking away… ;)
      “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
      Mykle1M 1 Reply Last reply
      • K
        kclemen
        Cool module, shows directly the mobiles based on their MAC adress nicely. However, the online status is not displayed (yes, wifi is on and the mac addresses are correct :)). Any idea?
        EDIT; seems that only lowercase MAC adress work. My mobile phone just popped up, after changing the MAC address from uppercase (copy of advanced ip scanner) to lowercase.
        I 1 Reply Last reply
        • I
          ianperrin @kclemen
          @kclemen said in MMM-NetworkScanner:
          Could you post a copy of your config for the module - masking the MAC addresses ;)
          K 1 Reply Last reply
          • K
            kclemen @ianperrin
            @ianperrin I tough the problem was solved by what I stated in the edit of the previous post. But my mobile just went to offline on the mirror, even though wifi is still on…
            module: ‘MMM-NetworkScanner’,
            header: ‘Aanwezig in huis’,
            position: ‘top_left’,
            devices: [
            { macAddress: “1xxx”, name: “mom”, icon: “mobile”},
            { macAddress: “xxx”, name: “dad”, icon: “mobile”},
            /**** { macAddress: “xxxc”, name: “Laptop”, icon: “laptop”}, /
            { macAddress: “xxx”, name: “Mobile”, icon: “mobile”}, ****/
            showUnknown: false,
            showOffline: true,
            keepAlive: 300,
            updateInterval: 60
              BenNewsome
              Feature that turns off the mirror when you leave the house.
              I was looking at this module and your other module MMM-ModuleScheduler and was looking for something to turn my monitor off when I am not home.
              Your other module already lets me turn it off the display while I am asleep when combined with MMM-Remote-Control, and so I looked into doing the same for when I am out of the house (When my phone is not connected to my LAN).
              With a little help looking at MMM-ping I also managed to integrate IP address lockups and hostnames, so that if you have the option of IP addresses you can use them, and if not you can use MAC addresses, as I found IP addresses were more stable.
              I am just about to send a pull request, but for now I have the forked version here. I am very new to node.js still and so any feedback from anyone willing to try this out would be appreciated.
                Speedy-one
                Is it possible to add some color to the icons?
                • outjetO
                  outjet
                  I do love this module! I have one bizarre problem. Whenever my “Kirsten” device is not home, the module will not get past “Loading”. As long as she is home, the module loads OK. If I take her out of the list, it also loads OK.
                  		        module: 'MMM-NetworkScanner',
                  		        position: 'bottom_right',
                              devices: [
                          	      { macAddress: "cc:29:f5:36:ca:fe", name:   "Kirsten", icon: "female"},
                  	              { macAddress: "c4:9a:02:8c:50:72", name:   "Robert" , icon:   "male"},
                              showUnknown: false,
                              showOffline: true,
                              keepAlive: 75,
                              updateInterval: 5
                  Any thoughts? Thanks!
                  B 1 Reply Last reply
                    BenNewsome @outjet
                    @outjet I have a couple of thoughts. It looks like your update interval is very short. If you increased this to at least 10 seconds it might do something. It takes my Pi3 ~3 seconds to do the arp-scan command so if you are running a Pi2 it might be taking too long.
                    If that does nothing then I would suggest visiting your pi from a different machine. If you open chrome and go to your mirror ip port 8080 e.g. 19.168.3.14:8080 and then hit f12 the developer tools should show up. If you then go to the Console tab and reload the page, some errors should show up, and if you paste them here it might be useful.
                    If no errors show up then try running the module with the command node serveronly instead of pm2 or npm. This will throw probably more errors which could help.
                    OR
                    If you have static IP addresses you could try my fork here
                    outjetO 1 Reply Last reply
                    • outjetO
                      outjet @BenNewsome
                      @BenNewsome Thank you for the reply! I increased the interval as you suggested, and reverted a change I forgot I made to the .js, which got things going.
                      I remembered I altered the code to show: “Robert - Last seen 23 minutes ago”.
                      alt text
                      This has been working really nicely except when one of the devices is not online at module load time … My lack of JS skills catching up with me.
                      //Name
                      deviceItem.innerHTML += (device.name ? device.name + ". Last seen " + device.lastSeen.fromNow(): device.macAddress ) ;
                      I reverted to the original code and all is back to working, I’ll need to work on troubleshooting the “last seen” functionality to keep working if a device has not yet been seen. (if you see anything obvious, a penny for your thoughts!)
                      Thanks again
                      strawberry 3.141S I 2 Replies Last reply
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @outjet
                        @outjet i guess the problem is that you try to access device.lastSeen.fromNow() this will probably result in cannot run method fromNow of undefined
                        • I
                          ianperrin @BenNewsome
                          @BenNewsome Hi Ben - I’m commited elsewhere at the moment so sorry for not getting back to you sooner. Thanks for the pull request - I’ve accepted it and merged it into the module for all to share!
                          • I
                            ianperrin @outjet
                            @outjet I’ve not been able to spend much time on the Mirror (or this module) recently but I’ve just updated the module to include @BenNewsome’s additional functionality along with a showLastSeen option
                            Can you try updating your module and adding this to your config.js file e.g. showLastSeen: true,
                            • pugslyP
                              pugsly
                              This was working great for me until the latest git pull. I am getting the following errors now.
                              mm-0 (err): at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron-prebuilt/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                              mm-0 (err): at Function.Module._load (module.js:403:25)
                              mm-0 (err): at Module.require (module.js:483:17)
                              mm-0 (err): at require (internal/module.js:20:19)
                              mm-0 (err): at Object. (/home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js:10:14)
                              mm-0 (err): at Module._compile (module.js:556:32)
                              mm-0 (err): at Object.Module._extensions…js (module.js:565:10)
                              mm-0 (err): at Module.load (module.js:473:32)
                              mm-0 (err): at tryModuleLoad (module.js:432:12)
                              mm-0 (err): { Error: Cannot find module ‘ping’
                              mm-0 (err): at Module._resolveFilename (module.js:455:15)
                              mm-0 (err): at tryModuleLoad (module.js:432:12) code: ‘MODULE_NOT_FOUND’ }
                                BenNewsome @ianperrin
                                @ianperrin No problem, thanks for the great module(s). I hope I accidentally didn’t break anything as I’m pretty new to Node.
                                  BenNewsome @pugsly
                                  @pugsly Sorry thats from my update. Have you done a NPM install inside the module as it has a new dependency?
                                  Hopefully this will fix the problem.
                                  pugslyP 2 Replies Last reply
                                  • pugslyP
                                    pugsly @BenNewsome
                                    @BenNewsome yes I did
                                    • pugslyP
                                      pugsly @BenNewsome
                                      @BenNewsome I see that it installed two things under \Magicmirror\modules\MMM-NetworkScanner\node_modules
                                      one dir called ping which is what the error says it can’t find
                                      the other called sudo (that one kinda worries me).
                                      Anyway it still doesn’t work.
                                        BenNewsome @pugsly
                                        @pugsly Hi pugsly,
                                        sudo is for arp-scan which is the MAC address checker as this requires sudo to be called.
                                        Ping is the one I added which just calls the ping command from node.
                                        Could you try editing the file: /home/pi/MagicMirror/modules/MMM-NetworkScanner/node_helper.js
                                        On line 10 it says
                                        const ping = require('ping')
                                        Could you replace it with:
                                        const ping = require("ping");
                                        (Change the speach marks and add a semicolon.)
                                        I have no idea if this is the reason as it works fine on my system, but it is my current best guess.
                                        pugslyP 1 Reply Last reply
                                        • pugslyP
                                          pugsly @BenNewsome
                                          @BenNewsome Sorry… same thing, still says can’t find module ‘ping’.
                                            BenNewsome @pugsly
                                            @pugsly I think I have managed to replicate your error.
                                            Could you run the following command.
                                            (cd /home/pi/MagicMirror/modules/MMM-NetworkScanner && npm install)
                                            npm install needs running from the module directory so that it downloads the npm ping module. When I delete the ping module I get the error you do, and when I run the command above the error goes away.
                                            D pugslyP 2 Replies Last reply
                                            • 1 / 6
