    Calendar modification
    35 Posts 15 Posters 49.5k Views 12 Watching
    • MichMichM
      MichMich
      maximumNumberOfDays should be part of the config object:
      			module: 'calendar',
      			header: 'Events',
      			position: 'top_left',
                                      maximumNumberOfDays: 7,
      						symbol: 'calendar-check-o ',
      						url: 'https://calendar.google.com/calendar/ical/your-info'
        brad
        That makes perfect sense. :) sorry didn’t catch that…
          MagicCrumps1 @KirAsh4
          @KirAsh4 Weird. I had to make mine public or else the dashboard wont be able to display saying “No Events”
          K 1 Reply Last reply
          • K
            KirAsh4 Moderator @MagicCrumps1
            @MagicCrumps1, perhaps you were using the wrong URL? There’s both a public and a private one. If you use the public URL, then you must also set your calendar to public view. But the private URL has the authentication key in it. No need to make the calendar public.
            M 1 Reply Last reply
              @KirAsh4 Of course that worked. Thanks for the silver bullet
              • 0
                00conman
                Hey guys sorry I’ve been away so I haven’t seen all these posts but I would recommend putting the calendar in monthly mode so events to disappear prematurely.
                Reply Quote -1
                • K
                  KirAsh4 Moderator @00conman
                  @00conman, care to explain what you mean?
                  0 1 Reply Last reply
                  • 0
                    00conman @KirAsh4
                    @KirAsh4 I keep my calendar in month mode because it makes sure that events don’t delete halfway through a day and when in month mode it prevents a glitch from occurring. In that glitch on the mirror itself events will be assigned random times, in my case the newest event would be assigned 4:00 am and then each event after that would increase by the hour to 5:00 and so on. There is also an occurrence that events will randomly delete themselves from the actual mirror, not the online calendar, so putting this in month mode will cause them to remove themselves, or stop displaying, on the mirror at 12:00 o’clock midnight the day that they were assigned. It is certainly not necessary but I would do it because it take just a few seconds.
                    • 0
                      00conman
                      To anyone wondering how to switch the calendar to month mode here is a few images.
                      Main calendar:
                      https://gyazo.com/52f994a4b33968c8a0ebe2effe349179
                      And where you switch it:
                      https://gyazo.com/81e42213091d63b75e4bb9798e01d4ac
                      Please note that it might not work the first time in that case either try again and reload the page or try again and go to settings and save the calendar.
                      • K
                        KirAsh4 Moderator
                        That’s something that is outside of the scope of MM itself. They don’t have anything to do with the MM calendar module itself. When you said to keep the calendar in monthly mode, my first reaction was, ‘Uh, the calendar doesn’t have a monthly view’, hence my request for clarification.
                        It’s helpful to others who are using that specific service to host a calendar, and trying to incorporate it into MM, but you needed to specify what you were referring to.
                        Thanks for the clarification.
                        • A
                          aarinsingh
                          Wow, Thanks Guys.
                          I took a couple days of from the project and hit the lake, so sorry for the slow replies.
                          @MichMIch - That cured it, I had the maximunNumberOfDays Line to far down.
                          I have a couple other questions but I won’t clutter up the calendar Module board with them.
                            Plati
                            How to get ICAL for a Facebook calendar:
                            https://www.facebook.com/help/152652248136178/
                            2 different ICAL for birthdays and upcoming events :)
                            Useful config part: “maximumEntries: X”
                            And holidays calendars for many countries: https://www.mozilla.org/en-US/projects/calendar/holidays/
                              CCoates
                              Anyone had any luck with Outlook 365 or Iphone calendars?
                              L Y 2 Replies Last reply
                              • L
                                lolobyte @CCoates
                                @CCoates
                                iphone calendar is not a big problem.
                                U must go to iCloud Calendar and make the calendar of your choice usable for public access.
                                After that copy the link of your public calendar and insert this link into the config.js in your calendar module.
                                restart your magicmirror
                                • Y
                                  yawns Moderator @CCoates
                                  @CCoates said in Calendar modification:
                                  I use my outlook.com calendar without any problems
                                  C 1 Reply Last reply
                                    CCoates @yawns
                                    @yawns said in Calendar modification:
                                    How do you find out the ical or link???
                                    In outlook?
                                    • Y
                                      yawns Moderator
                                      I went to the web calendar on my computer (not on a smartphone or tablet!), went to settings (gear symbol top right) and clicked on options. The you see Publish Calendar and you are able to create the ics link.
                                      • L
                                        l8kerjuan
                                        is there a full month layout module?
                                        • MdManM
                                          MdMan
                                          Would this be the proper way to have it setup with both the Holiday cal and my personal shared one?
                                          			header: "US Holidays",
                                          						symbol: "calendar-check-o ",
                                          			module: 'calendar',
                                          			header: 'Shared',
                                          Holiday Cal is good for me hahaha reminds me of days off lol
                                          • MdManM
                                            MdMan
                                            For anyone wondering the same question as me, that would be how you do it. I tried it when I got home and my private calendar was also showing along with Holidays
