    Making my own translation [solved]
    tips and trickstutorial
    10 Posts 4 Posters 7.1k Views 3 Watching
    • MichMichM Offline
      MichMich
      • Copy translations/en.json to translations/no.json.
      • Modify the translations/no.json to Norwegian translations.
      • Add your translation to translations/translations.js.
      And don’t forget to send us a pull request so others can use it as well! :) (Do do this, you need to make a fork of the repository: https://help.github.com/articles/using-pull-requests/)
        Rahansen @MichMich
        @MichMich Did all of the above yesterday, the only result I got was that the wind direction notations only showed as small squares. The rest stayed in English. We use a special character for east (Ø), so maybe that had something to do with it?
        I’ll doublecheck everything when I get off from work, might just be I made a mistake somewhere :)
        MichMichM 1 Reply Last reply Reply Quote 0
        • MichMichM Offline
          MichMich @Rahansen
          I quickly tried using the Ø to see if it would give any problems, but it just works fines. (Tested on both the Raspberry and my Mac).
            Rahansen @MichMich
            @MichMich Thanks, got it working fine now. Made a pull request also, might do Swedish and Danish as well as that’s pretty similar to Norwegian : )
            • prototype0815P Offline
              prototype0815
              Does Norwegian have some special characters? What I want to solve is that the special characters of Germany are displayed at the “compliments”.
              I tried to change some occurrences of “UTF-8” to “ISO-8859” but this didn’t work.
              I would appreciate it if someone give me an answer in the near future, because the MM is the birthday present to my girlfriend.
              Wilco89W 1 Reply Last reply Reply Quote 0
              • Wilco89W Offline
                Wilco89 @prototype0815
                @prototype0815 said in Making my own translation [solved]:
                UTF-8
                Probaly you can try: http://www.theegglestongroup.com/writing/special_chars.php
                prototype0815P 2 Replies Last reply Reply Quote 0
                  prototype0815 @Wilco89
                  @Wilco89 Thank you, I’ll give it a try this afternoon.
                    @Wilco89 Hey Wilco89, that works like a charm !! I’m very happy that the first solution proposal works at the firt attempt ! Thank you very much !
                    • Wilco89W Offline
                      Wilco89
                      After years of programming & translations I learned a lot. In my own language (frisian) we do use some of these a lot, and in the other language (Dutch) we don’t use them often.
                      But for every starter it can Be a huge problem to solve this very Tiny issue.
                      I Hope you did finish your translation and Made a PR.
