    Alignment with module "random_quotes"
    16 Posts 3 Posters 12.0k Views 3 Watching
    • Q Offline
      qqqqqqqq
      I’m using the module random_quotes to display pre-defined quotes from a local file.
      Now, the problem is that I’ve set it’s position to ‘top_right’ & aligned it to the right so that it appears just below the current weather module; but instead of appearing in 2-3 rows, it it blocking the calendar module (currently hidden).
      I know I have to just change the margin value in the random_quotes.js, but I can’t seem to get it right. Here is the image.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @qqqqqqqq
        @qqqqqqqq try that in custom.css
        .random_quotes {
          width: 250px;
        • Q Offline
          qqqqqqqq
          My custom.css is a blank file.
          Is this correct? If yes, then it’s not working.
           * Magic Mirror                                      *
           * Custom CSS                                        *
           * By Michael Teeuw http://michaelteeuw.nl           *
           * MIT Licensed.                                     *
           * Add any custom CSS below.                         *
           * Changes to this files will be ignored by GIT. *
           body {
           .random_quotes {
            width: 200px;
            @qqqqqqqq delete body { and the last }
            • Q Offline
              qqqqqqqq
              Works like a charm!
              Thank you SOOO much.
              Can I use this to set margins for other modules as well? If yes, how?
              How do I set their alignment?
                @qqqqqqqq to set margins which is the outer distance to another element
                .MODULENAME {
                  margin: 10px 5px 15px 20px; //10px top, 5px right, 15px bottom, 20px left
                Q 1 Reply Last reply Reply Quote 0
                • Q Offline
                  qqqqqqqq
                  Okay, understood.
                  Are you familiar with the “stocks/MMM-Stocks” module? Because I’ve having trouble with them too.
                  I’ve got few more questions, should I create new threads for them, or can I PM you or something since you seem like an expert at MM2. ;)
                  strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 0
                    @qqqqqqqq because it’s related to another module I suggest to create a new thread, so users who have the same issue can find it via search. Benefit for you, you can also get opinions from others, but you can also send a pm.
                      Mykle1 Project Sponsor Module Developer @qqqqqqqq
                      @qqqqqqqq said in Alignment with module “random_quotes”:
                      Oh, he is. :thumbsup:
                      • Q Offline
                        qqqqqqqq @strawberry 3.141
                        @strawberry-3.141
                        I’m trying to align this module to right cuttently it appears like this
                        alt text
                        But there is no alignment tag.
                        I also tried to add align attribute to the HTML tag in the .js file. But even that doesn’t work.
                        Also, the module has a header property which isn’t showing up. It works if I add it to the HTML tag, but not via the config file.
