    messed up my config.. MM tells me to create a config file
    31 Posts 6 Posters 23.7k Views 6 Watching
    • johnnyboyJ Offline
      johnnyboy @strawberry 3.141
      johnnyboyJ 1 Reply Last reply Reply Quote 0
        johnnyboy @johnnyboy
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @johnnyboy
          @johnnyboy your quotes are wrong only " and ' are valid, but on your screenshot you used different ones which is causing the error
          johnnyboyJ 1 Reply Last reply Reply Quote 1
              @johnnyboy no you didn’t use markdown syntax, the forum messes up quotes if their not in set in markdown codeblock.
              your second calendar uses different quotes
                  @johnnyboy as i said your pictures don’t show everything and your code snippet is corrupt, why you not just trying it out and if it doesnt work you report again?
                        • 1 / 4
