    messed up my config.. MM tells me to create a config file
    31 Posts 6 Posters 25.7k Views 6 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @johnnyboy
      @johnnyboy as i said your pictures don’t show everything and your code snippet is corrupt, why you not just trying it out and if it doesnt work you report again?
      johnnyboyJ 1 Reply Last reply Reply Quote 0
      • johnnyboyJ Offline
        johnnyboy @strawberry 3.141
          johnnyboy @johnnyboy
                  johnnyboyJ strawberry 3.141S 2 Replies Last reply Reply Quote 0
                          @johnnyboy as I said earlier you can use single and double quotes, it doesn’t matter which one, but it has to be either " or ' and you used a backtick `, which is not working
                          johnnyboyJ 2 Replies Last reply Reply Quote 0
                            • W Offline
                              wizz
                              @johnnyboy said in messed up my config.. MM tells me to create a config file:
                              I see that you got one }; that are making the error should look like this }, if i am right but i am new to this to so i can be wrong :)
                                  johnnyboy @wizz
                                  • X Offline
                                    xy86
                                    Hey,
                                    I have some issues here too. Not very familiar with Linux and just got my first RPI, for this project specifically :)
                                    I’ve been trying for hours now to get this to work, but MM just says that I need a working config file. I’ve tried editing the text in Sublime (I find it easier to read than the built in texteditor on Raspbian), but I can’t seem to find the errors.
                                    I’m attaching the contents of my config file, minus the tokens and stuff:
                                    /* Magic Mirror Config Sample
                                     * MIT Licensed.
                                    var config = {
                                    	port: 8080,
                                    	address: 192.168.86.131,
                                    	ipWhitelist: ["192.168.86.100", "192.168.86.150"],
                                    	language: "en",
                                    	timeFormat: 24,
                                    	units: "metric",
                                    			module: "alert",
                                    			module: "updatenotification",
                                    			position: "top_bar"
                                    			module: "clock",
                                    			position: "top_left"
                                    			header: "Kalender",
                                    						symbol: "calendar-check-o",
                                    						url: "https://calendar.google.com/calendar/the_rest_of_my_calendars_URL"
                                    			module: "compliments",
                                    			position: "lower_third"
                                    			module: "currentweather",
                                    				locationID: "3149533",  //ID from http://www.openweathermap.org
                                    				appid: "MY-TOKEN-HERE"
                                    			module: "weatherforecast",
                                    			header: "Weather Forecast",
                                    			module: "newsfeed",
                                    			position: "bottom_bar",
                                    				feeds: [
                                    						title: "NRK Siste nytt",
                                    						url: "http://www.nrk.no/nyheter/siste.rss"
                                    				showSourceTitle: true,
                                    				showPublishDate: true
                                    	module: "MMM-Ruter",
                                    	header: "Reisetider",
                                    		showPlatform: true,
                                    		maxItems: 10,
                                    		stops: [
                                    				stopId: "4024715",
                                    				platforms: [ "1", "2" ],
                                    				timeToThere: 5
                                    				stopId: "4020080",
                                    				timeToThere: 0
                                    Any help is highly appreciated!
                                      johnnyboy @xy86
                                      X 1 Reply Last reply Reply Quote 0
                                      • X Offline
                                        xy86 @johnnyboy
                                        @johnnyboy Thanks for the leads! I’ll have a look at it.
                                        I didn’t change the original file (or at least, I don’t think I did) - except for the alterations with keys and the Ruter-addon.
                                        Stupid question: Is the config.js file supposed to be in the config folder, or should there be a /config/config (ie another folder called config) that contains the config.js ?
                                        Mykle1M johnnyboyJ 2 Replies Last reply Reply Quote 0
                                          Mykle1 Project Sponsor Module Developer @xy86
                                          @xy86 said in messed up my config.. MM tells me to create a config file:
                                          Yes
                                            johnnyboy @xy86
