    messed up my config.. MM tells me to create a config file
    31 Posts 6 Posters 25.8k Views 6 Watching
    • johnnyboyJ Offline
      johnnyboy @strawberry 3.141
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @johnnyboy
        @johnnyboy no you didn’t use markdown syntax, the forum messes up quotes if their not in set in markdown codeblock.
        your second calendar uses different quotes
        johnnyboyJ 1 Reply Last reply Reply Quote 1
            @johnnyboy as i said your pictures don’t show everything and your code snippet is corrupt, why you not just trying it out and if it doesnt work you report again?
            johnnyboyJ 1 Reply Last reply Reply Quote 0
                johnnyboy @johnnyboy
                        johnnyboyJ strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                @johnnyboy as I said earlier you can use single and double quotes, it doesn’t matter which one, but it has to be either " or ' and you used a backtick `, which is not working
                                johnnyboyJ 2 Replies Last reply Reply Quote 0
                                  • W Offline
                                    wizz
                                    @johnnyboy said in messed up my config.. MM tells me to create a config file:
                                    I see that you got one }; that are making the error should look like this }, if i am right but i am new to this to so i can be wrong :)
                                        johnnyboy @wizz
                                        • X Offline
                                          xy86
                                          Hey,
                                          I have some issues here too. Not very familiar with Linux and just got my first RPI, for this project specifically :)
                                          I’ve been trying for hours now to get this to work, but MM just says that I need a working config file. I’ve tried editing the text in Sublime (I find it easier to read than the built in texteditor on Raspbian), but I can’t seem to find the errors.
                                          I’m attaching the contents of my config file, minus the tokens and stuff:
                                          /* Magic Mirror Config Sample
                                           * MIT Licensed.
                                          var config = {
                                          	port: 8080,
                                          	address: 192.168.86.131,
                                          	ipWhitelist: ["192.168.86.100", "192.168.86.150"],
                                          	language: "en",
                                          	timeFormat: 24,
                                          	units: "metric",
                                          			module: "alert",
                                          			module: "updatenotification",
                                          			position: "top_bar"
                                          			module: "clock",
                                          			position: "top_left"
                                          			header: "Kalender",
                                          						symbol: "calendar-check-o",
                                          						url: "https://calendar.google.com/calendar/the_rest_of_my_calendars_URL"
                                          			module: "compliments",
                                          			position: "lower_third"
                                          			module: "currentweather",
                                          				locationID: "3149533",  //ID from http://www.openweathermap.org
                                          				appid: "MY-TOKEN-HERE"
                                          			module: "weatherforecast",
                                          			header: "Weather Forecast",
                                          			module: "newsfeed",
                                          			position: "bottom_bar",
                                          				feeds: [
                                          						title: "NRK Siste nytt",
                                          						url: "http://www.nrk.no/nyheter/siste.rss"
                                          				showSourceTitle: true,
                                          				showPublishDate: true
                                          	module: "MMM-Ruter",
                                          	header: "Reisetider",
                                          		showPlatform: true,
                                          		maxItems: 10,
                                          		stops: [
                                          				stopId: "4024715",
                                          				platforms: [ "1", "2" ],
                                          				timeToThere: 5
                                          				stopId: "4020080",
                                          				timeToThere: 0
                                          Any help is highly appreciated!
                                            johnnyboy @xy86
                                            X 1 Reply Last reply Reply Quote 0
