    messed up my config.. MM tells me to create a config file
    31 Posts 6 Posters 25.4k Views 6 Watching
    • W Offline
      wizz
      @johnnyboy said in messed up my config.. MM tells me to create a config file:
      I see that you got one }; that are making the error should look like this }, if i am right but i am new to this to so i can be wrong :)
      johnnyboyJ 1 Reply Last reply Reply Quote 0
      • johnnyboyJ Offline
        johnnyboy @strawberry 3.141
          johnnyboy @wizz
          • X Offline
            xy86
            Hey,
            I have some issues here too. Not very familiar with Linux and just got my first RPI, for this project specifically :)
            I’ve been trying for hours now to get this to work, but MM just says that I need a working config file. I’ve tried editing the text in Sublime (I find it easier to read than the built in texteditor on Raspbian), but I can’t seem to find the errors.
            I’m attaching the contents of my config file, minus the tokens and stuff:
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
            	port: 8080,
            	address: 192.168.86.131,
            	ipWhitelist: ["192.168.86.100", "192.168.86.150"],
            	language: "en",
            	timeFormat: 24,
            	units: "metric",
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
            			header: "Kalender",
            						symbol: "calendar-check-o",
            						url: "https://calendar.google.com/calendar/the_rest_of_my_calendars_URL"
            			module: "compliments",
            			position: "lower_third"
            			module: "currentweather",
            				locationID: "3149533",  //ID from http://www.openweathermap.org
            				appid: "MY-TOKEN-HERE"
            			module: "weatherforecast",
            			header: "Weather Forecast",
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "NRK Siste nytt",
            						url: "http://www.nrk.no/nyheter/siste.rss"
            				showSourceTitle: true,
            				showPublishDate: true
            	module: "MMM-Ruter",
            	header: "Reisetider",
            		showPlatform: true,
            		maxItems: 10,
            		stops: [
            				stopId: "4024715",
            				platforms: [ "1", "2" ],
            				timeToThere: 5
            				stopId: "4020080",
            				timeToThere: 0
            Any help is highly appreciated!
              johnnyboy @xy86
              X 1 Reply Last reply Reply Quote 0
              • X Offline
                xy86 @johnnyboy
                @johnnyboy Thanks for the leads! I’ll have a look at it.
                I didn’t change the original file (or at least, I don’t think I did) - except for the alterations with keys and the Ruter-addon.
                Stupid question: Is the config.js file supposed to be in the config folder, or should there be a /config/config (ie another folder called config) that contains the config.js ?
                Mykle1M johnnyboyJ 2 Replies Last reply Reply Quote 0
                  Mykle1 Project Sponsor Module Developer @xy86
                  @xy86 said in messed up my config.. MM tells me to create a config file:
                  Yes
                    johnnyboy @xy86
                    • X Offline
                      xy86 @johnnyboy
                      @johnnyboy Thanks - I should have learned that by now, but… Haha. You know.
                      I ended up re-installing Raspbian as i messed up something so the wifi-card wasn’t recognized anymore.
                      I also followed the step-by-step guide at https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6 and got by the cleaning process. I then tried installing apache2 and PHP5 again; getting the same error as the one below.
                      When I try installing MM now, I get these errors:
                      Installing helper tools ...
                      Reading package lists... Done
                      Building dependency tree
                      build-essential is already the newest version.
                      curl is already the newest version.
                      git is already the newest version.
                      unzip is already the newest version.
                      wget is already the newest version.
                      1 not fully installed or removed.
                      After this operation, 0 B of additional disk space will be used.
                      Can't set locale; make sure $LC_* and $LANG are correct!
                      perl: warning: Setting locale failed.
                      perl: warning: Please check that your locale settings:
                      	LANGUAGE = (unset),
                      	LC_ALL = (unset),
                      	LC_CTYPE = "UTF-8",
                      	LANG = "en_GB.UTF-8"
                          are supported and installed on your system.
                      perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
                      locale: Cannot set LC_CTYPE to default locale: No such file or directory
                      locale: Cannot set LC_ALL to default locale: No such file or directory
                      Setting up libpam-chksshpwd:armhf (1.1.8-3.1+deb8u2+rpi2) ...
                      mkdir: cannot create directory '/var/lib/chksshpwd/': File exists
                      dpkg: error processing package libpam-chksshpwd:armhf (--configure):
                       subprocess installed post-installation script returned error exit status 1
                      Errors were encountered while processing:
                      E: Sub-process /usr/bin/dpkg returned an error code (1)
                      I tried googling the error, but I’m not sure if I’m on the right track with solutions described.
                      Any ideas?
                      • Y Offline
                        yawns Moderator
                        What are you installing PHP5 and apache2 for?
                          johnnyboy @xy86
