    messed up my config.. MM tells me to create a config file
    31 Posts 6 Posters 24.1k Views 6 Watching
    • johnnyboyJ Offline
      johnnyboy @johnnyboy
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @johnnyboy
        @johnnyboy as I said earlier you can use single and double quotes, it doesn’t matter which one, but it has to be either " or ' and you used a backtick `, which is not working
        johnnyboyJ 2 Replies Last reply Reply Quote 0
          johnnyboy @strawberry 3.141
          • W Offline
            wizz
            @johnnyboy said in messed up my config.. MM tells me to create a config file:
            I see that you got one }; that are making the error should look like this }, if i am right but i am new to this to so i can be wrong :)
            johnnyboyJ 1 Reply Last reply Reply Quote 0
                johnnyboy @wizz
                • X Offline
                  xy86
                  Hey,
                  I have some issues here too. Not very familiar with Linux and just got my first RPI, for this project specifically :)
                  I’ve been trying for hours now to get this to work, but MM just says that I need a working config file. I’ve tried editing the text in Sublime (I find it easier to read than the built in texteditor on Raspbian), but I can’t seem to find the errors.
                  I’m attaching the contents of my config file, minus the tokens and stuff:
                  /* Magic Mirror Config Sample
                   * MIT Licensed.
                  var config = {
                  	port: 8080,
                  	address: 192.168.86.131,
                  	ipWhitelist: ["192.168.86.100", "192.168.86.150"],
                  	language: "en",
                  	timeFormat: 24,
                  	units: "metric",
                  			module: "alert",
                  			module: "updatenotification",
                  			position: "top_bar"
                  			module: "clock",
                  			position: "top_left"
                  			header: "Kalender",
                  						symbol: "calendar-check-o",
                  						url: "https://calendar.google.com/calendar/the_rest_of_my_calendars_URL"
                  			module: "compliments",
                  			position: "lower_third"
                  			module: "currentweather",
                  				locationID: "3149533",  //ID from http://www.openweathermap.org
                  				appid: "MY-TOKEN-HERE"
                  			module: "weatherforecast",
                  			header: "Weather Forecast",
                  			module: "newsfeed",
                  			position: "bottom_bar",
                  				feeds: [
                  						title: "NRK Siste nytt",
                  						url: "http://www.nrk.no/nyheter/siste.rss"
                  				showSourceTitle: true,
                  				showPublishDate: true
                  	module: "MMM-Ruter",
                  	header: "Reisetider",
                  		showPlatform: true,
                  		maxItems: 10,
                  		stops: [
                  				stopId: "4024715",
                  				platforms: [ "1", "2" ],
                  				timeToThere: 5
                  				stopId: "4020080",
                  				timeToThere: 0
                  Any help is highly appreciated!
                    johnnyboy @xy86
                    X 1 Reply Last reply Reply Quote 0
                    • X Offline
                      xy86 @johnnyboy
                      @johnnyboy Thanks for the leads! I’ll have a look at it.
                      I didn’t change the original file (or at least, I don’t think I did) - except for the alterations with keys and the Ruter-addon.
                      Stupid question: Is the config.js file supposed to be in the config folder, or should there be a /config/config (ie another folder called config) that contains the config.js ?
                      Mykle1M johnnyboyJ 2 Replies Last reply Reply Quote 0
                        Mykle1 Project Sponsor Module Developer @xy86
                        @xy86 said in messed up my config.. MM tells me to create a config file:
                        Yes
                          johnnyboy @xy86
                          • X Offline
                            xy86 @johnnyboy
                            @johnnyboy Thanks - I should have learned that by now, but… Haha. You know.
                            I ended up re-installing Raspbian as i messed up something so the wifi-card wasn’t recognized anymore.
                            I also followed the step-by-step guide at https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6 and got by the cleaning process. I then tried installing apache2 and PHP5 again; getting the same error as the one below.
                            When I try installing MM now, I get these errors:
                            Installing helper tools ...
                            Reading package lists... Done
                            Building dependency tree
                            build-essential is already the newest version.
                            curl is already the newest version.
                            git is already the newest version.
                            unzip is already the newest version.
                            wget is already the newest version.
                            1 not fully installed or removed.
                            After this operation, 0 B of additional disk space will be used.
                            Can't set locale; make sure $LC_* and $LANG are correct!
                            perl: warning: Setting locale failed.
                            perl: warning: Please check that your locale settings:
                            	LANGUAGE = (unset),
                            	LC_ALL = (unset),
                            	LC_CTYPE = "UTF-8",
                            	LANG = "en_GB.UTF-8"
                                are supported and installed on your system.
                            perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
                            locale: Cannot set LC_CTYPE to default locale: No such file or directory
                            locale: Cannot set LC_ALL to default locale: No such file or directory
                            Setting up libpam-chksshpwd:armhf (1.1.8-3.1+deb8u2+rpi2) ...
                            mkdir: cannot create directory '/var/lib/chksshpwd/': File exists
                            dpkg: error processing package libpam-chksshpwd:armhf (--configure):
                             subprocess installed post-installation script returned error exit status 1
                            Errors were encountered while processing:
                            E: Sub-process /usr/bin/dpkg returned an error code (1)
                            I tried googling the error, but I’m not sure if I’m on the right track with solutions described.
                            Any ideas?
                            • yawnsY Offline
                              yawns Moderator
                              What are you installing PHP5 and apache2 for?
                                johnnyboy @xy86
