    messed up my config.. MM tells me to create a config file
    31 Posts 6 Posters 25.7k Views 6 Watching
    • johnnyboyJ Offline
      johnnyboy @johnnyboy
      johnnyboyJ 1 Reply Last reply Reply Quote 0
        johnnyboyJ strawberry 3.141S 2 Replies Last reply Reply Quote 0
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @johnnyboy
                @johnnyboy as I said earlier you can use single and double quotes, it doesn’t matter which one, but it has to be either " or ' and you used a backtick `, which is not working
                johnnyboyJ 2 Replies Last reply Reply Quote 0
                  johnnyboy @strawberry 3.141
                  • W Offline
                    wizz
                    @johnnyboy said in messed up my config.. MM tells me to create a config file:
                    I see that you got one }; that are making the error should look like this }, if i am right but i am new to this to so i can be wrong :)
                        johnnyboy @wizz
                        • X Offline
                          xy86
                          Hey,
                          I have some issues here too. Not very familiar with Linux and just got my first RPI, for this project specifically :)
                          I’ve been trying for hours now to get this to work, but MM just says that I need a working config file. I’ve tried editing the text in Sublime (I find it easier to read than the built in texteditor on Raspbian), but I can’t seem to find the errors.
                          I’m attaching the contents of my config file, minus the tokens and stuff:
                          /* Magic Mirror Config Sample
                           * MIT Licensed.
                          var config = {
                          	port: 8080,
                          	address: 192.168.86.131,
                          	ipWhitelist: ["192.168.86.100", "192.168.86.150"],
                          	language: "en",
                          	timeFormat: 24,
                          	units: "metric",
                          			module: "alert",
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: "clock",
                          			position: "top_left"
                          			header: "Kalender",
                          						symbol: "calendar-check-o",
                          						url: "https://calendar.google.com/calendar/the_rest_of_my_calendars_URL"
                          			module: "compliments",
                          			position: "lower_third"
                          			module: "currentweather",
                          				locationID: "3149533",  //ID from http://www.openweathermap.org
                          				appid: "MY-TOKEN-HERE"
                          			module: "weatherforecast",
                          			header: "Weather Forecast",
                          			module: "newsfeed",
                          			position: "bottom_bar",
                          				feeds: [
                          						title: "NRK Siste nytt",
                          						url: "http://www.nrk.no/nyheter/siste.rss"
                          				showSourceTitle: true,
                          				showPublishDate: true
                          	module: "MMM-Ruter",
                          	header: "Reisetider",
                          		showPlatform: true,
                          		maxItems: 10,
                          		stops: [
                          				stopId: "4024715",
                          				platforms: [ "1", "2" ],
                          				timeToThere: 5
                          				stopId: "4020080",
                          				timeToThere: 0
                          Any help is highly appreciated!
                            johnnyboy @xy86
                            X 1 Reply Last reply Reply Quote 0
                            • X Offline
                              xy86 @johnnyboy
                              @johnnyboy Thanks for the leads! I’ll have a look at it.
                              I didn’t change the original file (or at least, I don’t think I did) - except for the alterations with keys and the Ruter-addon.
                              Stupid question: Is the config.js file supposed to be in the config folder, or should there be a /config/config (ie another folder called config) that contains the config.js ?
                              Mykle1M johnnyboyJ 2 Replies Last reply Reply Quote 0
                                Mykle1 Project Sponsor Module Developer @xy86
                                @xy86 said in messed up my config.. MM tells me to create a config file:
                                Yes
                                  johnnyboy @xy86
                                  • X Offline
                                    xy86 @johnnyboy
                                    @johnnyboy Thanks - I should have learned that by now, but… Haha. You know.
                                    I ended up re-installing Raspbian as i messed up something so the wifi-card wasn’t recognized anymore.
                                    I also followed the step-by-step guide at https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6 and got by the cleaning process. I then tried installing apache2 and PHP5 again; getting the same error as the one below.
                                    When I try installing MM now, I get these errors:
                                    Installing helper tools ...
                                    Reading package lists... Done
                                    Building dependency tree
                                    build-essential is already the newest version.
                                    curl is already the newest version.
                                    git is already the newest version.
                                    unzip is already the newest version.
                                    wget is already the newest version.
                                    1 not fully installed or removed.
                                    After this operation, 0 B of additional disk space will be used.
                                    Can't set locale; make sure $LC_* and $LANG are correct!
                                    perl: warning: Setting locale failed.
                                    perl: warning: Please check that your locale settings:
                                    	LANGUAGE = (unset),
                                    	LC_ALL = (unset),
                                    	LC_CTYPE = "UTF-8",
                                    	LANG = "en_GB.UTF-8"
                                        are supported and installed on your system.
                                    perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
                                    locale: Cannot set LC_CTYPE to default locale: No such file or directory
                                    locale: Cannot set LC_ALL to default locale: No such file or directory
                                    Setting up libpam-chksshpwd:armhf (1.1.8-3.1+deb8u2+rpi2) ...
                                    mkdir: cannot create directory '/var/lib/chksshpwd/': File exists
                                    dpkg: error processing package libpam-chksshpwd:armhf (--configure):
                                     subprocess installed post-installation script returned error exit status 1
                                    Errors were encountered while processing:
                                    E: Sub-process /usr/bin/dpkg returned an error code (1)
                                    I tried googling the error, but I’m not sure if I’m on the right track with solutions described.
                                    Any ideas?
                                    • Y Offline
                                      yawns Moderator
                                      What are you installing PHP5 and apache2 for?
                                        johnnyboy @xy86
