    Wires at back of Monitor too short
    8 Posts 2 Posters 3.3k Views 2 Watching
    • johnnyboyJ
      johnnyboy
      johnnyboyJ Mykle1M 2 Replies Last reply Reply Quote 0
      • johnnyboyJ
        johnnyboy @johnnyboy
        johnnyboyJ 1 Reply Last reply Reply Quote 0
        • johnnyboyJ
          • johnnyboyJ
            • johnnyboyJ
              • johnnyboyJ
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @johnnyboy
                  @johnnyboy
                  Because you like hearing from me and like dropping my name
                  You know, if you build a frame that extends past the edge of the box that will contain the monitor, you can effectively hide the joystick and not have to johnnyboy around with the wiring. :wink:
                  Now, looking at your pictures closely, (I counted the 8 wires and the 8 pins) I would say that each of the eight wires of the harness connect to only one pin each via the clip connector on both the monitor circuit board and the joystick circuit board. With that, and IMHO, I would say that you can lengthen each wire, being careful to match the gauge of the wire as closely as possible. Also, being careful to splice the correct wires to each other. I would use shrinkwrap/crimp connectors for the splicing for proper connection and insulation.
                  Seeing as you’ll only be extending these wires a few inches (from what I can see) you won’t encounter any resistance problems or degradation in performance of the joystick.
                  Peace bro . . .
                  johnnyboyJ 1 Reply Last reply Reply Quote 1
                  • johnnyboyJ
                    johnnyboy @Mykle1
