    email module black screen
    neig
    10 Posts 5 Posters 6.5k Views 5 Watching
    • F Offline
      fischi87
      Hello, after i installed the email module and wrote like in the readme the config in the config.js i have after restart pm2 a black screen. if i cancel the module from the config.js i can see my screen again with my modules.
      anyone a idea?
      greedings
      • tosti007T Offline
        tosti007 Module Developer
        Are you certain you installed it properly by going into the folder and using the npm install command?
        If there is anything don't hesitate to contact me!
        ProfileSwitcher, TouchNotifications
          roramirez Core Contributors
          @tosti007 At certain point some errors for this kind of case is because a forget
          npm install
          We’ll can figure out a solution for problems like that.
          • F Offline
            fischi87 @tosti007
            @tosti007 yes of course and without any errors. when i cancel the config in config.js everthing is working very good
            i tried it agin and this is the output:
            pi@Magic-Mirror:~/MagicMirror/modules/email-mirror $ npm install
            npm WARN email@0.0.1 No repository field.
            npm WARN email@0.0.1 No license field.
            i tried something and now i get after DISPLAY=:0 npm start this:
            Starting MagicMirror: v2.1.0
            Loading config ...
            Loading module helpers ...
            null
            No helper found for module: MMM-Callmonitor-Current-Call.
            All module helpers loaded.
            Starting server op port 8090 ...
            Server started ...
            Connecting socket for: MMM-FRITZ-Box-Callmonitor
            Starting module: MMM-FRITZ-Box-Callmonitor
            Connecting socket for: MMM-iCloud-Client
            Starting helper: MMM-iCloud-Client
            loading Database
            Connecting socket for: MMM-SystemStats
            Connecting socket for: MMM-PIR-Sensor
            Connecting socket for: email-mirror
            email-mirror helper started ...
            { Error: listen EADDRINUSE :::8090
                at Object.exports._errnoException (util.js:1026:11)
                at exports._exceptionWithHostPort (util.js:1049:20)
                at Server._listen2 (net.js:1253:14)
                at listen (net.js:1289:10)
                at net.js:1399:9
                at _combinedTickCallback (internal/process/next_tick.js:77:11)
                at process._tickCallback (internal/process/next_tick.js:98:9)
                at Module.runMain (module.js:592:11)
                at run (bootstrap_node.js:402:7)
                at startup (bootstrap_node.js:157:9)
              code: 'EADDRINUSE',
              errno: 'EADDRINUSE',
              syscall: 'listen',
              address: '::',
              port: 8090 }
            Launching application.
            maybe this helps?
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @fischi87
              @fischi87 something is already using this port, either an old instance of mm is still running or something else is using that port you can change the port in the config file
              • F Offline
                fischi87 @strawberry 3.141
                @strawberry-3.141 i changed it and the error is not working anymore thanks but the screen is still black when i activate the email module?!
                  @fischi87 can you start the mirror and post the logs from the terminal and electron (start with npm start dev)
                  • F Offline
                    @strawberry-3.141
                    pi@Magic-Mirror:~/MagicMirror $ sudo npm start dev
                    > magicmirror@2.1.0 start /home/pi/MagicMirror
                    > electron js/electron.js "dev"
                    npm ERR! Linux 4.4.38-v7+
                    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
                    npm ERR! node v6.10.0
                    npm ERR! npm  v4.3.0
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! magicmirror@2.1.0 start: `electron js/electron.js "dev"`
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js "dev"'.
                    npm ERR! If you do, this is most likely a problem with the magicmirror package,
                    npm ERR! not with npm itself.
                    npm ERR!     electron js/electron.js "dev"
                    npm ERR!     npm bugs magicmirror
                    npm ERR! Or if that isn't available, you can get their info via:
                    npm ERR!     npm owner ls magicmirror
                    npm ERR!     /root/.npm/_logs/2017-02-24T09_43_49_882Z-debug.log
                    how i do it with electron?
                    • F Offline
                      fischi87
                      i found the mistake because of the black screen.
                      i use the module Carousel and in this i didn’t change the module ‘email-mirror’ to ‘email’ because after installation the folders name is ‘email-mirror’ but u have to change this folder in /MagicMirror/modules to ‘email’ than it works.
                      thanks
                        ronny3050 Module Developer @fischi87
                        @fischi87 said in email module black screen:
                        I apologize you had to figure this out the hard way, but the installation instructions clearly state this.
