    email module black screen
    neig
    10 Posts 5 Posters 6.7k Views 5 Watching
    • F Offline
      fischi87 @tosti007
      @tosti007 yes of course and without any errors. when i cancel the config in config.js everthing is working very good
      i tried it agin and this is the output:
      pi@Magic-Mirror:~/MagicMirror/modules/email-mirror $ npm install
      npm WARN email@0.0.1 No repository field.
      npm WARN email@0.0.1 No license field.
      i tried something and now i get after DISPLAY=:0 npm start this:
      Starting MagicMirror: v2.1.0
      Loading config ...
      Loading module helpers ...
      null
      No helper found for module: MMM-Callmonitor-Current-Call.
      All module helpers loaded.
      Starting server op port 8090 ...
      Server started ...
      Connecting socket for: MMM-FRITZ-Box-Callmonitor
      Starting module: MMM-FRITZ-Box-Callmonitor
      Connecting socket for: MMM-iCloud-Client
      Starting helper: MMM-iCloud-Client
      loading Database
      Connecting socket for: MMM-SystemStats
      Connecting socket for: MMM-PIR-Sensor
      Connecting socket for: email-mirror
      email-mirror helper started ...
      { Error: listen EADDRINUSE :::8090
          at Object.exports._errnoException (util.js:1026:11)
          at exports._exceptionWithHostPort (util.js:1049:20)
          at Server._listen2 (net.js:1253:14)
          at listen (net.js:1289:10)
          at net.js:1399:9
          at _combinedTickCallback (internal/process/next_tick.js:77:11)
          at process._tickCallback (internal/process/next_tick.js:98:9)
          at Module.runMain (module.js:592:11)
          at run (bootstrap_node.js:402:7)
          at startup (bootstrap_node.js:157:9)
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '::',
        port: 8090 }
      Launching application.
      maybe this helps?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @fischi87
        @fischi87 something is already using this port, either an old instance of mm is still running or something else is using that port you can change the port in the config file
        • F Offline
          fischi87 @strawberry 3.141
          @strawberry-3.141 i changed it and the error is not working anymore thanks but the screen is still black when i activate the email module?!
            @fischi87 can you start the mirror and post the logs from the terminal and electron (start with npm start dev)
            • F Offline
              @strawberry-3.141
              pi@Magic-Mirror:~/MagicMirror $ sudo npm start dev
              > magicmirror@2.1.0 start /home/pi/MagicMirror
              > electron js/electron.js "dev"
              npm ERR! Linux 4.4.38-v7+
              npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
              npm ERR! node v6.10.0
              npm ERR! npm  v4.3.0
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! magicmirror@2.1.0 start: `electron js/electron.js "dev"`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js "dev"'.
              npm ERR! If you do, this is most likely a problem with the magicmirror package,
              npm ERR! not with npm itself.
              npm ERR!     electron js/electron.js "dev"
              npm ERR!     npm bugs magicmirror
              npm ERR! Or if that isn't available, you can get their info via:
              npm ERR!     npm owner ls magicmirror
              npm ERR!     /root/.npm/_logs/2017-02-24T09_43_49_882Z-debug.log
              how i do it with electron?
              • F Offline
                fischi87
                i found the mistake because of the black screen.
                i use the module Carousel and in this i didn’t change the module ‘email-mirror’ to ‘email’ because after installation the folders name is ‘email-mirror’ but u have to change this folder in /MagicMirror/modules to ‘email’ than it works.
                thanks
                  ronny3050 Module Developer @fischi87
                  @fischi87 said in email module black screen:
                  I apologize you had to figure this out the hard way, but the installation instructions clearly state this.
