    Mirror (2015) with PIR for the screen
    4 Posts 3 Posters 5.3k Views 3 Watching
      doubleT Module Developer
      Hi all,
      back in early 2015 I wanted to build a one way mirror with a screen behind it that showed a website from my server. I googled around and found Michael’s MagicMirror so I just went along with this, as it was the perfect solution.
      I still think this is one of the best uses for a RasbPi and this project absolutely deserved to win the award (number 1 in the MagPi Top 50).
      I had developed some apps for my version, like a fuel price monitor and a football board with results and tables.
      When some people asked me to set up mirrors for them I started to tinker with a small and easy backend for configuration and soon found out about MagicMirror². Now I’m here and I’ll use this new version and I’ll try to translate my apps into modules for this project.
      My mirror:
      alt text
      alt text
      Just stome minor style changes and I added an indoor temperature sensor at the bottom of the frame (see below).
      alt text
      Aral Ultimate 102 price monitor from the closest station.
      PIR:
      alt text
      Be careful when playing with 220V … I nearly killed myself after switching off the wrong circuit …
      alt text
      On the backside.
      Setup:
      alt text
      alt text
      The PIR is below the mirror, nearly unnoticeable. Here you can also see a DS18B20 temperature sensor.
      alt text
      The inside.
      I’m looking forward to setting up MM² on this setup in the next few days.
      1 Reply Last reply Reply Quote 8
      • yawnsY Offline
        yawns Moderator
        Now this is a sexy and clean mirror. Very good job
          SoleLo
          @doubleT very clean and simple. Love the look of it. What size monitor did you use?
            Thanks, guys. It’s a 27" screen.
