    IR Frame doesn't rotate
    24 Posts 7 Posters 22.2k Views 8 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @Snille
      @Snille did you ask the manufacturer?
      SnilleS 1 Reply Last reply Reply Quote 0
      • SnilleS Offline
        Snille Module Developer @strawberry 3.141
        @strawberry-3.141 Nope, not yet, not sure who to ask really… It’s even kind of hard to find the brand itself…
        It’s this one: https://www.aliexpress.com/item/32-points-32-Inch-IR-Multi-touch-overlay-kit-without-glass-for-Interactive-Table-Multi-Touch/1195149819.html
        The model number is at least: NECO-X
        Much more then that is hard to find… :)
        At least they have support for Linux as a HID compatible device (that should be enough I think).
        And it does work, just not in portrait… So, I’m thinking it got to be configurable on the “input-device” itself in rasbian… I just can’t find how. :)
          @Snille they advertise For vertical and horizontal installation screen so ask the seller how you can change this
          • SnilleS Offline
            @strawberry-3.141 Yes, I read that to, but it may also mean like vertical like a monitor (normal landscape) and horizontal like a table (but still in landscape). :)
              AlessandroRa @Snille
              @Snille Sorry, but I hade a few problems in these weeks, so I didn’t had the chance to fix it…
              I asked the manufacturer (thank you @cowboysdude!) and they did send me a driver, but they’ve sent it with 3 extensions: .pkg, .exe, .apk and I’ve no idea how to open them… I have Debian 8 Jessie, by the way.
              Any suggestions? :anguished:
              Y SnilleS 2 Replies Last reply Reply Quote 0
              • Y Offline
                yawns Moderator @AlessandroRa
                @AlessandroRa
                Hm, these are drivers for Mac (pkg), Android (apk), Windows (exe)
                Maybe you can extract the pkg file and gather the driver files?
                • SnilleS Offline
                  Snille Module Developer @AlessandroRa
                  @AlessandroRa Hi! Unfortunately the manufacturer do not have any drivers for ARM.
                  I ended up with using it as a normal “HID” device. I have to rotate the frame manually with this command in SSH: DISPLAY=:0.0 xinput --set-prop "Multi touch Multi touch overlay device" "Coordinate Transformation Matrix" 0 1 0 -1 0 1 0 0 1
                  But I cant get it to stick after reboot. So, I have to do it after every boot when everything has started.
                  I did not get the xinnput_calibration values to stick either. I’m in Rasbian Jessie Lite.
                  • cowboysdudeC Offline
                    cowboysdude Module Developer @Snille
                    @Snille said in IR Frame doesn’t rotate:
                    Write it in an .sh file and have it run everytime you boot up ;)
                      AlessandroRa @yawns
                      @yawns I tried, there’s no way to open it…
                      @Snille I’ve installed xinput_calibrator and I’ve just tried to start the mirror with the command you wrote, but it still doesn’t recognise the xinput command… How did you do it?
                      @cowboysdude smart move!
                      SnilleS 1 Reply Last reply Reply Quote 1
                      • SnilleS Offline
                        @AlessandroRa Just install xinput sudo apt-get install xinput
                        Then you are good to go. :)
                        @cowboysdude I have to know when to start the actual xinput command, I have tried in the “startup” for LXDE, with CRON and in “openbox”:es “statup”. For some reason I cant get it to “take”. I have not made a .sh file, true. But where / when to execute it? :)
                          @Snille
                          Edit the file:
                          sudo crontab -e
                          Add line to file (here a python script):
                          @reboot python3 /home/pi/Desktop/example.py &
                          SnilleS peemoellerP 2 Replies Last reply Reply Quote 0
                          • SnilleS Offline
                            Snille Module Developer @cowboysdude
                            @cowboysdude It worked when added to a sh script! Good call! :) Before I just tested with the xinput command directly in the autostart file, but that did not work. So now instead I just created a script called xin.sh.
                            nano ~/xin.sh
                            Then added
                            There should actually be 3 spaces between “Multi touch” and “Multi touch overlay device”. For some reason the board removes the extra spaces here.
                            You can actually find the “name” of the device with this command DISPLAY=:0.0 xinput list
                            Shows something like this:
                            ⎡ Virtual core pointer id=2 [master pointer (3)]
                            ⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
                            ⎜ ↳ Multi touch Multi touch overlay device id=6 [slave pointer (2)]
                            ⎣ Virtual core keyboard id=3 [master keyboard (2)]
                            ↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
                            Depending on what you have connected to your RPi. :)
                            So, after creating the xin.sh I added that to the autostart file for LXDE:
                            Like this:
                            nano ~/.config/lxsession/LXDE/autostart
                            Added at the end of the file.
                            @/home/pi/xin.sh
                            Restarted and it works. :)
                              @Snille Oddly enough you may have accidently solved my problem too! :) I’m getting a 32" IR touch frame… this may work for me as well!! So Thank you! :)
                              What kind of IR touch frame do you have and where did you get it?
                              Thanks!
                              • SnilleS Offline
                                @cowboysdude I bought this one: https://www.aliexpress.com/item/32-points-32-Inch-IR-Multi-touch-overlay-kit-without-glass-for-Interactive-Table-Multi-Touch/1195149819.html
                                And I can actually “zoom” the on the mirror (in the electron browser) which means that multitouch works (at least for two points). :)
                                  That’s AWESOME … Thank you soooooooooo much… That’s the one I am ordering too!! WOW that’s just amazing how things work out…
                                  What kind of glass did you get for it?
                                  • SnilleS Offline
                                    @cowboysdude Hehe, I’m still waiting for my mirror. Have not yet tested with any glass, just have it leaned against the monitor right now. :) I hope my work can supply a Pilkington MirrorView mirror, if not that’s what I’m going to buy.
                                      OH that’ll be very cool! I have a 7" touch clock and bathroom mirror already built. This is a 32" ‘command center’ for the house… so no mirror but as I have read I need to use tempered glass so when the frame comes in I’ll take it there and get the glass for it :)
                                      How long did it take to get after you ordered it?
                                      • SnilleS Offline
                                        @cowboysdude Actually it was quite fast only 8 days! :)
                                          @Snille I’m happy :) Thank you!
                                            spacevolt
                                            Hi guys!
                                            So I am ordering this one soon
                                            https://www.aliexpress.com/store/product/Free-Shipping-32-Infrared-Touch-screen-Frame-with-4-point-Touches-Quick-Response/922495_32752894952.html?spm=2114.12010612.0.0.F1YMw5
                                            Is it the same frame model as the one you guys got? (just smaller) Can one of you confirm? Excited to add touchscreen to the mirror! Thanks!
