    Throwing down the gauntlet
    85 Posts 11 Posters 117.1k Views 11 Watching
    • jproehlJ
      jproehl @Mykle1
      @Mykle1 and/or @strawberry-3.141:
      Great, thanks for the color update, I’ll try that in a minute.
      As for the current weather, I’ve been looking at the web page for MMM-WunderGround extensively. I don’t think all the changes I made to your current weather module call to WWW-WunderGround in your config.js were necessary, but I thought I should try to shut off ALL parameters that were possibly related to the forecast to see if I could get rid of that last line of header symbols used for the forecast. None did, because I still have those 3 icons (max thermometer, min thermometer and the umbrella) right below the current conditions icon and current temperature.
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @jproehl
        @jproehl
        Ok, well that is beyond me but I’ll go out on a limb here and say that Strawberry will be able to help you with that. That’s a custom.css thing and I do believe he is the resident expert. When he does fix it for you (because I am sure that he will) be sure to post the css entry so that I can see how it looks on mine. Right now, I sorta like the little icons
        jproehlJ 1 Reply Last reply
        • jproehlJ
          jproehl @Mykle1
          @Mykle1 and/or @strawberry-3-141:
          I suspect that Strawberry will straighten me out on this.Those additions to custom.css do not change my font colors. I wonder if I have an error somewhere that is interfering with the proper loading of the custom.css file. When I start the display, I see a flash of text, which I think lists node.js, that disappears very fast that might be an error message. But since it’s so fast I can’t tell.
          Mykle1M strawberry 3.141S 2 Replies Last reply
          • Mykle1M
            @jproehl
            Alright, I’ll check back in here to see how you make out. I’m interested in the outcome. I’m off to dinner right now
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @jproehl
              @jproehl
              .region.top.right .MMM-WunderGround table th {
              	display: none;
              Mykle1M jproehlJ 2 Replies Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @strawberry 3.141
                @strawberry-3.141
                Don’t know why, but I’m still amazed! Once again, Strawberry to the rescue!
                • jproehlJ
                  jproehl @strawberry 3.141
                  @strawberry-3.141 Hey, thanks for the reply. I’m not totally sure where to add that text, so I appended it to my custom.css file. But I don’t see any difference in the MagicMirror view.
                  Here are my custom.css and my config.js (with the appid’s removed). You’ll probably see what I’ve done wrong right away
                  ================== custom.css ==================
                  body {
                  .clock .time {
                  color: #99F;
                  .clock .date {
                  	color: #99F;
                  .calendar .header {
                  	color: #F00;
                  .newsfeed .title {
                  	color: #F00;
                  	font-size: large;
                  .MMM-WunderGround .max-temp {
                   color: #f66;
                  .MMM-WunderGround .min-temp {
                   color: #0ff;
                  .MMM-WunderGround .weather-icon {
                    color: #f93;
                  .MMM-WunderGround .day {
                    color: #6f6;
                  .region.top.center .MMM-WunderGround table.small {
                    display:none;
                  .region.top.right .MMM-WunderGround table:not(.small) {
                    display:none;
                  .region.top.right .MMM-WunderGround table.small td:nth-child(6) {
                    display:none;
                  display: none;
                  =================== config.js ==================
                  /* Magic Mirror Config Sample
                  • MIT Licensed.
                  var config = {
                  port: 8080,
                  ipWhitelist: [‘127.0.0.1’, ‘::ffff:127.0.0.1’, ‘::1’],
                  language: ‘en’,
                  timeFormat: 24,
                  units: ‘imperial’,
                  		module: 'alert',
                  		module: 'updatenotification',
                  		position: 'top_bar'
                  		module: 'clock',
                  		position: 'top_center'
                  		module: 'calendar',  // My Google Calendar
                  		header: 'My Calendar',
                  		position: 'top_left',
                  					symbol: 'calendar-check-o ',
                  					url: 'https://calendar.google.com/calendar/ical/japroehl%40gmail.com/private-xxx/basic.ics',
                  					maximumEntries: 15,
                  					timeformat: 'absolute',
                  					getrelative: 96,
                  					fadepoint: 0.9
                  		module: 'MMM-WunderGround',
                  		header: 'Current Weather in Cornish',
                  		position: 'top_center',
                  		apikey: '', // private; don't share!
                  		pws: 'NH/Cornish', //weather station
                  		currentweather: 1,
                  		coloricon: true,
                  		hourly: 0,
                  		fctext: 0,
                  		fcdaycount: 0,
                  		fcdaystart: 0,
                  		hourlyinterval: 0,
                  		hourlycount: 0,
                  		animationSpeed: 5000,
                  		alerttime: 10000,
                  		alerttruncatestring: 'english:',
                  		roundTmpDecs: 0,
                  		UseCardinals: 1,
                  		layout: 'vertical',
                  		windunits: 'mph',
                  		sysstat: 0
                  			header: 'Forecast for Cornish',
                  		position: 'top_right',
                  		currentweather: '0',
                  		coloricon: true,
                  		hourly: 0,
                  		fctext: 1,
                  		fcdaycount: 7,
                  		fcdaystart: 1,
                  		hourlyinterval: 6,
                  		hourlycount: 0,
                  		alerttime: 10000,
                  		roundTmpDecs: 0,
                  		UseCardinals: 1,
                  		layout: 'vertical',
                  		windunits: 'mph',
                  		sysstat: 0
                  		module: 'newsfeed',
                  		position: 'bottom_bar',
                  			feeds: [
                  					title: 'New York Times',
                  					url: 'http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml'
                  					title: 'BBC',
                  					url: 'http://feeds.bbci.co.uk/news/video_and_audio/news_front_page/rss.xml?edition=uk',
                  				showSourceTitle: true,
                  				showPublishDate: true
                  if (typeof module !== ‘undefined’) {module.exports = config;}
                  jproehlJ Mykle1M 2 Replies Last reply
                  • jproehlJ
                    jproehl @jproehl
                    @jproehl Don’t know why it split the code like that, but is it a sign? I posted all of this as a block of text (file upload wasn’t allowed to my new user). So does this splitting of the text suggest a bad formatting command in either or both files?
                    • Mykle1M
                      @jproehl said in Throwing down the gauntlet:
                      First, close out the body with a }
                      body  {
                      .clock .time {
                      color: #99F;
                      • jproehlJ
                        jproehl @Mykle1
                        @Mykle1 Doesn’t all of that text go within the body? There is a close } at the very end of the custom.css file that closes the body. Is that misplaced?
                        • Mykle1M
                          Nope. Before you paste code, simply put three back ticks It's under your tilde key, then close out the code with three more back ticks
                          • Mykle1M
                            No sir, not in this case. css is a bit different than config. That last } in your css is not doing anything. You can remove it. If you fixed the body and save the css file, you should see your changes after relaunching MM
                            • jproehlJ
                              jproehl @Mykle1
                              @Mykle1 Okay, thanks! I was way off! I made that change and now I get red text for the high temperature (so that’s progress, yea!!) but all the other stuff is still gray. I must still have some other syntax errors some where. Back to looking at the code …
                              • jproehlJ
                                jproehl @Mykle1
                                @Mykle1 Okay, I got it! I was missing a close bracket in my
                                definition, and fixing that fixed everything!! Even the line of icons in the current weather disappeared!!
                                Thank you so much!
                                • Mykle1M
                                  Thank you so much!
                                  Glad to be of service. I’m just paying back Strawberry’s kindness to me by helping
                                  • jproehlJ
                                    jproehl @Mykle1
                                    @Mykle1 Well, I applaud your efforts (it’s getting rarer in this messed up country) … I hope someday to figure this stuff out to a point where I can help another newbie. Thanks again!
                                    • Mykle1M
                                      New York City, USA. I’m just trying to be good representative of my city and country.
                                      Dude, one month ago I knew less than you, guaranteed. You will be helping others soon, guaranteed.
                                      Peace
                                      • Mykle1M
                                        Thank you so much!
                                        I just stole your coloring code for the date and time. haha, so thank you. See? You’re helping already. :thumbsup_tone1:
                                        • jproehlJ
                                          jproehl @Mykle1
                                          @Mykle1 Have at it! FYI: the one I can’t get to work is the .newsfeed .title I still get small letters in gray for “New York Times” and “BBC”. If I go into the main.css and change the color/size for “small” text, that works but hear that isn’t recommended since it will disappear if I update MagicMirror.
                                          • strawberry 3.141S
                                            @jproehl custom.css
                                            .newsfeed div.light.small.dimmed {
                                              color: #e54a1b;
                                              font-size: 9px;
                                            Mykle1M jproehlJ 3 Replies Last reply
                                            Reply Quote 3
                                            • 2 / 5
