    Throwing down the gauntlet
    85 Posts 11 Posters 117.1k Views 11 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @lolobyte
      @lolobyte no that’s all, you can combine selectors with a comma. the open bracket is in line 3 and the closing bracket in line 5
      it’s the short form for
      .region.top.center .MMM-WunderGround table.small {
        display:none;
      .region.top.right .MMM-WunderGround table:not(.small) {
        display:none;
      .region.top.right .MMM-WunderGround table.small td:nth-child(6) {
        display:none;
      L J 2 Replies Last reply
      • L
        lolobyte @strawberry 3.141
        @strawberry-3.141
        … and all for custom css i think!
        • jproehlJ
          jproehl
          Hi:
          Newbie here: I really like the design layout you’ve come up with - Kudos! However, can’t make heads or tails out of exactly what code I put where? Are the lines you list placed in config.js or in custom.css? If possible, can you post the part of your config.js and/or custom.css files (with appid and any other personal info erased, of course) that gives this display?
          Thanks!
          jproehl
          strawberry 3.141S Mykle1M 2 Replies Last reply
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @jproehl
            @jproehl all I posted here goes into the custom.css file
            jproehlJ 1 Reply Last reply
            • jproehlJ
              jproehl @strawberry 3.141
              @strawberry-3.141 What do you put into your config.js file?
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @jproehl
                @jproehl said in Throwing down the gauntlet:
                Thanks! It’s just how I pictured it, but it only happened through the goodwill of Strawberry 3.141
                • jproehlJ
                  jproehl @Mykle1
                  @Mykle1 and/or @strawberry-3.141: I’m still having problems getting things to look like Mykle’s. If I just put those 9 lines in my custom.css file and have no reference to the MMM-WunderGround module in my config.js file, I get nothing displayed for my weather info. Does this mean that the custom.css file isn’t being read? Do I have to place my custom.css file somewhere other than pi/MagicMirror/css/?
                  When I add references to the MMM-WunderGround module in config.js, I get the weather info, but I do not get the format you have. Presumably the parameters set in the module reference override the custom.css info in some way.
                  That’s why I was wondering what you have in your config.js file to initiate the MMM-WunderGround module.
                  Mykle1M 1 Reply Last reply
                  • Mykle1M
                    My design/layout ideas are in high demand. :thumbsup_tone1:
                    This is my entry in the config. Yes, there are 2 entries. One is for the current weather and one is for the weather forecast, only seperate and in different locations. You still have to enter what Strawberry told you to enter in your custom.css file. Then all should be well.
                        			module: 'MMM-WunderGround',
                        			position: 'top_center',
                            		apikey: 'YOUR API KEY', // private; don't share!
                            		pws: 'pws:KNYNEWYO103', // Richmondtown Weather Station - Very Cool
                    			currentweather: 1,
                            		coloricon: true,
                            		hourly: '0',
                            		fctext: '1',
                            		fcdaycount: "10",
                            		fcdaystart: "0",
                            		hourlyinterval: "2",
                            		hourlycount: "1",
                    			animationSpeed: 5000,
                            		alerttime: 10000,
                            		alerttruncatestring: "english:",
                        			roundTmpDecs: 0,
                        			UseCardinals: 1,
                        			layout: "vertical",
                    			windunits: "mph",
                        			sysstat: "0"
                        			position: 'top_right',
                            		apikey: 'YOUR API KEY AGAIN', // private; don't share!
                    			currentweather: 0,
                            		coloricon: true,
                            		hourly: '1',
                            		fctext: '1',
                            		fcdaycount: "10",
                            		fcdaystart: "1",
                            		hourlycount: "1",
                            		alerttime: 10000,
                        			roundTmpDecs: 0,
                        			UseCardinals: 1,
                        			layout: "vertical",
                    			windunits: "mph",
                        			sysstat: "0"
                    • jproehlJ
                      jproehl @Mykle1
                      @Mykle1 Thanks! I’m much closer. There are a couple of minor differences that I’m trying to ferret out:
                      1. I had to change a few lines in your module call to MMM-WunderGround for the current weather - I zeroed out the fctext, fcdaycount, hourlyinterval and hourlycount otherwise I got the forecast right below the current conditions in addition to the one at upper-right
                      2. Under my current conditions color icon/temperature, I see a line with two thermometers and an umbrella (i.e. the header for the forecasts) which I have no idea how to get rid of. I believe the changes I made under 1) should have removed any call for a forecast.
                      3. I do not get any color changes like you have in the forecast at the upper right. Did you have to change something else to get those?
                      Thanks a bunch!
                      Mykle1M J 3 Replies Last reply
                      • Mykle1M
                        This page will explain the effects of the individual config changes that you made.
                        https://github.com/RedNax67/MMM-WunderGround
                        • Mykle1M
                          This goes in your custom.css file for the coloring that I have. You can change the colors to your liking
                          .MMM-WunderGround .max-temp {
                            color: #f66;
                          .MMM-WunderGround .min-temp {
                            color: #0ff;
                          .MMM-WunderGround .weather-icon {
                            color: #f93;
                          .MMM-WunderGround .day {
                            color: #6f6;
                          • jproehlJ
                            jproehl @Mykle1
                            Great, thanks for the color update, I’ll try that in a minute.
                            As for the current weather, I’ve been looking at the web page for MMM-WunderGround extensively. I don’t think all the changes I made to your current weather module call to WWW-WunderGround in your config.js were necessary, but I thought I should try to shut off ALL parameters that were possibly related to the forecast to see if I could get rid of that last line of header symbols used for the forecast. None did, because I still have those 3 icons (max thermometer, min thermometer and the umbrella) right below the current conditions icon and current temperature.
                            • Mykle1M
                              @jproehl
                              Ok, well that is beyond me but I’ll go out on a limb here and say that Strawberry will be able to help you with that. That’s a custom.css thing and I do believe he is the resident expert. When he does fix it for you (because I am sure that he will) be sure to post the css entry so that I can see how it looks on mine. Right now, I sorta like the little icons
                              • jproehlJ
                                jproehl @Mykle1
                                @Mykle1 and/or @strawberry-3-141:
                                I suspect that Strawberry will straighten me out on this.Those additions to custom.css do not change my font colors. I wonder if I have an error somewhere that is interfering with the proper loading of the custom.css file. When I start the display, I see a flash of text, which I think lists node.js, that disappears very fast that might be an error message. But since it’s so fast I can’t tell.
                                Mykle1M strawberry 3.141S 2 Replies Last reply
                                • Mykle1M
                                  @jproehl
                                  Alright, I’ll check back in here to see how you make out. I’m interested in the outcome. I’m off to dinner right now
                                  • strawberry 3.141S
                                    @jproehl
                                    .region.top.right .MMM-WunderGround table th {
                                    	display: none;
                                    Mykle1M jproehlJ 2 Replies Last reply
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @strawberry 3.141
                                      @strawberry-3.141
                                      Don’t know why, but I’m still amazed! Once again, Strawberry to the rescue!
                                      • jproehlJ
                                        @strawberry-3.141 Hey, thanks for the reply. I’m not totally sure where to add that text, so I appended it to my custom.css file. But I don’t see any difference in the MagicMirror view.
                                        Here are my custom.css and my config.js (with the appid’s removed). You’ll probably see what I’ve done wrong right away
                                        ================== custom.css ==================
                                        body {
                                        .clock .time {
                                        color: #99F;
                                        .clock .date {
                                        	color: #99F;
                                        .calendar .header {
                                        	color: #F00;
                                        .newsfeed .title {
                                        	color: #F00;
                                        	font-size: large;
                                         color: #f66;
                                         color: #0ff;
                                          color: #f93;
                                          color: #6f6;
                                          display:none;
                                          display:none;
                                          display:none;
                                        display: none;
                                        =================== config.js ==================
                                        /* Magic Mirror Config Sample
                                        • MIT Licensed.
                                        var config = {
                                        port: 8080,
                                        ipWhitelist: [‘127.0.0.1’, ‘::ffff:127.0.0.1’, ‘::1’],
                                        language: ‘en’,
                                        timeFormat: 24,
                                        units: ‘imperial’,
                                        		module: 'alert',
                                        		module: 'updatenotification',
                                        		position: 'top_bar'
                                        		module: 'clock',
                                        		module: 'calendar',  // My Google Calendar
                                        		header: 'My Calendar',
                                        		position: 'top_left',
                                        					symbol: 'calendar-check-o ',
                                        					url: 'https://calendar.google.com/calendar/ical/japroehl%40gmail.com/private-xxx/basic.ics',
                                        					maximumEntries: 15,
                                        					timeformat: 'absolute',
                                        					getrelative: 96,
                                        					fadepoint: 0.9
                                        		header: 'Current Weather in Cornish',
                                        		apikey: '', // private; don't share!
                                        		pws: 'NH/Cornish', //weather station
                                        		currentweather: 1,
                                        		coloricon: true,
                                        		hourly: 0,
                                        		fctext: 0,
                                        		fcdaycount: 0,
                                        		fcdaystart: 0,
                                        		hourlyinterval: 0,
                                        		hourlycount: 0,
                                        		alerttime: 10000,
                                        		alerttruncatestring: 'english:',
                                        		roundTmpDecs: 0,
                                        		UseCardinals: 1,
                                        		layout: 'vertical',
                                        		windunits: 'mph',
                                        		sysstat: 0
                                        			header: 'Forecast for Cornish',
                                        		currentweather: '0',
                                        		coloricon: true,
                                        		hourly: 0,
                                        		fctext: 1,
                                        		fcdaycount: 7,
                                        		fcdaystart: 1,
                                        		hourlyinterval: 6,
                                        		hourlycount: 0,
                                        		alerttime: 10000,
                                        		roundTmpDecs: 0,
                                        		UseCardinals: 1,
                                        		layout: 'vertical',
                                        		windunits: 'mph',
                                        		sysstat: 0
                                        		module: 'newsfeed',
                                        		position: 'bottom_bar',
                                        			feeds: [
                                        					title: 'New York Times',
                                        					url: 'http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml'
                                        					title: 'BBC',
                                        					url: 'http://feeds.bbci.co.uk/news/video_and_audio/news_front_page/rss.xml?edition=uk',
                                        				showSourceTitle: true,
                                        				showPublishDate: true
                                        if (typeof module !== ‘undefined’) {module.exports = config;}
                                        jproehlJ Mykle1M 2 Replies Last reply
                                        • jproehlJ
                                          jproehl @jproehl
                                          @jproehl Don’t know why it split the code like that, but is it a sign? I posted all of this as a block of text (file upload wasn’t allowed to my new user). So does this splitting of the text suggest a bad formatting command in either or both files?
                                          • Mykle1M
                                            First, close out the body with a }
                                            body  {
                                            .clock .time {
                                            color: #99F;
                                            • 1 / 5
