    PIR Sensor turning display on/off over and over
    29 Posts 13 Posters 27.2k Views 13 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @elmerito25
      @elmerito25 I don’t have a mirror to test, but the code does the following
      from gpiozero import MotionSensor
      pir = MotionSensor(4)
      while True: #repeat this forever
          if pir.motion_detected: # if motion is detected print the message
              print("Motion detected!")
      after the print is done it immediately repeats the loop, because their is no sleep, timeout, delay or whatsoever in there. So for me the expected behaviour is that it prints over and over the same message. You could try to check motion not detected
      import time
          if not pir.motion_detected: # if no motion is detected print the message
              print("No motion detected!")
          time.sleep(1)
      run this and leave your sensor alone it will print just every second
      • H Offline
        hermlam
        I have the same issue. Maybe it’s related to WiFi. I tested the PIR with on older PI 2, no WiFi. Ran the Python script, working perfectly.
        After installing the PIR to my Mirror Pi, a Pi 3 screen wouldn’t go out. Installed the test Python script again and I am getting a lot of false positives, over 5 a minute. So PIR stays highs and screen stays on.
        I am thinking that WiFi is interfering with the PIR.
        Anybody any experiences or ideas?
        Thanks,
        Herman
        • F Offline
          fischi87
          by my mirror it works really nice. i have a question, it is possible the time to change right now it turns the display off after 4 minutes. i would like to change the time maybe 2 minutes or so.
          thanks
            Renfield
            It might be interference. Try installing a ferrite bead. The person whose site I’ve linked below had a very similar problem and describes how he fixed it.
            https://helentronica.com/2016/01/11/magic-mirror-with-motion-detector/
            Renfield
            cowboysdudeC johnnyboyJ 2 Replies Last reply Reply Quote 2
            • cowboysdudeC Offline
              cowboysdude Module Developer @Renfield
              @Renfield said in PIR Sensor turning display on/off over and over:
              Renfield
              It’s what I had to do with mine… they are very inexpensive…
              • E Offline
                elmerito25 @cowboysdude
                @cowboysdude said in PIR Sensor turning display on/off over and over:
                Renfield
                Thanks guys! Will try this once I get home tonight!
                E 1 Reply Last reply Reply Quote 1
                • E Offline
                  elmerito25 @elmerito25
                  @elmerito25 said in PIR Sensor turning display on/off over and over:
                  Renfield
                  Thanks @Renfield and @cowboysdude ! Followed your advice and found a ferrite bead on unused USB cable and got the PIR sensor working perfectly!
                    Renfield
                    Great to hear. I love it when a plan comes together.
                    Now I need to scrounge up a bead for my build.
                    Ren
                    • H Offline
                      hermlam
                      Hi all,
                      Thanks for the reactions. I ordered one and will test tomorrow.
                      Herman
                        cyberphox
                        i gave up on my PIR sensor cause this was happening to me…guess who is searching for a Ferrite bead tomorrow!!!
                        • johnnyboyJ Offline
                          johnnyboy @Renfield
                            phrazelle
                            FWIW, a ferrite bead is a working solution, but I was able to circumvent this issue by keeping the PIR Sensor a good distance from the Pi. Mine is about 3 feet away from the Pi and doesn’t act erratically as it did when it was right next to it during testing.
                            johnnyboyJ H 2 Replies Last reply Reply Quote 3
                              johnnyboy @phrazelle
                                Jay
                                Similar problem here, PIR works like a charm (tested with code of post #4) but after starting the MagicMirror the display is turned off and on over and over even though nothing is changed in front of the sensor. (I use MMM-PIR).
                                • H Offline
                                  hermlam @phrazelle
                                  @phrazelle Since I am having a ‘cordless’ mirror (power is coming from wall behind mirror) I don’t want to see cables to my mirror. I’ve build the PIR into the frame of my mirror.
                                  • H Offline
                                    hermlam
                                    Even with the bead installed I have various results. Sometimes it’s running ok for an hour or so, but most of the time I’m getting a lot of false positives. And very strange, only with the output timer (2nd yellow knob) on minimal it’s working ok. But then the screen lits up far too short. But output time has nothing to do with it?
                                      Jay
                                      Basically I had the same error with the display turning on and off over time. All in anger, I deinstalled the MagicMirror from the Pi and began at zero again.
                                      After updating and upgrading the Pi and installing the MagicMirror, a new try with the PIR-Module was iniciated. So I installed the PIR-Module and somehow noticed that my GPIO cables were wrong connected (ground connected to GPIO21 and vice-versa).
                                      So after this embarassing moment of disbelieve I changed the connections and checked if the sensor is working with a simple python script:
                                      import time
                                      pir = MotionSensor(21)
                                          time.sleep(1)
                                      Note that my pir is using GPIO21.
                                      With this script I tested the sensor and it worked like a charm, even though the sensor is placed 5 centimeters away from the raspberry pi 3 (with no case or even a bead installed).
                                      In the end, I only had to do a cd MagicMirror again, and install the MagicMirror:
                                      npm install. With this setup the MMM-PIR-module works magnificient.
                                        deepshades @Jay
                                        @Jay
                                        Hi Jay, can you reply a link to your PIR module you finaly use?
                                          Jay @deepshades
                                          @deepshades
                                          Basically its just the standard PIR-Sensor shipped with female to female gpio connections (PIR-Sensor Amazon).
                                            deepshades @Jay
                                            @Jay
                                            Ok, so you just use a script to let the sensor deactivate the hdmi output?
                                            Could you tell me the steps to let all work together?
