    MMM-Ruter (for Oslo and Akershus in Norway)
    34 Posts 13 Posters 34.2k Views 13 Watching
    • O Offline
      open_book
      Hi @Cato ,
      I’ve just updated with MM 2.1.0 and checked that I’m running the latest version of MMM-Ruter.
      When I tried to run the module with two different stops, it crashed the config file.
      ´´´´javascript´´´´
      module: ‘MMM-Ruter’,
      header: ‘Ruter’,
      position: ‘bottom_right’,
      showPlatform: true,
      maxItems: 10,
      stops: [
      stopId: “3010430”,
      platforms: [ “1”, “2” ],
      timetoThere: 2
      stopId: “3010425”,
      timetoThere: 2
      ´´´´javascript´´´´
      It runs fine with 1 stop. But I get a config error message with 2 stops. Even if I just copy the exact same information two times.
      Is there an error in the config above? Let me know!
      sudo insert motivational.quote
        Cato Module Developer @open_book
        @open_book Seems you are missing a comma between the stops.
        O 1 Reply Last reply Reply Quote 1
        • O Offline
          open_book @Cato
          @Cato yes. yes I am. Thanks. That’s it!
          • L Offline
            LincolnClay
            Hi @Cato. Great work on this very practical module.
            I am just getting into raspberry pi (3) and MM, so this is the first module i try to install. Unfortnatly when I run MM it goes black. I guess there is something with how I inserted the module in the config.js file.
            This is how I did it.
            Also this is what the terminal with the same config.js file.
            //pi@raspberrypi:~/MagicMirror $ npm start
            > magicmirror@2.1.0 start /home/pi/MagicMirror
            > electron js/electron.js
            Xlib:  extension "RANDR" missing on display ":1.0".
            Starting MagicMirror: v2.1.0
            Loading config ...
            Loading module helpers ...
            No helper found for module: MMM-Ruter.
            All module helpers loaded.
            Starting server op port 8080 ...
            Server started ...
            Starting module: newsfeed
            { Error: listen EADDRINUSE :::8080
                at Object.exports._errnoException (util.js:1026:11)
                at exports._exceptionWithHostPort (util.js:1049:20)
                at Server._listen2 (net.js:1253:14)
                at listen (net.js:1289:10)
                at net.js:1399:9
                at _combinedTickCallback (internal/process/next_tick.js:77:11)
                at process._tickCallback (internal/process/next_tick.js:98:9)
                at Module.runMain (module.js:592:11)
                at run (bootstrap_node.js:402:7)
                at startup (bootstrap_node.js:157:9)
              code: 'EADDRINUSE',
              errno: 'EADDRINUSE',
              syscall: 'listen',
              address: '::',
              port: 8080 }
            Xlib:  extension "XInputExtension" missing on display ":1.0".
            Launching application.
              Cato Module Developer @LincolnClay
              @LincolnClay The error indicates the port 8080 is in use. Did you install pm2? If so then Magic Mirror is already started when you run npm start. Just restart it with pm2 restart mm
              L 1 Reply Last reply Reply Quote 2
              • L Offline
                LincolnClay @Cato
                @Cato Thanks for the prompt response. Yes I installed pm2, but when run pm2 restart mm MM doesn’t open. I only get successful starts with npm start.
                If I delete the insertion in config.js file from your module, mm starts normally without being all black. Do you spot any other errors?
                  @LincolnClay Well, I still don’t think it’s the module’s fault. I tried to replicate your exact configuration and it works.
                  What output do you get from npm start?
                  • L Offline
                    LincolnClay @Cato
                    @Cato I’m sorry for the late reply, I had to figure out if there was any issues with my initial MM install. You where absolutely right, the issue had nothing to do with the module. I did a re-install and now the module works perfectly. Thanks for your help and your work on this module :)
                    • L Offline
                      laumb
                      How do I get rid of this?
                      strawberry 3.141S C 2 Replies Last reply Reply Quote 0
                      • strawberry 3.141S Offline
                        strawberry 3.141 Project Sponsor Module Developer @laumb
                        @laumb cd ~/MagicMirror/modules/MMM-Ruter then git pull
                          Cato Module Developer @laumb
                          @laumb you have to run git pull in the modules directory.
                          This is described in the Readme on GitHub.
                          • KimzerK Offline
                            Kimzer
                            Any chance you could possibly do this to support Skyss in bergen aswell? Would be really great!
                              Cato Module Developer @Kimzer
                              @Kimzer I’m sorry, but I only make modules I need myself. If I move to Bergen, I let you know… ;-)
                              I did though do a quick search and it doesn’t seem that Skyss has any public API. Found a couple of unofficial/depricated onces, but that is not something I would support anyway…
                                amomat @Cato
                                Hi @Cato. Did something regarding the time change in the last update? Upgraded today and time format is set to 12 instead of 24 as it was before.
                                This is what is in my config file (have not changed that recently)
                                language: 'en',
                                timeFormat: 24,
                                units: 'metric',
                                  Cato Module Developer @amomat
                                  @amomat I have done nothing, and I can’t remember noticing that since I only use public transport in the morning. I will take a look tonight to make sure.
                                    DeeWoo
                                    Hi @Cato. I’ve just installed your MMM-Ruter module, and I’m having issues with the time, it’s 12-hour…My Pi is 24 hour, my config is 24 hour…but the MMM-Ruter is 12 hour.
                                    language: "nb",
                                    timeFormat: 24,
                                    units: "metric",
                                    pi@MagicMirror_1:~/MagicMirror/config $ date
                                    Sun 13 Aug 15:26:42 CEST 2017
                                    Any idea how to fix this? :)
                                      Cato Module Developer @DeeWoo
                                      Think I found the “bug” (oversight from my end). New version is now available.
                                      D 1 Reply Last reply Reply Quote 2
                                        DeeWoo @Cato
                                        @Cato said in MMM-Ruter (for Oslo and Akershus in Norway):
                                        Just wanted to thank you for the lightning fast response!
                                        Now it shows 24h time. Cheers :)
                                        • K Offline
                                          kj3rra
                                          Hei Cato!
                                          Great work with the this module. I have two problems:
                                          1. I cant get several stops on Frognerseterbanen (linje 1) to work (Vinderen (3012315), Gaustad (3012320) etc). It stops at ‘Loading’. Im trying in particular to get Vinderen T-bane. I have no other problems getting times from other stops, such as buses etc. Please see picture.
                                          2. How do I change the dimmed light on the time-text to be bright. Ive been through alle the files, but I cant find where you can change this. Im really quite new to this, but Ive managed to change text size and ‘dimmness’ on all other modules.
                                          Would be glad if you could help with these two! Thanks!
                                            jonaslaeret @kj3rra
                                            @kj3rra Did you manage to get those stops to work? I’m having the same problem. Some stops are working, but Vogts gate and Torshovparken recently (a couple of months ago) stopped working. Before that they were fine. I checked that the stop ID didn’t change.
