    Splash Screens/No Signal
    6 Posts 6 Posters 3.7k Views 6 Watching
      steve23p9835908
      I’ve searched through the forums and not managed to find an answer. I’m looking to pick up a second hand monitor (they seem cheaper than TVs) and I’d like to use a PIR sensor to turn the monitor on and off. However, when the HDMI output of the Pi is turned off, won’t the monitor display a “No SIgnal” message or even a company splash screen?
      Can anyone confirm whether this is a genuine concern and, if so, how to avoid it?
      Thanks for your help,
      Steve
      FlatPepsiF M 2 Replies Last reply Reply Quote 0
      • FlatPepsiF Offline
        FlatPepsi @steve23p9835908
        @steve23p9835908 depends on your monitor. For most, the pi sends a “power off” signal, and you get no message.
        Really, you gotta play worth the parts you have to see how it works.
          MyMirror @steve23p9835908
          @steve23p9835908
          Hi Steve,
          did you find one?
          I’ve got the same problem …
          Thanks MyMirror
            doubleT Module Developer
            I used a BenQ and it had the option to disable the splashscreen. I’d suggest using Google for the monitor you’re looking at + “disable splash screen” or something like that, quite a lot of monitors have these options. I’d also suggest checking the power consumption.
            I used a PIR sensor to switch the monitor independently from the RasPi while the RasPi is running 24/7. Mainly because my RasPi is collecting data every 2 hours and writing it to a JSON that I want to be updated without interuption. The other reason was the screens power consumption in standby (I’m not at home for at least 10 hours every day and sleeping ~ 7 hours, so that’s min 17 hours standby every day) and the screen takes ~ 3 or 4 seconds to turn on while the RasPi takes quite a bit longer to start.
            Just be careful when selecting and setting up that PIR sensor with a switch for the monitor, not a lot are suitable for that power consumption and load and setting it up means working with the 220 V cable (or whatever voltage your country might have) – if you’re not sure what needs to be done, let a professional handle that. (Trust me, I learned the hard way …)
              Peter
              Did anybody find a way to disable the “no signal” or “hdmi1” or “analog” messages of a monitor?
              I have a Samsung 2231; it works fine with a pir, but only this stupid message …
              Peter
                AxLed Module Developer
                i had a similar issue, connecting RPI with HDMI vs. VGA had different behavior.
                To get my PIR working the way i want it, i had to use a HDMI->VGA Adapter and connected the display by VGA. Dont worry, VGA also supports FullHD Resolution.
                See alse: https://forum.magicmirror.builders/topic/6410/which-monitor-supports-standby-sleep-poweroff-wakeup-via-vga-hdmi-commands
