    need help with config file
    17 Posts 7 Posters 27.2k Views 7 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      You might want to read the README on the module:
      https://github.com/MichMich/MagicMirror/tree/master/modules/default/currentweather
      Basically, you need to go get your own API key for that to work.
        abdullah
        Thanks! could you tell me how to fix the time? for some odd reason the time is different.
        • KirAsh4K Offline
          KirAsh4 Moderator
          Which time? What’s displayed above the weather portion isn’t the current time, it’s showing you when the sun sets or rises.
          • csdesign3C Offline
            csdesign3 @Mate3
            @Mate3 How about to edit the config.js file. I’ve tried to acess but i cant.
              Mykle1 Project Sponsor Module Developer @csdesign3
              @csdesign3
              I was just like you a few weeks ago. I didn’t know a thing about this, or coding. A complete noob, as they say. My suggestion, because it helped me, is, don’t do your editing in the terminal. Do it in the graphical user interface (GUI). Navigate your desktop as you would on a PC with Windows or a Mac’s Finder.
              Click on File Manager (the folder at the top left of your desktop, usually)
              Double click the MagicMirror folder
              Double click the config folder
              Right click the config.js.sample file - select Copy
              Right click again somewhere else in that same window - select Paste
              Rename the file to config.js and click the Rename button
              The new config.js file that you just pasted is now your working config file for MagicMirror
              Double click it and it should open in a text editor.
              This is one of the places where you will customize your MM. It’s actually good enough to run your MM, although it will only show some of the modules but you’ll be encouraged by the fact that it is at least working. Every module folder has a ReadMe file that instructs you on what to add to your config.js file to get that module up and running.
              I think that’s good for now. If you want to run MM right now to see how your new config.js is working you will have to go back to the terminal. Do this:
              Open a new terminal
              type cd MagicMirror
              then type npm start
              Sit back and watch the magic happen. When you calm down after a minute or two of watching your MM actually working and you want to quit MM, press the Option key on your keyboard. Select QUIT from File menu that appears, top left of your screen
              csdesign3C D 3 Replies Last reply Reply Quote 1
                csdesign3 @Mykle1
                @Mykle1 I there
                From 2 days of exploring i’m feeling more confortable playing with config.js via SSH. Yesterday i feel very lost because my inexperience with comand line in linux, but reading some forums here and there and with some help from varius users.
                Right now i have the Magic Mirror Running with any major problems. My concern is, i’ve doing something wrong, because PM2 doesn’t autorun at boot of raspberry, and i i have to have the graphical Debian running to MagicMirror showing of, but far from there it’s just acess SSH and pm2 start mm.sh and it runs without problem.
                Right now i’m looking the best way to:
                • Know all possible locations of content in screen (Top_left, top, right, bottom… etc);
                • The best way to transfer files (jpg, txt, etc), usb flash drive is not a option, because in the future the display and raspberry will be placed in a wall without direct easy acess;
                • Find more modules to: slide show images or videos.
                thanks again for the help :-)
                best regards carlos
                  dmrowe84 @Mykle1
                  @Mykle1 I’m trying to make a MM for my wife, I’ve got everything ok, except the weather module, it just doesn’t show up on the screen, I’ve input my aapid and location id, and still won’t show. I’m in the middle of wiping and reflashing it now, was wondering if I could contact you with any questions of it still doesn’t work after this reflash, or with you had any advice?
                    Mykle1 Project Sponsor Module Developer @dmrowe84
                    @dmrowe84 said in need help with config file:
                    Don’t wipe and reflash every time a module doesn’t work. Most likely you could have gotten help here on the forums. So, ask first before you take that step again. :-)
                    Sure, this is the place to ask your questions and get answers. If I can’t help you, there are many helpful people here that can, and will. :-)
                      dmrowe84 @Mykle1
                        thank you for your help in advance!
                        I don’t use those modules but this should help you
                        location: requires state and country, or city and country, something like that
                        You have a URL in the appid: option. Just put in the long ID number, not the entire url.
                        Put your locationID in your currentweather also. I believe this overrides location anyway
                        Make sure your numbers are correct! Sample below:
                        locationID: "12345", //Location ID from http://openweathermap.org/help/city_list.txt
                        appid: "abcde12345abcde12345abcde12345ab"
                        You can delete your last post that contains your ID’s. At the very bottom right of the post are three vertical dots. Click on that and choose delete
