    How do you turn Off/On the monitor if not in use - Be Green
    24 Posts 9 Posters 22.4k Views 9 Watching
    • mpiresM
      mpires @Steff
      @Steff ty Steff, i did order today my PIR.
      • W
        wizz
        I got an solution that i like and hope will work good for me.
        I am waiting for my Alexa Dot to arrive and when it dose i will use this to shut down the power to the monitor with the implementation for my Vera edge and a wall plug just telling the Alexa to shut down the monitor and also by command start up the monitor i rely hope that works as for the RPI i let it to be powered on like @broberg mentioned.
        So just waiting for the Alexa to drop down in the mail :)
        Z 1 Reply Last reply Reply Quote 0
        • Z
          zam @wizz
          @wizz , I have already done this using an Echo Dot & 5V 4-Channel Wifi Relay module for Arduino LinkNode R4 with couple of coding i made a voice activated power extension plug :) it’s working fine for me !
          • W
            wizz
            @zam Do you want to explain the setup and the coding pleas?
            • Z
              zam @wizz
              @wizz Unfortunately i didn’t documented yet once i done ill update it , i try to upload a demo video though… but it says maximum size should be 2048 Kb .
              • W
                wizz
                @zam Post the video on Youtube and link to it in your answer.
                • Z
                  zam @wizz
                  @wizz you can check the tutorial video on https://www.youtube.com/watch?v=t5QEt-vX5Ng&t=2s a guy call Charles did an wonderful job hope it will help you .
                  • W
                    wizz
                    @zam Thanks will have a look at it.
                      cyberphox
                      Mirror is plugged into a Z-wave outlet. I just tell my echo - Hey Alexa - turn on/off my mirror
                      • W
                        wizz
                        @cyberphox that is what I was looking for and want to do with my mirror.
                          cyberphox
                          I have a Vera controller for Zwave devices and they just released a new firmware that adds Alex support pretty easy!
                          • W
                            wizz
                            @cyberphox said in How do you turn Off/On the monitor if not in use - Be Green:
                            new firmware
                            @cyberphox any link to the new firmware ? Pleas share it.
                              cyberphox @wizz
                              @wizz
                              http://support.getvera.com/customer/en/portal/articles/2729880
                              • W
                                wizz
                                @cyberphox Thanks will check that tonight.
