    How do you turn Off/On the monitor if not in use - Be Green
    24 Posts 9 Posters 22.2k Views 9 Watching
      Steff
      I am using a “dual” solution: I do use a PIR sensor together with the MMM-PIR module to switch the monitor to standby via HDMI off. Since the Raspi and the monitor are still consuming energy, I thought about when I do really use my MagicMirror. So I came to the conclusion that I never use and need my MM during night and during my working hours in the week. So I bought a rather cheap clock timer with the capability to program it per day. Every day the MM is switched completely off during night time and every work day during my work time. In order to prevent any potential SD card failure I do use the module MMM-Scheduler to shut down the Raspi well in advance before power is cut. If there is interest I can post the configuration of MMM-Scheduler.
      johnnyboyJ mpiresM 2 Replies Last reply Reply Quote 1
      • johnnyboyJ Offline
        johnnyboy @Steff
        @Steff
        The PIR sensor and MMM-PIR Module is on my list as soon as I read up more about them, so I for one would be gratefull if you could post the scheduler config… I want to see if I can mange the set up as smoothly as possible… hence why I want to read up as many posts about it here and in other posts.
        Thanks.
        • mpiresM Offline
          mpires @Steff
          @Steff Sure Steff, post the Scheduler configuration.
            Steff
            @mpires
            Here is the configuration:
                            module: 'MMM-ModuleScheduler',
                            notification_schedule: [
                                            // TURN THE MONITOR/SCREEN OFF AT 8:30 EVERY WEEK DAY
                                            {notification: 'REMOTE_ACTION', schedule: '30 8 * * MON-FRI', payload: {action: "SHUTDOWN"}},
                                            // TURN THE MONITOR/SCREEN OFF AT 23:30 EVERY DAY
                                            {notification: 'REMOTE_ACTION', schedule: '30 23 * * *', payload: {action: "SHUTDOWN"}},
            The clock timer is programmed to kill the power supply 15 min later than the shutdown time(s).
            mpiresM 1 Reply Last reply Reply Quote 1
            • mpiresM Offline
              mpires @Steff
              @Steff ty Steff, i did order today my PIR.
              • W Offline
                wizz
                I got an solution that i like and hope will work good for me.
                I am waiting for my Alexa Dot to arrive and when it dose i will use this to shut down the power to the monitor with the implementation for my Vera edge and a wall plug just telling the Alexa to shut down the monitor and also by command start up the monitor i rely hope that works as for the RPI i let it to be powered on like @broberg mentioned.
                So just waiting for the Alexa to drop down in the mail :)
                Z 1 Reply Last reply Reply Quote 0
                • Z Offline
                  zam @wizz
                  @wizz , I have already done this using an Echo Dot & 5V 4-Channel Wifi Relay module for Arduino LinkNode R4 with couple of coding i made a voice activated power extension plug :) it’s working fine for me !
                  • W Offline
                    wizz
                    @zam Do you want to explain the setup and the coding pleas?
                    • Z Offline
                      zam @wizz
                      @wizz Unfortunately i didn’t documented yet once i done ill update it , i try to upload a demo video though… but it says maximum size should be 2048 Kb .
                      • W Offline
                        wizz
                        @zam Post the video on Youtube and link to it in your answer.
                        • Z Offline
                          zam @wizz
                          @wizz you can check the tutorial video on https://www.youtube.com/watch?v=t5QEt-vX5Ng&t=2s a guy call Charles did an wonderful job hope it will help you .
                          • W Offline
                            wizz
                            @zam Thanks will have a look at it.
                              cyberphox
                              Mirror is plugged into a Z-wave outlet. I just tell my echo - Hey Alexa - turn on/off my mirror
                              • W Offline
                                wizz
                                @cyberphox that is what I was looking for and want to do with my mirror.
                                  cyberphox
                                  I have a Vera controller for Zwave devices and they just released a new firmware that adds Alex support pretty easy!
                                  • W Offline
                                    wizz
                                    @cyberphox said in How do you turn Off/On the monitor if not in use - Be Green:
                                    new firmware
                                    @cyberphox any link to the new firmware ? Pleas share it.
                                      cyberphox @wizz
                                      @wizz
                                      http://support.getvera.com/customer/en/portal/articles/2729880
                                      • W Offline
                                        wizz
                                        @cyberphox Thanks will check that tonight.
