    How do you turn Off/On the monitor if not in use - Be Green
    24 Posts 9 Posters 21.9k Views 9 Watching
    • mpiresM Offline
      mpires @Steff
      @Steff Sure Steff, post the Scheduler configuration.
        Steff
        @mpires
        Here is the configuration:
                        module: 'MMM-ModuleScheduler',
                        notification_schedule: [
                                        // TURN THE MONITOR/SCREEN OFF AT 8:30 EVERY WEEK DAY
                                        {notification: 'REMOTE_ACTION', schedule: '30 8 * * MON-FRI', payload: {action: "SHUTDOWN"}},
                                        // TURN THE MONITOR/SCREEN OFF AT 23:30 EVERY DAY
                                        {notification: 'REMOTE_ACTION', schedule: '30 23 * * *', payload: {action: "SHUTDOWN"}},
        The clock timer is programmed to kill the power supply 15 min later than the shutdown time(s).
        mpiresM 1 Reply Last reply Reply Quote 1
        • mpiresM Offline
          mpires @Steff
          @Steff ty Steff, i did order today my PIR.
          • W Offline
            wizz
            I got an solution that i like and hope will work good for me.
            I am waiting for my Alexa Dot to arrive and when it dose i will use this to shut down the power to the monitor with the implementation for my Vera edge and a wall plug just telling the Alexa to shut down the monitor and also by command start up the monitor i rely hope that works as for the RPI i let it to be powered on like @broberg mentioned.
            So just waiting for the Alexa to drop down in the mail :)
            Z 1 Reply Last reply Reply Quote 0
            • Z Offline
              zam @wizz
              @wizz , I have already done this using an Echo Dot & 5V 4-Channel Wifi Relay module for Arduino LinkNode R4 with couple of coding i made a voice activated power extension plug :) it’s working fine for me !
              • W Offline
                wizz
                @zam Do you want to explain the setup and the coding pleas?
                • Z Offline
                  zam @wizz
                  @wizz Unfortunately i didn’t documented yet once i done ill update it , i try to upload a demo video though… but it says maximum size should be 2048 Kb .
                  • W Offline
                    wizz
                    @zam Post the video on Youtube and link to it in your answer.
                    • Z Offline
                      zam @wizz
                      @wizz you can check the tutorial video on https://www.youtube.com/watch?v=t5QEt-vX5Ng&t=2s a guy call Charles did an wonderful job hope it will help you .
                      • W Offline
                        wizz
                        @zam Thanks will have a look at it.
                          cyberphox
                          Mirror is plugged into a Z-wave outlet. I just tell my echo - Hey Alexa - turn on/off my mirror
                          • W Offline
                            wizz
                            @cyberphox that is what I was looking for and want to do with my mirror.
                              cyberphox
                              I have a Vera controller for Zwave devices and they just released a new firmware that adds Alex support pretty easy!
                              • W Offline
                                wizz
                                @cyberphox said in How do you turn Off/On the monitor if not in use - Be Green:
                                new firmware
                                @cyberphox any link to the new firmware ? Pleas share it.
                                  cyberphox @wizz
                                  @wizz
                                  http://support.getvera.com/customer/en/portal/articles/2729880
                                  • W Offline
                                    wizz
                                    @cyberphox Thanks will check that tonight.
