    How do you turn Off/On the monitor if not in use - Be Green
    24 Posts 9 Posters 22.4k Views 9 Watching
    • mpiresM
      mpires
      alt text
      So after read so many post, i would like know how you turn Off/On your monitor when you are not using.
      I can’t decide what is the best way to do this, after all i think we must be green and save some energy ;)
      My idea is to active MM once someone get in front of the MM, then turn off the monitor to save some power, for this i think that PIR is the way to go, by power on/off the HDMI.
      ( was the solution i found on the forum that seems to work ok. )
      Be free to tell how did you became green with your MM, i’m sure this is a topic that most of us are interested.
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @mpires
        @mpires with voice control
          broberg Project Sponsor
          Just a thought, does the PIR cut the power entirely or does it just set the monitor to standby?
          I don’t really care about the small amount that electronic devices use in standby, but to be truly green you should really cut the power entirely to the monitor.
          Y mpiresM 2 Replies Last reply Reply Quote 0
          • Y
            yawns Moderator @broberg
            @broberg
            You are right. Using the PIR to power down the HDMI puts your screen to standby.
            You could of course use a relais and completely switch off/on the power supply to your screen. However this would cause delays when the screen is powered again and needs to start. In addition I don’t know how long the display and the display board would survive being switched on and off constantly
            mpiresM 1 Reply Last reply Reply Quote 0
            • mpiresM
              mpires @yawns
              @yawns said in How do you turn Off/On the monitor if not in use - Be Green:
              art. In
              I agree, but the other problem i see with relay, is that you will be able to cut the energy, but once you order to power on, monitor will need human action to press power button :(
              • mpiresM
                mpires @broberg
                @broberg
                The test i did with my LG monitor, was using remote module i did turn Monitor OFF, and my monitor will enter in standby after 2 sec, so i think that i can set the PIR to once detect movement will trigger the monitor to ON, and after X sec, if no movement is detect turn monitor OFF.
                  Steff
                  I am using a “dual” solution: I do use a PIR sensor together with the MMM-PIR module to switch the monitor to standby via HDMI off. Since the Raspi and the monitor are still consuming energy, I thought about when I do really use my MagicMirror. So I came to the conclusion that I never use and need my MM during night and during my working hours in the week. So I bought a rather cheap clock timer with the capability to program it per day. Every day the MM is switched completely off during night time and every work day during my work time. In order to prevent any potential SD card failure I do use the module MMM-Scheduler to shut down the Raspi well in advance before power is cut. If there is interest I can post the configuration of MMM-Scheduler.
                  johnnyboyJ mpiresM 2 Replies Last reply Reply Quote 1
                  • johnnyboyJ
                    johnnyboy @Steff
                    @Steff
                    The PIR sensor and MMM-PIR Module is on my list as soon as I read up more about them, so I for one would be gratefull if you could post the scheduler config… I want to see if I can mange the set up as smoothly as possible… hence why I want to read up as many posts about it here and in other posts.
                    Thanks.
                    • mpiresM
                      mpires @Steff
                      @Steff Sure Steff, post the Scheduler configuration.
                        Steff
                        @mpires
                        Here is the configuration:
                                        module: 'MMM-ModuleScheduler',
                                        notification_schedule: [
                                                        // TURN THE MONITOR/SCREEN OFF AT 8:30 EVERY WEEK DAY
                                                        {notification: 'REMOTE_ACTION', schedule: '30 8 * * MON-FRI', payload: {action: "SHUTDOWN"}},
                                                        // TURN THE MONITOR/SCREEN OFF AT 23:30 EVERY DAY
                                                        {notification: 'REMOTE_ACTION', schedule: '30 23 * * *', payload: {action: "SHUTDOWN"}},
                        The clock timer is programmed to kill the power supply 15 min later than the shutdown time(s).
                        mpiresM 1 Reply Last reply Reply Quote 1
                        • mpiresM
                          mpires @Steff
                          @Steff ty Steff, i did order today my PIR.
                          • W
                            wizz
                            I got an solution that i like and hope will work good for me.
                            I am waiting for my Alexa Dot to arrive and when it dose i will use this to shut down the power to the monitor with the implementation for my Vera edge and a wall plug just telling the Alexa to shut down the monitor and also by command start up the monitor i rely hope that works as for the RPI i let it to be powered on like @broberg mentioned.
                            So just waiting for the Alexa to drop down in the mail :)
                            Z 1 Reply Last reply Reply Quote 0
                            • Z
                              zam @wizz
                              @wizz , I have already done this using an Echo Dot & 5V 4-Channel Wifi Relay module for Arduino LinkNode R4 with couple of coding i made a voice activated power extension plug :) it’s working fine for me !
                              • W
                                wizz
                                @zam Do you want to explain the setup and the coding pleas?
                                • Z
                                  zam @wizz
                                  @wizz Unfortunately i didn’t documented yet once i done ill update it , i try to upload a demo video though… but it says maximum size should be 2048 Kb .
                                  • W
                                    wizz
                                    @zam Post the video on Youtube and link to it in your answer.
                                    • Z
                                      zam @wizz
                                      @wizz you can check the tutorial video on https://www.youtube.com/watch?v=t5QEt-vX5Ng&t=2s a guy call Charles did an wonderful job hope it will help you .
                                      • W
                                        wizz
                                        @zam Thanks will have a look at it.
                                          cyberphox
                                          Mirror is plugged into a Z-wave outlet. I just tell my echo - Hey Alexa - turn on/off my mirror
                                          • W
                                            wizz
                                            @cyberphox that is what I was looking for and want to do with my mirror.
