    How do you turn Off/On the monitor if not in use - Be Green
    24 Posts 9 Posters 22.3k Views 9 Watching
    • Y
      yawns Moderator @broberg
      @broberg
      You are right. Using the PIR to power down the HDMI puts your screen to standby.
      You could of course use a relais and completely switch off/on the power supply to your screen. However this would cause delays when the screen is powered again and needs to start. In addition I don’t know how long the display and the display board would survive being switched on and off constantly
      mpiresM 1 Reply Last reply Reply Quote 0
      • mpiresM
        mpires @yawns
        @yawns said in How do you turn Off/On the monitor if not in use - Be Green:
        art. In
        I agree, but the other problem i see with relay, is that you will be able to cut the energy, but once you order to power on, monitor will need human action to press power button :(
        • mpiresM
          mpires @broberg
          @broberg
          The test i did with my LG monitor, was using remote module i did turn Monitor OFF, and my monitor will enter in standby after 2 sec, so i think that i can set the PIR to once detect movement will trigger the monitor to ON, and after X sec, if no movement is detect turn monitor OFF.
            Steff
            I am using a “dual” solution: I do use a PIR sensor together with the MMM-PIR module to switch the monitor to standby via HDMI off. Since the Raspi and the monitor are still consuming energy, I thought about when I do really use my MagicMirror. So I came to the conclusion that I never use and need my MM during night and during my working hours in the week. So I bought a rather cheap clock timer with the capability to program it per day. Every day the MM is switched completely off during night time and every work day during my work time. In order to prevent any potential SD card failure I do use the module MMM-Scheduler to shut down the Raspi well in advance before power is cut. If there is interest I can post the configuration of MMM-Scheduler.
            johnnyboyJ mpiresM 2 Replies Last reply Reply Quote 1
            • johnnyboyJ
              johnnyboy @Steff
              @Steff
              The PIR sensor and MMM-PIR Module is on my list as soon as I read up more about them, so I for one would be gratefull if you could post the scheduler config… I want to see if I can mange the set up as smoothly as possible… hence why I want to read up as many posts about it here and in other posts.
              Thanks.
              • mpiresM
                mpires @Steff
                @Steff Sure Steff, post the Scheduler configuration.
                  Steff
                  @mpires
                  Here is the configuration:
                                  module: 'MMM-ModuleScheduler',
                                  notification_schedule: [
                                                  // TURN THE MONITOR/SCREEN OFF AT 8:30 EVERY WEEK DAY
                                                  {notification: 'REMOTE_ACTION', schedule: '30 8 * * MON-FRI', payload: {action: "SHUTDOWN"}},
                                                  // TURN THE MONITOR/SCREEN OFF AT 23:30 EVERY DAY
                                                  {notification: 'REMOTE_ACTION', schedule: '30 23 * * *', payload: {action: "SHUTDOWN"}},
                  The clock timer is programmed to kill the power supply 15 min later than the shutdown time(s).
                  mpiresM 1 Reply Last reply Reply Quote 1
                  • mpiresM
                    mpires @Steff
                    @Steff ty Steff, i did order today my PIR.
                    • W
                      wizz
                      I got an solution that i like and hope will work good for me.
                      I am waiting for my Alexa Dot to arrive and when it dose i will use this to shut down the power to the monitor with the implementation for my Vera edge and a wall plug just telling the Alexa to shut down the monitor and also by command start up the monitor i rely hope that works as for the RPI i let it to be powered on like @broberg mentioned.
                      So just waiting for the Alexa to drop down in the mail :)
                      Z 1 Reply Last reply Reply Quote 0
                      • Z
                        zam @wizz
                        @wizz , I have already done this using an Echo Dot & 5V 4-Channel Wifi Relay module for Arduino LinkNode R4 with couple of coding i made a voice activated power extension plug :) it’s working fine for me !
                        • W
                          wizz
                          @zam Do you want to explain the setup and the coding pleas?
                          • Z
                            zam @wizz
                            @wizz Unfortunately i didn’t documented yet once i done ill update it , i try to upload a demo video though… but it says maximum size should be 2048 Kb .
                            • W
                              wizz
                              @zam Post the video on Youtube and link to it in your answer.
                              • Z
                                zam @wizz
                                @wizz you can check the tutorial video on https://www.youtube.com/watch?v=t5QEt-vX5Ng&t=2s a guy call Charles did an wonderful job hope it will help you .
                                • W
                                  wizz
                                  @zam Thanks will have a look at it.
                                    cyberphox
                                    Mirror is plugged into a Z-wave outlet. I just tell my echo - Hey Alexa - turn on/off my mirror
                                    • W
                                      wizz
                                      @cyberphox that is what I was looking for and want to do with my mirror.
                                        cyberphox
                                        I have a Vera controller for Zwave devices and they just released a new firmware that adds Alex support pretty easy!
                                        • W
                                          wizz
                                          @cyberphox said in How do you turn Off/On the monitor if not in use - Be Green:
                                          new firmware
                                          @cyberphox any link to the new firmware ? Pleas share it.
                                            cyberphox @wizz
                                            @wizz
                                            http://support.getvera.com/customer/en/portal/articles/2729880
