    Try to update a module
    4 Posts 2 Posters 3.3k Views 2 Watching
    • F Offline
      Fonfon
      HI
      when i try to update a module ‘MMM-Traffic’
      i go in cd MagicMirror/modules/MMM-Traffic
      and i do ‘git pull’
      i have a message :
      error: your local changes to the following files would be overwritten by merge: MMM-Taffic.js
      please, commit your changes or stash them before you can merge.
      Aborting
      why ?
      thanks.
        Mykle1 Project Sponsor Module Developer @Fonfon
        @Fonfon said in Try to update a module:
        It would appear that you changed something in the module file, MMM-Traffic.js. So, you can either undo those changes and then do a git pull, or you can delete and re-install the module and then do a git pull.
        Keep in mind, if you delete and re-install the module, the changes you made to the original will be lost. This does not affect your config.js file
        • F Offline
          Fonfon @Mykle1
          @Mykle1 Thanks again ;) you are right
          sometimes when i can’t have a very good english is difficult to understand …
          thanks…
            @Fonfon - You’re welcome :-)
            De rien.
            Prego.
            別客氣.
            Bitte.
            どういたしまして.
            Værsågod.
