    Facial Recognition - customize your mirror for every user!
    215 Posts 55 Posters 519.1k Views 57 Watching
      sunnysys
      Hey!
      I’d like to use facial recognition with MM. Before installing OpenCV, I’d like to know if OpenCV 2.4.13, or OpenCV 3.1 should I get to use face recognition module? Does it matter at all?
      Thanks in advance!
        sunnysys @sunnysys
        @sunnysys OK, I figured it out.
        Finally managed Facial-Recognition to work, but I’ve got a little issue: I have to stand real close (10 cm) to RPi Camera to recognize me. What do I wrong, and how can it be fixed?
        Thanks!
        cowboysdudeC paviroP 2 Replies Last reply Reply Quote 0
        • cowboysdudeC Offline
          cowboysdude Module Developer @sunnysys
          @sunnysys What equipment and software did you use?
            sunnysys @cowboysdude
            @cowboysdude
            RPi2 + RPi camera, control with laptop via Putty+Xming. I installed OpenCV 2.4.9 on RPi2.
            I wrote a little script in Python and made 20 pictures with RPi2 + RPi camera. Then I used paviro’s MMM-Facial-Recognition-Tools to train with the saved pictures, also in RPi2. (paviro says it can be pretty slow on RPi, but it wasn’t. :) ) After this I gave MMM-Facial-Recognition module to Magic Mirror config.js and the classis to the other modules.
            It works, but can recognize my face rarely. Maybe I made the pictures in inappropriate lighting conditions?
            cowboysdudeC 2 Replies Last reply Reply Quote 2
            • paviroP Offline
              paviro @sunnysys
              @sunnysys Somewhere in the code is a hardcoded setting of the resolution that is captured (I will add an option for that someday but I am busy with school right now). If you set this to an higher resolution you will not have to stand as close but it will require more processing power :)
              Please also note that you should take the pics in a similar lightning environment as your mirror will be!
              – The Doctor
              S 1 Reply Last reply Reply Quote 3
                sunnysys @paviro
                @paviro Really thanks paviro, I will try to find it! :)
                  @sunnysys Thank you!!! Sounds straight forward enough!!
                  Thank you again!!!
                    @sunnysys OH shoot I just sat down to order some stuff for this and realized I didn’t ask you which camera did you get? Did you get the regular or NOIR version?
                    Do you mind sharing your py script that you used to make the pictures? Much appreciated!
                    Thanks!
                    paviroP S 2 Replies Last reply Reply Quote 0
                    • paviroP Offline
                      paviro @cowboysdude
                      @cowboysdude @sunnysys why not use the capture script in the module repo?
                      – The Doctor
                      cowboysdudeC S 2 Replies Last reply Reply Quote 1
                        cowboysdude Module Developer @paviro
                        @paviro When I get the camera and rebuild the mirror I will do that!! Sounds like it may be easier…
                        • 21
                        • 22
                        • 1 / 22
