    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 564.2k Views 58 Watching
      sunnysys @cowboysdude
      @cowboysdude
      RPi2 + RPi camera, control with laptop via Putty+Xming. I installed OpenCV 2.4.9 on RPi2.
      I wrote a little script in Python and made 20 pictures with RPi2 + RPi camera. Then I used paviro’s MMM-Facial-Recognition-Tools to train with the saved pictures, also in RPi2. (paviro says it can be pretty slow on RPi, but it wasn’t. :) ) After this I gave MMM-Facial-Recognition module to Magic Mirror config.js and the classis to the other modules.
      It works, but can recognize my face rarely. Maybe I made the pictures in inappropriate lighting conditions?
      cowboysdudeC 2 Replies Last reply Reply Quote 2
        paviro @sunnysys
        @sunnysys Somewhere in the code is a hardcoded setting of the resolution that is captured (I will add an option for that someday but I am busy with school right now). If you set this to an higher resolution you will not have to stand as close but it will require more processing power :)
        Please also note that you should take the pics in a similar lightning environment as your mirror will be!
        – The Doctor
        S 1 Reply Last reply Reply Quote 3
          sunnysys @paviro
          @paviro Really thanks paviro, I will try to find it! :)
          • cowboysdudeC
            cowboysdude Module Developer @sunnysys
            @sunnysys Thank you!!! Sounds straight forward enough!!
            Thank you again!!!
            • cowboysdudeC
              @sunnysys OH shoot I just sat down to order some stuff for this and realized I didn’t ask you which camera did you get? Did you get the regular or NOIR version?
              Do you mind sharing your py script that you used to make the pictures? Much appreciated!
              Thanks!
              P S 2 Replies Last reply Reply Quote 0
                paviro @cowboysdude
                @cowboysdude @sunnysys why not use the capture script in the module repo?
                – The Doctor
                cowboysdudeC S 2 Replies Last reply Reply Quote 1
                • cowboysdudeC
                  cowboysdude Module Developer @paviro
                  @paviro When I get the camera and rebuild the mirror I will do that!! Sounds like it may be easier…
                    @cowboysdude I’ve got the 5MP regular version PiCamera. I read somewhere that the new 8MP ones still got some issues. Don’t know what’s the situation with it now.
                    Yes, I can share you my capturing code but now I’ve tried to capture images with the built in script of paviro’s MMM-Facial-Recognition-Tools and it works fine. No need to use other script anymore. :)
                      sunnysys @paviro
                      @paviro I tried it at first time and it seemed not working. Don’t know what the problem was but I’ve taken a second try right now and it works like a charm. :) Thanks!
                      • cowboysdudeC
                        @sunnysys @paviro
                        Thank you both!! My camera should be in today so I guess I’ll tinker with it this weekend.
                        I ordered the NOIR version …
                        • piedanielP
                          piedaniel
                          Someone know if this module could work with a USB webcam? I try but don´t recognize me. I have the training.xml document on the folder, then start the MagicMirror and Raspberry start the module, but then nothing. I need to do something else? Need to configure in a different way? Or not be possible?
                          Log:
                          > magicmirror@2.0.0 start /home/pi/MagicMirror
                          > electron js/electron.js
                          Loading config ...
                          Loading module helpers ...
                          All module helpers loaded.
                          Starting server op port 8080 ...
                          Server started ...
                          Starting module: newsfeed
                          Connecting socket for: MMM-Facial-Recognition
                          Staring module helper: MMM-Facial-Recognition
                          Launching application.
                          Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/es.ar%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 300000
                          Create new news fetcher for url: http://www.ole.com.ar/rss/ultimas-noticias/ - Interval: 300000
                          Can't parse feed item:
                          Title: undefined
                          Description:
                          Pubdate: undefined
                          [MMM-Facial-Recognition] Facerecognition started...
                          [MMM-Facial-Recognition] Loading training data...
                          [MMM-Facial-Recognition] ALGORITHM: LBPH
                          [MMM-Facial-Recognition] Training data loaded!
                          [MMM-Facial-Recognition] --------------------
                          [MMM-Facial-Recognition] Webcam ausgewählt...
                          Note from admin: Please use Markdown on code snippets!
                            sunnysys @piedaniel
                            @piedaniel did you set “useUSBCam” to True in the config.js?
                            • piedanielP
                              piedaniel
                              yes, I configure in true useUSBCam.
                              • cowboysdudeC
                                I’m holding off on the facial recognition until I can figure out how to use in conjunction with pir sensor to turn mirror on and off…
                                  sarthak18593
                                  Can anyone show me an example of how the classes should sit in the config.js file? I’m confused
                                  • K
                                    KirAsh4 Moderator
                                    Take a look at the stock ~/MagicMiror/config/config.js.sample file. That should give you a good start.
                                      sarthak18593
                                      im stuck at this part of the facial recognition tools - “Write down the [‘name’, ‘name2’,‘name3’] part because you will later need it for setting up your mirror’s face recognition.” , Where do i find those names ? i see a folder has been created in the training data , but training.xml doesnt have any names
                                        sarthak18593
                                        Nevermind , got it , stupid mistake
                                        • L
                                          lepetitnicolas
                                          I just discovered this project and i want to try this module before to build my MagicMirror !!!
                                          i’ve got a problem with the facial recognition tools…
                                          i use a usbcam, i try with fswebcam without problem, i enable the webcam in raspi-config but when i try capture.py, i’ve got a error
                                          Capturing positive training images.
                                          Type c (and press enter) to capture an image.
                                          Press Ctrl-C to quit.
                                          c
                                          Capturing image...
                                          mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
                                          mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
                                            File "capture.py", line 35, in <module>
                                              capture.capture()
                                            File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facetrainer/lib/capture.py", line 55, in capture
                                              image = camera.read()
                                            File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facetrainer/lib/picam.py", line 23, in read
                                              with picamera.PiCamera() as camera:
                                            File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 488, in __init__
                                              self.STEREO_MODES[stereo_mode], stereo_decimate)
                                            File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 526, in _init_camera
                                              "Camera is not enabled. Try running 'sudo raspi-config' "
                                          picamera.exc.PiCameraError: Camera is not enabled. Try running 'sudo raspi-config' and ensure that the camera has been enabled.
                                          Can you help me ?
                                          Thank
                                          Note from admin: Please use Markdown on shell snippets!
                                            sarthak18593 @lepetitnicolas
                                            @lepetitnicolas To my knowledge , capture .py only works with the built in webcam , that is , the pi camera module . Plus , if you are already taking images via fswebcam , why not just select option 2 in capture.py, the one with using already existing .jpg files ? Why capture again ?
                                            • 10
                                            • 11
                                            • 1 / 11
