    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 570.1k Views 58 Watching
      sunnysys @sunnysys
      @sunnysys OK, I figured it out.
      Finally managed Facial-Recognition to work, but I’ve got a little issue: I have to stand real close (10 cm) to RPi Camera to recognize me. What do I wrong, and how can it be fixed?
      Thanks!
      cowboysdudeC paviroP 2 Replies Last reply
      • cowboysdudeC
        cowboysdude Module Developer @sunnysys
        @sunnysys What equipment and software did you use?
          sunnysys @cowboysdude
          @cowboysdude
          RPi2 + RPi camera, control with laptop via Putty+Xming. I installed OpenCV 2.4.9 on RPi2.
          I wrote a little script in Python and made 20 pictures with RPi2 + RPi camera. Then I used paviro’s MMM-Facial-Recognition-Tools to train with the saved pictures, also in RPi2. (paviro says it can be pretty slow on RPi, but it wasn’t. :) ) After this I gave MMM-Facial-Recognition module to Magic Mirror config.js and the classis to the other modules.
          It works, but can recognize my face rarely. Maybe I made the pictures in inappropriate lighting conditions?
          cowboysdudeC 2 Replies Last reply
          Reply Quote 2
          • paviroP
            paviro @sunnysys
            @sunnysys Somewhere in the code is a hardcoded setting of the resolution that is captured (I will add an option for that someday but I am busy with school right now). If you set this to an higher resolution you will not have to stand as close but it will require more processing power :)
            Please also note that you should take the pics in a similar lightning environment as your mirror will be!
            – The Doctor
            Reply Quote 3
              sunnysys @paviro
              @paviro Really thanks paviro, I will try to find it! :)
              • cowboysdudeC
                @sunnysys Thank you!!! Sounds straight forward enough!!
                Thank you again!!!
                • cowboysdudeC
                  @sunnysys OH shoot I just sat down to order some stuff for this and realized I didn’t ask you which camera did you get? Did you get the regular or NOIR version?
                  Do you mind sharing your py script that you used to make the pictures? Much appreciated!
                  Thanks!
                  paviroP S 2 Replies Last reply
                  • paviroP
                    paviro @cowboysdude
                    @cowboysdude @sunnysys why not use the capture script in the module repo?
                    – The Doctor
                    cowboysdudeC S 2 Replies Last reply
                    • cowboysdudeC
                      cowboysdude Module Developer @paviro
                      @paviro When I get the camera and rebuild the mirror I will do that!! Sounds like it may be easier…
                        @cowboysdude I’ve got the 5MP regular version PiCamera. I read somewhere that the new 8MP ones still got some issues. Don’t know what’s the situation with it now.
                        Yes, I can share you my capturing code but now I’ve tried to capture images with the built in script of paviro’s MMM-Facial-Recognition-Tools and it works fine. No need to use other script anymore. :)
                        Reply Quote 2
                          sunnysys @paviro
                          @paviro I tried it at first time and it seemed not working. Don’t know what the problem was but I’ve taken a second try right now and it works like a charm. :) Thanks!
                          • cowboysdudeC
                            @sunnysys @paviro
                            Thank you both!! My camera should be in today so I guess I’ll tinker with it this weekend.
                            I ordered the NOIR version …
                            • piedanielP
                              piedaniel
                              Someone know if this module could work with a USB webcam? I try but don´t recognize me. I have the training.xml document on the folder, then start the MagicMirror and Raspberry start the module, but then nothing. I need to do something else? Need to configure in a different way? Or not be possible?
                              Log:
                              > magicmirror@2.0.0 start /home/pi/MagicMirror
                              > electron js/electron.js
                              Loading config ...
                              Loading module helpers ...
                              All module helpers loaded.
                              Starting server op port 8080 ...
                              Server started ...
                              Starting module: newsfeed
                              Connecting socket for: MMM-Facial-Recognition
                              Staring module helper: MMM-Facial-Recognition
                              Launching application.
                              Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/es.ar%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 300000
                              Create new news fetcher for url: http://www.ole.com.ar/rss/ultimas-noticias/ - Interval: 300000
                              Can't parse feed item:
                              Title: undefined
                              Description:
                              Pubdate: undefined
                              [MMM-Facial-Recognition] Facerecognition started...
                              [MMM-Facial-Recognition] Loading training data...
                              [MMM-Facial-Recognition] ALGORITHM: LBPH
                              [MMM-Facial-Recognition] Training data loaded!
                              [MMM-Facial-Recognition] --------------------
                              [MMM-Facial-Recognition] Webcam ausgewählt...
                              Note from admin: Please use Markdown on code snippets!
                                sunnysys @piedaniel
                                @piedaniel did you set “useUSBCam” to True in the config.js?
                                • piedanielP
                                  piedaniel
                                  yes, I configure in true useUSBCam.
                                  • cowboysdudeC
                                    I’m holding off on the facial recognition until I can figure out how to use in conjunction with pir sensor to turn mirror on and off…
                                    Reply Quote 2
                                      sarthak18593
                                      Can anyone show me an example of how the classes should sit in the config.js file? I’m confused
                                      • KirAsh4K
                                        KirAsh4 Moderator
                                        Take a look at the stock ~/MagicMiror/config/config.js.sample file. That should give you a good start.
                                          sarthak18593
                                          im stuck at this part of the facial recognition tools - “Write down the [‘name’, ‘name2’,‘name3’] part because you will later need it for setting up your mirror’s face recognition.” , Where do i find those names ? i see a folder has been created in the training data , but training.xml doesnt have any names
                                          L 1 Reply Last reply
                                            sarthak18593
                                            Nevermind , got it , stupid mistake
                                            • 10
                                            • 11
                                            • 1 / 11
