    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 227.4k Views 28 Watching
    • A
      albertc
      @Alvinger
      Is it possible to make the departure times show up as relative instead of absolute? As in: bus leaving in 5 mins, instead of at 09:44 (just as it looks at the bus stop).
      AlvingerA 1 Reply Last reply
      Reply Quote -1
      • AlvingerA
        Alvinger @albertc
        @albertc
        Not right now. This was a conscious decision on my part as the mirror updates fairly seldom. relative departure times would be showing the wrong info after one minute.
          MobbareKurtZ
          Module doesn’t show anything except the header for me, found this in the logs:
          node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: [object Object]
          What to do?
          M 1 Reply Last reply
            MobbareKurtZ @MobbareKurtZ
            @MobbareKurtZ said in MMM-ResRobot - Public transport information for Sweden:
            What to do?
            Oh I think I got it. You can’t have a route that isn’t a direct run?
            • A
              albertc @Alvinger
              @Alvinger
              Thanks for the response! But wouldn’t it be possible to use the (seldomly updated) time and subtract real time and still have an accurate “time left to departure”? I guess the table on screen would need to be updated more often than data is loaded.
              • AlvingerA
                Alvinger @MobbareKurtZ
                @MobbareKurtZ
                It all depends on the underlying ResRobot API but it sounds reasonable that ResRobot needs to know in what direction you are travelling.
                As the module only shows departures there is no need to specify a destination unless you want to limit the displayed departures to the ones going in that specific direction. In that case I would suggest to enter not the ultimate destination but rather the next “logical” stop such as point of transit between modes of transport.
                  MobbareKurtZ @Alvinger
                  @Alvinger How can you add multiple departure locations though?
                  • AlvingerA
                    @MobbareKurtZ
                    By adding them as a comma-separated list, e.g.
                    to: "54321,64321,74321"
                    where each from and to pair specify an id for the departure and destination stops. If destination is not needed for a departure station, simply leave it empty like this:
                    to: "54321,,74321"
                      @Alvinger Alright thanks!
                      • A
                        Advokaten
                        Is this still working? I’m getting “Fetching departures…” message forever :(
                        		module: "MMM-ResRobot",
                        		position: "bottom_left",
                        			from: "740064518",		// ResRobot Station ID (or a comma-separated string of IDs)
                        			to: "740012366",			// ResRobot Station ID of destination (or a comma-separated string of IDs)
                        			skipMinutes: 0,		// Skip departures that happens within the next  minutes.
                        			maximumEntries: 6,	// Number of departures to show on screen
                        			truncateAfter: 5,	// A value > 0 will truncate direction name at first space after  characters. 0 = no truncation
                        			apiKey: "my api key"		// Your ResRobot apiKey
                        • AlvingerA
                          Alvinger @Advokaten
                          @Advokaten
                          Strange, my mirror is running flawlessly. I’ll put in your config and see what happens.
                          A 2 Replies Last reply
                          • A
                            Advokaten @Alvinger
                            @Alvinger I reinstalled it, rebooted and stuff and it magically appeared! Thank you for this wonderful module! :D (I have no idea what was wrong lol)
                            • A
                              Advokaten @Alvinger
                              @Alvinger I saw that the bus line I pull data from is misnamed. Is there a way to fix this? Thanks.
                              • AlvingerA
                                Alvinger @Advokaten
                                @Advokaten
                                Do you mean that the name of the bus stop is misnamed on screen? Then you have to contact ResRobot to change it.
                                • W
                                  wizz
                                  @Alvinger If i add 2 departure one for my bus and one for the train in the module i also want it to display 2 different mode of transportation icons,
                                  How do i do that?
                                  Or is it not possible?
                                  Wold be nice if it was an solution for this.
                                  • AlvingerA
                                    Alvinger @wizz
                                    @wizz
                                    It’s automatic and already there! Try it and you’ll see.
                                    Icons are selected based on mode of transport, it’s going to be one of bus, metro, rail or ferry.
                                    • W
                                      wizz
                                      @Alvinger ok thats nice will try tonight and see how it works :)
                                      • N
                                        norden1978
                                        I am having the same trouble with “Fetching departures…”
                                        Tried to redo it some times but cannot get it to work.
                                        This is the config i use:
        module: "weatherforecast",
        header: "Weather Forecast",
        locationID: "2677025",  //ID from http://www.openweathermap.org/help/city_list.txt
        appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
        position: "right",
        header: "Tidtabell",
        to: "740001587",
        maximumEntries: 6,
        truncateAfter: 0,
        apiKey: "d0b6457c-a18e-42cc-9aa4-xxxxxxxxx"
                                        • E
                                          Eburkis
                                          I have the same problem as norden1978 ^^above me and its stuck on “fetching departures”
                                          i dont know whats wrong
                                          here is my code
                                          		position: "left",
                                          		header: "Avgångar",
                                          			to: "1138",
                                          			skipMinutes: 0,
                                          			maximumEntries: 6,
                                          			truncateAfter: 2,
                                          			apikey: "MY APIKEY"		// Your ResRobot apiKey
                                          • AlvingerA
                                            Alvinger @Eburkis
                                            @Eburkis
                                            I haven’t been active for a while due to other things than magic mirrors.
                                            Let me take a look and see if I can find out what’s wrong.
                                            E N 2 Replies Last reply
                                            • 3 / 7
