    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 225.2k Views 28 Watching
      MobbareKurtZ @Alvinger
      @Alvinger How can you add multiple departure locations though?
      • A
        Alvinger @MobbareKurtZ
        @MobbareKurtZ
        By adding them as a comma-separated list, e.g.
        to: "54321,64321,74321"
        where each from and to pair specify an id for the departure and destination stops. If destination is not needed for a departure station, simply leave it empty like this:
        to: "54321,,74321"
          @Alvinger Alright thanks!
          • A
            Advokaten
            Is this still working? I’m getting “Fetching departures…” message forever :(
            		module: "MMM-ResRobot",
            		position: "bottom_left",
            			from: "740064518",		// ResRobot Station ID (or a comma-separated string of IDs)
            			to: "740012366",			// ResRobot Station ID of destination (or a comma-separated string of IDs)
            			skipMinutes: 0,		// Skip departures that happens within the next  minutes.
            			maximumEntries: 6,	// Number of departures to show on screen
            			truncateAfter: 5,	// A value > 0 will truncate direction name at first space after  characters. 0 = no truncation
            			apiKey: "my api key"		// Your ResRobot apiKey
            • A
              Alvinger @Advokaten
              @Advokaten
              Strange, my mirror is running flawlessly. I’ll put in your config and see what happens.
              A 2 Replies Last reply Reply Quote 0
              • A
                Advokaten @Alvinger
                @Alvinger I reinstalled it, rebooted and stuff and it magically appeared! Thank you for this wonderful module! :D (I have no idea what was wrong lol)
                • A
                  Advokaten @Alvinger
                  @Alvinger I saw that the bus line I pull data from is misnamed. Is there a way to fix this? Thanks.
                  • A
                    Alvinger @Advokaten
                    @Advokaten
                    Do you mean that the name of the bus stop is misnamed on screen? Then you have to contact ResRobot to change it.
                    • W
                      wizz
                      @Alvinger If i add 2 departure one for my bus and one for the train in the module i also want it to display 2 different mode of transportation icons,
                      How do i do that?
                      Or is it not possible?
                      Wold be nice if it was an solution for this.
                      • A
                        Alvinger @wizz
                        @wizz
                        It’s automatic and already there! Try it and you’ll see.
                        Icons are selected based on mode of transport, it’s going to be one of bus, metro, rail or ferry.
                        • W
                          wizz
                          @Alvinger ok thats nice will try tonight and see how it works :)
                          • N
                            norden1978
                            I am having the same trouble with “Fetching departures…”
                            Tried to redo it some times but cannot get it to work.
                            This is the config i use:
                                                    module: "weatherforecast",
                                                    header: "Weather Forecast",
                                                            locationID: "2677025",  //ID from http://www.openweathermap.org/help/city_list.txt
                                                            appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                                                    position: "right",
                                                    header: "Tidtabell",
                                                            to: "740001587",
                                                            maximumEntries: 6,
                                                            truncateAfter: 0,
                                                            apiKey: "d0b6457c-a18e-42cc-9aa4-xxxxxxxxx"
                            • E
                              Eburkis
                              I have the same problem as norden1978 ^^above me and its stuck on “fetching departures”
                              i dont know whats wrong
                              here is my code
                              		position: "left",
                              		header: "Avgångar",
                              			to: "1138",
                              			skipMinutes: 0,
                              			maximumEntries: 6,
                              			truncateAfter: 2,
                              			apikey: "MY APIKEY"		// Your ResRobot apiKey
                              • A
                                Alvinger @Eburkis
                                @Eburkis
                                I haven’t been active for a while due to other things than magic mirrors.
                                Let me take a look and see if I can find out what’s wrong.
                                E N 2 Replies Last reply Reply Quote 0
                                • E
                                  Eburkis
                                  @Alvinger said in MMM-ResRobot - Public transport information for Sweden:
                                  @Eburkis
                                  yes do that pls :) it would be very nice
                                  • E
                                    Eburkis @Alvinger
                                    @Eburkis
                                    —Update–
                                    now the module is working and seems to fetching the data but don’t displays anything…
                                    dont know whats wrong now
                                    • N
                                      norden1978 @Alvinger
                                      @Alvinger sounds great :)
                                        rich710
                                        Same for me, Fetching departures… forever, I have checked my ID:s on ResRobot and entered them in an url, to test.
                                        Happy for help.
                                        Regards //Richard
                                        • N
                                          nn1mda
                                          Installed this today, but it doesn’t work.
                                          Does it work for anyone else? And if so - what did you do? :)
                                          • A
                                            Alvinger @nn1mda
                                            @nn1mda
                                            I haven’t been active in the Magic Mirror community for some time but I just checked and for me it works without issues. Did you get your API key?
                                            • 3 / 7
