    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 220.5k Views 28 Watching
      albertc @Alvinger
      @Alvinger
      Thanks for the response! But wouldn’t it be possible to use the (seldomly updated) time and subtract real time and still have an accurate “time left to departure”? I guess the table on screen would need to be updated more often than data is loaded.
        Alvinger @MobbareKurtZ
        @MobbareKurtZ
        It all depends on the underlying ResRobot API but it sounds reasonable that ResRobot needs to know in what direction you are travelling.
        As the module only shows departures there is no need to specify a destination unless you want to limit the displayed departures to the ones going in that specific direction. In that case I would suggest to enter not the ultimate destination but rather the next “logical” stop such as point of transit between modes of transport.
          MobbareKurtZ @Alvinger
          @Alvinger How can you add multiple departure locations though?
            @MobbareKurtZ
            By adding them as a comma-separated list, e.g.
            to: "54321,64321,74321"
            where each from and to pair specify an id for the departure and destination stops. If destination is not needed for a departure station, simply leave it empty like this:
            to: "54321,,74321"
              @Alvinger Alright thanks!
                Advokaten
                Is this still working? I’m getting “Fetching departures…” message forever :(
                		module: "MMM-ResRobot",
                		position: "bottom_left",
                			from: "740064518",		// ResRobot Station ID (or a comma-separated string of IDs)
                			to: "740012366",			// ResRobot Station ID of destination (or a comma-separated string of IDs)
                			skipMinutes: 0,		// Skip departures that happens within the next  minutes.
                			maximumEntries: 6,	// Number of departures to show on screen
                			truncateAfter: 5,	// A value > 0 will truncate direction name at first space after  characters. 0 = no truncation
                			apiKey: "my api key"		// Your ResRobot apiKey
                  Alvinger @Advokaten
                  @Advokaten
                  Strange, my mirror is running flawlessly. I’ll put in your config and see what happens.
                  A 2 Replies Last reply Reply Quote 0
                    Advokaten @Alvinger
                    @Alvinger I reinstalled it, rebooted and stuff and it magically appeared! Thank you for this wonderful module! :D (I have no idea what was wrong lol)
                      Advokaten @Alvinger
                      @Alvinger I saw that the bus line I pull data from is misnamed. Is there a way to fix this? Thanks.
                        Alvinger @Advokaten
                        @Advokaten
                        Do you mean that the name of the bus stop is misnamed on screen? Then you have to contact ResRobot to change it.
                        • W Offline
                          wizz
                          @Alvinger If i add 2 departure one for my bus and one for the train in the module i also want it to display 2 different mode of transportation icons,
                          How do i do that?
                          Or is it not possible?
                          Wold be nice if it was an solution for this.
                            Alvinger @wizz
                            @wizz
                            It’s automatic and already there! Try it and you’ll see.
                            Icons are selected based on mode of transport, it’s going to be one of bus, metro, rail or ferry.
                            • W Offline
                              wizz
                              @Alvinger ok thats nice will try tonight and see how it works :)
                              • N Offline
                                norden1978
                                I am having the same trouble with “Fetching departures…”
                                Tried to redo it some times but cannot get it to work.
                                This is the config i use:
                                                        module: "weatherforecast",
                                                        header: "Weather Forecast",
        locationID: "2677025",  //ID from http://www.openweathermap.org/help/city_list.txt
        appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                                                        position: "right",
                                                        header: "Tidtabell",
        to: "740001587",
        maximumEntries: 6,
        truncateAfter: 0,
        apiKey: "d0b6457c-a18e-42cc-9aa4-xxxxxxxxx"
                                • E Offline
                                  Eburkis
                                  I have the same problem as norden1978 ^^above me and its stuck on “fetching departures”
                                  i dont know whats wrong
                                  here is my code
                                  		position: "left",
                                  		header: "Avgångar",
                                  			to: "1138",
                                  			skipMinutes: 0,
                                  			maximumEntries: 6,
                                  			truncateAfter: 2,
                                  			apikey: "MY APIKEY"		// Your ResRobot apiKey
                                    Alvinger @Eburkis
                                    @Eburkis
                                    I haven’t been active for a while due to other things than magic mirrors.
                                    Let me take a look and see if I can find out what’s wrong.
                                    E N 2 Replies Last reply Reply Quote 0
                                    • E Offline
                                      Eburkis
                                      @Alvinger said in MMM-ResRobot - Public transport information for Sweden:
                                      @Eburkis
                                      yes do that pls :) it would be very nice
                                      • E Offline
                                        Eburkis @Alvinger
                                        @Eburkis
                                        —Update–
                                        now the module is working and seems to fetching the data but don’t displays anything…
                                        dont know whats wrong now
                                        • N Offline
                                          norden1978 @Alvinger
                                          @Alvinger sounds great :)
                                            rich710
                                            Same for me, Fetching departures… forever, I have checked my ID:s on ResRobot and entered them in an url, to test.
                                            Happy for help.
                                            Regards //Richard
                                            • 3 / 7
