    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 225.2k Views 28 Watching
    • A
      Alvinger
      @FallandeGubbe,
      I’m running it on a Raspberry Pi 1 B with 256MB so yes, it’s possible… :-)
      You can’t run MagicMirror out of the box but I wrote a post in another thread about it:
      [https://forum.magicmirror.builders/topic/1659/3-tries-3-fails-raspberry-b/13]
      FallandeGubbeF 1 Reply Last reply Reply Quote 0
      • FallandeGubbeF
        FallandeGubbe @Alvinger
        @Alvinger Thanks for replying! Yes, I know that Raspberry Pi 1 needs some manual work :)
        I followed the tutorial at https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero
        and everything is working great! Until I try to install MMM-ResRobot. Something gets messed up apparently… But it works fine on my Raspberry Pi 3 … (same SD card, same image)
        OK, I’ll keep investigating then, since you got it working!!
        • A
          Alvinger @FallandeGubbe
          @FallandeGubbe
          Maybe a stupid quesrion but did you run npm install after cloning the repository?
          • FallandeGubbeF
            @Alvinger No problem :)
            Yes , I did. And as mentioned - when I plug the SD-card into my RPi3 all work fine.
            When I plug the SD-card in my RPi1 midori won’t connect. If I remove MMM-resrobot from config-file and reboot MagicMirror works fine on my RPi 1 (all other modules load OK)…
            I find it strange …
              broberg Project Sponsor @FallandeGubbe
              @FallandeGubbe @Alvinger could it have something to do with this :
              https://forum.magicmirror.builders/topic/922/modules-not-showing-up-on-kweb-or-midori
              There are other modules that midori doesn’t like apparently.
              • A
                Alvinger @broberg
                @broberg @FallandeGubbe
                One thing popped into my mind: the Pi 1 is much slower than a Pi 3 and loading all the modules takes quite some time. Could it be that you are trying to open midori before MagicMirror has loaded all the modules and therefore is refusing connections? That in itself was the reason I had to go with a script that checked that midori was listening before launching MagicMirror.
                Have you checked with journalctl that magicmiror is ready for action?
                FallandeGubbeF 1 Reply Last reply Reply Quote 1
                • FallandeGubbeF
                  @Alvinger aahh… I think you might be right! I will do some investigation on this!
                  Thanks! :thumbsup:
                  • A
                    albertc
                    @Alvinger
                    Is it possible to make the departure times show up as relative instead of absolute? As in: bus leaving in 5 mins, instead of at 09:44 (just as it looks at the bus stop).
                    A 1 Reply Last reply Reply Quote -1
                    • A
                      Alvinger @albertc
                      @albertc
                      Not right now. This was a conscious decision on my part as the mirror updates fairly seldom. relative departure times would be showing the wrong info after one minute.
                        MobbareKurtZ
                        Module doesn’t show anything except the header for me, found this in the logs:
                        node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: [object Object]
                        What to do?
                          MobbareKurtZ @MobbareKurtZ
                          @MobbareKurtZ said in MMM-ResRobot - Public transport information for Sweden:
                          What to do?
                          Oh I think I got it. You can’t have a route that isn’t a direct run?
                          • A
                            albertc @Alvinger
                            @Alvinger
                            Thanks for the response! But wouldn’t it be possible to use the (seldomly updated) time and subtract real time and still have an accurate “time left to departure”? I guess the table on screen would need to be updated more often than data is loaded.
                            • A
                              Alvinger @MobbareKurtZ
                              @MobbareKurtZ
                              It all depends on the underlying ResRobot API but it sounds reasonable that ResRobot needs to know in what direction you are travelling.
                              As the module only shows departures there is no need to specify a destination unless you want to limit the displayed departures to the ones going in that specific direction. In that case I would suggest to enter not the ultimate destination but rather the next “logical” stop such as point of transit between modes of transport.
                                MobbareKurtZ @Alvinger
                                @Alvinger How can you add multiple departure locations though?
                                • A
                                  @MobbareKurtZ
                                  By adding them as a comma-separated list, e.g.
                                  to: "54321,64321,74321"
                                  where each from and to pair specify an id for the departure and destination stops. If destination is not needed for a departure station, simply leave it empty like this:
                                  to: "54321,,74321"
                                    @Alvinger Alright thanks!
                                    • A
                                      Advokaten
                                      Is this still working? I’m getting “Fetching departures…” message forever :(
                                      		module: "MMM-ResRobot",
                                      		position: "bottom_left",
                                      			from: "740064518",		// ResRobot Station ID (or a comma-separated string of IDs)
                                      			to: "740012366",			// ResRobot Station ID of destination (or a comma-separated string of IDs)
                                      			skipMinutes: 0,		// Skip departures that happens within the next  minutes.
                                      			maximumEntries: 6,	// Number of departures to show on screen
                                      			truncateAfter: 5,	// A value > 0 will truncate direction name at first space after  characters. 0 = no truncation
                                      			apiKey: "my api key"		// Your ResRobot apiKey
                                      • A
                                        Alvinger @Advokaten
                                        @Advokaten
                                        Strange, my mirror is running flawlessly. I’ll put in your config and see what happens.
                                        A 2 Replies Last reply Reply Quote 0
                                        • A
                                          Advokaten @Alvinger
                                          @Alvinger I reinstalled it, rebooted and stuff and it magically appeared! Thank you for this wonderful module! :D (I have no idea what was wrong lol)
                                          • A
                                            Advokaten @Alvinger
                                            @Alvinger I saw that the bus line I pull data from is misnamed. Is there a way to fix this? Thanks.
                                            • 3 / 7
