    MMM-OpenhabFloorplan
    23 Posts 7 Posters 32.1k Views 8 Watching
      paphko @schummi84
      @schummi84 Please make sure your openhab installation has the REST API installed/enabled. You can check that in a browser, e.g.: http://localhost:8080/rest/items/Light_Garden_Garage
      The result should be similar to this:
        "link": "http://localhost:8080/rest/items/Light_Garden_Garage",
        "state": "OFF",
        "type": "Switch",
        "name": "Light_Garden_Garage",
        "label": "Garage",
        "tags": [
          "Lighting"
        "groupNames": [
          "Garden",
          "Lights"
      Does that work for you? If so, please write the URL of one of your items.
      schummi84S 1 Reply Last reply Reply Quote 0
      • schummi84S
        schummi84 @paphko
        @paphko When I adjust your link with one of my items I get the following result:
          "link": "http://192.168.2.122:8080/rest/items/L_ZELT",
          "state": "ON",
          "type": "Switch",
          "name": "L_ZELT",
          "label": "Switch_Zelt",
          "category": "Light",
          "tags": [],
          "groupNames": []
        Adding the Light in the config.js is still not working.
        Here the config code:
        	//------------- OPENHAB FLOORPLAN ----------------------------------------------------------
                module: 'mmm-openhabfloorplan',
                position: 'bottom_center', // this can be any of the regions
                    updateInterval: 60 * 60 * 1000, // refreshing all windows / lights / labels once per hour; 0 to disable periodic update
                    draft: false, // if true, all lights, windows, and label names are shown; if false, get states from openhab
                    openhab: {
                        url: "http://localhost:8080", // must not have a trailing slash!
                    floorplan: {
                        image: "egog2.png", // image in subfolder 'images'; change to floorplan.png to avoid git repository changes
                        width: 800, // this must be the width of the image above
                        height: 333, // this must be the height of the image above
                     light: { // this part shows default settings for lights; may optionally be overwritten
                      image: "light.png", // located in subfolder 'images'
                      width: 19, // image width
                      height: 19, // image height
           		lights: { // list all light items to be shown (must be of openhab type Switch or Dimmer)
        		//=== ERDGESCHOSS ================
        		L_ZELT: {left:200, top:05},
        //ALTERNATIVEITEM CODE
        L_ZELT_Toggle: {left:200, top:05},
                    windows: { // list all window / door contacts to be shown (must be of openhab type Switch or Contact)
                        // openhab item: left, top, radius (draws quadrant), midPoint, and optionally counterwindow and color
                        // Reed_Sleeping_right: { left: 12,  top: 231, radius: 30, midPoint: "top-left" },
                        // openhab item: left, top, width, height (draws rectangle), and optionally color
                        // Reed_Sleeping_left:  { left: 90,  top: 301, width: 37, height: 20 },
                    labels: { // list all strings to be shown (may probably be any openhab type, resonable for String and Number)
                        // openhab item: left, top, and optionally color, font size, prefix, postfix, and number of decimals for floating numbers
                        //Temperature_Entry:          { left: 162, top: 280 },
                        //Temperature_Bath:           { left: 277, top: 280, postfix: "°C", decimals: 1 },
        Configuring the module as draft shows all configured lights correctly.
        Is there anything I am missing?
        • schummi84S
          schummi84 @schummi84
          As additional Information here my OpenHab configuration:
          lights.things
          Bridge hue:bridge:1 [ ipAddress="192.168.2.100" ]
          	0100	L_HUE_BEDROOM_WHITE_Toggle 	[ lightId="1" ]
          	0210	L_HUE_BEDROOM_COLOR_Toggle 	[ lightId="2" ]
          	0210	L_HUE_STRIP_Toggle 		[ lightId="3" ]
          	0210	L_HUE_WZ-MITTE_Toggle 		[ lightId="4" ]
          	0210	L_HUE_ZELT_Toggle 		[ lightId="5" ]
          	0200	L_HUE_IRIS_Toggle		[ lightId="6" ]
          	0210	L_HUE_SOFA_Toggle 		[ lightId="7" ]
          	0210	L_HUE_ESSECKE_Toggle 		[ lightId="8" ]
          	0100	L_HUE_ESSTISCH_Toggle 		[ lightId="9" ]
          	0100	L_HUE_KUECHE_Toggle		[ lightId="10" ]
          lights.sitemap
          sitemap lights label="Main Menu"
          	Frame {
          		Switch item=	L_HUE_SOFA_Toggle
          		Switch item=	L_HUE_STRIP_Toggle
          		Switch item=	L_HUE_ZELT_Toggle
          		Switch item=	L_HUE_IRIS_Toggle
          		Switch item= 	L_HUE_ESSECKE_Toggle
          		Switch item=	L_HUE_ESSTISCH_Toggle
          		Switch item= 	L_HUE_WZ-MITTE_Toggle
          		Switch item=	L_HUE_KUECHE_Toggle
          		Switch item= 	L_HUE_BEDROOM_COLOR_Toggle
          		Switch item= 	L_HUE_BEDROOM_WHITE_Toggle
          Lights.item
          //=====SWITCHES======================================
          Switch 		L_HUE_BEDROOM_WHITE_Toggle 	{ channel="hue:0100:0017881c28a8:1:brightness" }
          Switch 		L_HUE_BEDROOM_COLOR_Toggle 	{ channel="hue:0210:0017881c28a8:2:color" }
          Switch 		L_HUE_STRIP_Toggle 		{ channel="hue:0210:0017881c28a8:3:color" }
          Switch 		L_HUE_WZ-MITTE_Toggle 		{ channel="hue:0210:0017881c28a8:4:color" }
          Switch 		L_HUE_ZELT_Toggle 		{ channel="hue:0210:0017881c28a8:5:color" }
          Switch 		L_HUE_IRIS_Toggle 		{ channel="hue:0200:0017881c28a8:6:color" }
          Switch 		L_HUE_SOFA_Toggle 		{ channel="hue:0210:0017881c28a8:7:color" }
          Switch 		L_HUE_ESSECKE_Toggle 		{ channel="hue:0210:0017881c28a8:8:color" }
          Switch 		L_HUE_ESSTISCH_Toggle 		{ channel="hue:0100:0017881c28a8:9:brightness" }
          Switch 		L_HUE_KUECHE_Toggle 		{ channel="hue:0100:0017881c28a8:10:brightness" }
          Strangly the Config via files seems not to work as the “L_ZELT” item was configured via the PAPERUI and the files are obviously ignored:
          http://192.168.2.122:8080/rest/items/L_HUE_ZELT_Toggle
            "error": {
              "message": "Item L_HUE_ZELT_Toggle does not exist!",
              "http-code": 404
          I found the Openhab on the raspberry in:
          /etc/openhab2
          Is this the correct location?
          Thanks for any help!
          • schummi84S
            Update:
            I reinstalled a clean Jessie on the Raspi and installed Openhab according to the guide on the openhab.org homepage.
            This time I did not install anything via PAPERUI besides the HUE Binding. I copied my item/things/sitemap files as described above to the openhab2 folder.
            Checking the PAPERUI on localhost:8080 shows that the the bridge and lights get listet under the THINGS menue but no items appear.
            0_1488926336055_upload-bc388935-db4b-4b31-901d-393cb3c8b713
            When I link one of the lights with a “new item” I can see the item but with a confusing name. I can control it with openhab though.
            0_1488926552608_upload-a216e794-f0f5-41b8-94ab-0feab73b19f4
            0_1488926411068_upload-c030bbb8-5768-4e81-a523-4f5d29102265
            Your hint with checking the status in the browser just gives me this:
            http://192.168.2.122:8080/rest/items/L_HUE_STRIP_Toggle
             "error": {
                "message": "Item L_HUE_STRIP_Toggle does not exist!",
                "http-code": 404
            Accordingly in the Magicmirror no connection is made.
            Is this a basic OpenHab setup or configuration error?
            Note: trying to change the name of the item manually resutls in a “conflict error”
            Sorry for the long post. Any help is appreciated!
            Cheers
            Schummi
            P 2 Replies Last reply Reply Quote 0
              paphko @schummi84
              @schummi84 that sounds strange, it seems as if the rest api does not cover all items. I’ll try to check that as soon as I find some time.
                paphko @schummi84
                @schummi84 Please open http://192.168.2.122:8080/rest/items to get a (huge) list of all items that are available via the REST API. I realized that items that are automatically created via the Paper UI get an auto-generated name. However, you should be able to find them in the huge list of all items by searching the item labels.
                For example, the Paper UI created yahoo weather item ‘Luftfeuchtigkeit’ has item name ‘yahooweather_weather_berlin_humidity’ on my setup. Then the item URL for such an item would be: http://192.168.2.122:8080/rest/items/yahooweather_weather_berlin_humidity
                schummi84S 2 Replies Last reply Reply Quote 0
                • schummi84S
                  schummi84 @paphko
                  @paphko thanks for the hint. I will try it this afternoon and come back with the result.
                  • schummi84S
                    schummi84 @paphko
                    @paphko I tried you hint with the following result:
                    [{"link":"http://192.168.2.122:8080/rest/items/ExtendedColorLight_Color","state":"ON","type":"Switch","name":"ExtendedColorLight_Color","label":"Color","category":"ColorLight","tags":[],"groupNames":[]},{"link":"http://192.168.2.122:8080/rest/items/SOFA_Switch","state":"ON","type":"Switch","name":"SOFA_Switch","label":"Color","category":"ColorLight","tags":[],"groupNames":[]},{"link":"http://192.168.2.122:8080/rest/items/SOFA_Color","state":"274,87,24","type":"Color","name":"SOFA_Color","label":"Color","category":"ColorLight","tags":[],"groupNames":[]},{"link":"http://192.168.2.122:8080/rest/items/SOFA_ColorTemperature","state":"0","type":"Dimmer","name":"SOFA_ColorTemperature","label":"Color Temperature","category":"ColorLight","tags":[],"groupNames":[]}]
                    Basically it shows two items at the moment, both created with PaperUI. I still don’t undertsand why the file based setup/configuration is not working. I wouldn’t mind if th efloorplan integration would work but still doesn’t. I added the two items to the config.js but without success. I checked the pm2 logs to see the follwoing error:
                    0|mm       | TypeError: Cannot read property 'statusCode' of undefined
                    0|mm       |     at Request._callback (/home/pi/MagicMirror/modules/mmm-openhabfloorplan/node_helper.js:38:65)
                    0|mm       |     at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:186:22)
                    0|mm       |     at emitOne (events.js:96:13)
                    0|mm       |     at Request.emit (events.js:188:7)
                    0|mm       |     at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:845:8)
                    0|mm       |     at ClientRequest.emit (events.js:188:7)
                    0|mm       |     at Socket.socketErrorListener (_http_client.js:308:9)
                    0|mm       |     at Socket.emit (events.js:188:7)
                    Note: I already modified the mmm-openhabfloorplan.js according to your other thread. Unfortunatelly I cannot attach the files here - If required I can post the sourcecode.
                    Any idea ?
                    Cheers
                    Schummi
                      paphko @schummi84
                      @schummi84 I’ll test that as soon as I find some time - maybe tomorrow, maybe next week.
                        paphko @schummi84
                        @schummi84 @YourhighnessLeender : OH2 has a slightly different JSON format in items response which I had to deal with. Please pull latest changes, set new ‘version’ option is your config, and try again.
                        • schummi84S
                          schummi84 @paphko
                          @paphko Thank you very much for your effort. I’ll give it a try and report on the outcome!
                          • schummi84S
                            schummi84 @paphko
                            @paphko With you Update everything works as expected!!!
                            0_1489697104040_upload-3fa13796-8258-4888-8ea9-97ce6d72d95f
                            Again, thank you very much for your help and the effort you put in your module!
                            :grinning:
                            Best regards
                            Schummi
                            • T
                              teddy
                              Hi, I have problems and need help. What am I doing wrong?
                              alt text
                              alt text
                              alt text
                              alt text
                              alt text
                              • zdenekZ
                                zdenek
                                Hi all
                                sorry for stupid question - do I need to have another RPi to run OpenHAB, or it can by on the same?
                                thanks Zdeněk
                                  paphko @teddy
                                  @teddy Sorry for the late reply, I didn’t check the forum for quite a while. But from your post, I don’t know how to help. It’s as if you say “my car is not working, what am I doing wrong?”
                                  If you want some help, please check logs for errors and post them here.
                                  @zdenek It should be possible to run openhab on the same RPi. I didn’t try it but I don’t see any reason why it should not work. You only have to change the port of one of them because both use 8080 by default.
