    [MMM-NetworkScanner] disable logging
    16 Posts 5 Posters 8.8k Views 6 Watching
    • pugslyP
      pugsly @binderth
      @binderth Im guessing that this somehow rotates or makes new logs for anything running on pm2?
      Any config steps for this besides just installing it?
      binderthB 1 Reply Last reply
      • binderthB
        binderth @pugsly
        @pugsly jepp, this rotates the log (like Linux-logs or log4j): have a look here:
        https://www.npmjs.com/package/pm2-logrotate
        this eliminates the need to buy a new SD Card every month (just kidding), but leaves the initial problem open: how can I remove those log-entries, because if I don’t Need them after setup, they’re just filling the log, leaving me scrolling for other stuff I need to have a look at while debugging or whatever. Perhaps there is a switch, but I don’t see it…
        • I
          ianperrin
          @binderth, @pugsly
          There is a (currently undocumented) debug config option in the module which minimises the logging. By default it should be set to false, but you can explicitly set it yourself
          i.e. debug: false,
          In earlier versions it had little effect, but in the latest commit, it should significantly reduce the volume of logging.
          See how it goes
          “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
          • binderthB
            binderth @ianperrin
            @ianperrin I don’t get anymore logging from MMM-Networkscanner after git pull & npm install, but I also don’t get to see my devices, they all seem offline.
            			module: 'MMM-NetworkScanner',
            			position: 'top_right',
            			header: 'Binder Handys',
            				devices: [
            					{ ipAddress: "192.168.xx.x", name: "S", icon: "mobile"},
             					{ ipAddress: "192.168.xx.x", name: "A", icon: "mobile"},
            					{ ipAddress: "192.168.xx.x", name: "T", icon: "mobile"},
             					{ ipAddress: "192.168.xx.x", name: "D", icon: "mobile"},
            					showUnknown: false,
            					showOffline: true,
            					showLastSeen: false,
            					keepAlive: 180,
            					debug: false,
            					updateInterval: 30,
            in the mm-out-0.log:
            Connecting socket for: MMM-NetworkScanner
            Starting module: MMM-NetworkScanner
            MMM-NetworkScanner received CONFIG
            edit:
            after changing debug: true, in the config and pm2 restart mm I experience the same behaviour.
            after deleting the debug-line completely, nothing changes also.
            I Mykle1M 2 Replies Last reply
            • I
              ianperrin @binderth
              @binderth
              Did you restart the mirror after the upgrade?
              Are there any errors in the browser console?
              What happens if debug is set to true?
              • binderthB
                binderth @ianperrin
                @ianperrin said in [MMM-NetworkScanner] disable logging:
                as described, I did a pm2 restart mm, the behaviour is the same if debug: true as described.
                the browser console re MMM-NetworkScanner:
                loader.js:182 Load script: modules/MMM-NetworkScanner//MMM-NetworkScanner.js
                module.js:415 Module registered: MMM-NetworkScanner
                loader.js:152 Bootstrapping module: MMM-NetworkScanner
                loader.js:227 File already loaded: moment.js
                loader.js:157 Scripts loaded for: MMM-NetworkScanner
                loader.js:227 File already loaded: font-awesome.css
                loader.js:159 Styles loaded for: MMM-NetworkScanner
                loader.js:161 Translations loaded for: MMM-NetworkScanner
                MMM-NetworkScanner.js:32 Starting module: MMM-NetworkScanner
                module.js:117 MMM-NetworkScanner received a system notification: ALL_MODULES_STARTED
                module.js:117 MMM-NetworkScanner received a system notification: DOM_OBJECTS_CREATED
                module.js:115 MMM-NetworkScanner received a module notification: CURRENTWEATHER_DATA from sender: currentweather
                module.js:115 MMM-NetworkScanner received a module notification: CALENDAR_EVENTS from sender: calendar
                still, all devices are shown offline:
                0_1487415081291_upload-a204f2e9-3ec0-474c-9bf4-f8d6a2eac761
                hth! Thanks for your effort!
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @binderth
                  @binderth said in [MMM-NetworkScanner] disable logging:
                  This started happening yesterday to me, too. Now only macAddress works. ipAddress no longer works. And it used to work perfectly. I started a new topic. Forgive me for that. I was in a panic. Still am.
                  Mykle1M 1 Reply Last reply
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @Mykle1
                    I spent a good amount of time with this, yesterday and today.
                            		position: 'top_left',
                    			debug: false,
                                		devices: [
                                        	{ macAddress: "bc:9f:ef:bb:1c:de", name: "Dove", icon: "medkit"},
                                        	{ macAddress: "e0:b5:2d:d3:e6:26", name: "BottlePop", icon: "globe"},
                                        	{ macAddress: "0c:d7:46:1e:a0:3f", name: "Donna", icon: "venus"},
                    			{ macAddress: "64:9a:be:e3:83:6b", name: "Nikki", icon: "coffee"},
                    			{ macAddress: "90:b6:86:d2:16:99", name: "Jason", icon: "fire-extinguisher"},
                    			{ macAddress: "84:d6:d0:f9:8b:f6", name: "MJD", icon: "child"}
                                		showUnknown: false,
                                		showOffline: true,
                                		keepAlive: 180,
                                		updateInterval: 10,
                                		residents: ["BottlePop"],
                    Here are my cells phones using macAddress because ipAddress no longer works for me. With residents: set as above, BottlePop appears online always, even when the phone is powered off for 20 minutes. If I set residents as such, [“BottlePop”, “Dove”, “Donna”], then BottlePop blinks on and off about every 10 seconds. If I have residents set to [], then each device goes online briefly and then offline until the device is used again
                    • michael24hM
                      michael24h
                      @Mykle1 said in [MMM-NetworkScanner] disable logging:
                      icon: “venus”}
                      What are material icons?
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @michael24h
                        @michael24h said in [MMM-NetworkScanner] disable logging:
                        Dunno, but you can choose any of the icons at this site for use with MMM-NetworkScanner
                        http://fontawesome.io/icons/
                        • michael24hM
                          michael24h
                          material icons?
                          full set icons (Library),
                          I need airport extreme icon
                          • michael24hM
                            michael24h
                            Dunno
                            can’t find airport ext. so wifi might do.
                            • Mykle1M
                              Well, that sounds good. They don’t have EVERY icon but I found some that work perfectly for me
