    [MMM-NetworkScanner] disable logging
    16 Posts 5 Posters 7.5k Views 6 Watching
    • binderthB Offline
      binderth @pugsly
      @pugsly jepp, this rotates the log (like Linux-logs or log4j): have a look here:
      https://www.npmjs.com/package/pm2-logrotate
      this eliminates the need to buy a new SD Card every month (just kidding), but leaves the initial problem open: how can I remove those log-entries, because if I don’t Need them after setup, they’re just filling the log, leaving me scrolling for other stuff I need to have a look at while debugging or whatever. Perhaps there is a switch, but I don’t see it…
      • I Offline
        ianperrin
        @binderth, @pugsly
        There is a (currently undocumented) debug config option in the module which minimises the logging. By default it should be set to false, but you can explicitly set it yourself
        i.e. debug: false,
        In earlier versions it had little effect, but in the latest commit, it should significantly reduce the volume of logging.
        See how it goes
        "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
        binderthB 1 Reply Last reply Reply Quote 1
        • binderthB Offline
          binderth @ianperrin
          @ianperrin I don’t get anymore logging from MMM-Networkscanner after git pull & npm install, but I also don’t get to see my devices, they all seem offline.
          			module: 'MMM-NetworkScanner',
          			position: 'top_right',
          			header: 'Binder Handys',
          				devices: [
          					{ ipAddress: "192.168.xx.x", name: "S", icon: "mobile"},
           					{ ipAddress: "192.168.xx.x", name: "A", icon: "mobile"},
          					{ ipAddress: "192.168.xx.x", name: "T", icon: "mobile"},
           					{ ipAddress: "192.168.xx.x", name: "D", icon: "mobile"},
          					showUnknown: false,
          					showOffline: true,
          					showLastSeen: false,
          					keepAlive: 180,
          					debug: false,
          					updateInterval: 30,
          in the mm-out-0.log:
          Connecting socket for: MMM-NetworkScanner
          Starting module: MMM-NetworkScanner
          MMM-NetworkScanner received CONFIG
          edit:
          after changing debug: true, in the config and pm2 restart mm I experience the same behaviour.
          after deleting the debug-line completely, nothing changes also.
          I Mykle1M 2 Replies Last reply Reply Quote 0
          • I Offline
            ianperrin @binderth
            @binderth
            Did you restart the mirror after the upgrade?
            Are there any errors in the browser console?
            What happens if debug is set to true?
            • binderthB Offline
              binderth @ianperrin
              @ianperrin said in [MMM-NetworkScanner] disable logging:
              as described, I did a pm2 restart mm, the behaviour is the same if debug: true as described.
              the browser console re MMM-NetworkScanner:
              loader.js:182 Load script: modules/MMM-NetworkScanner//MMM-NetworkScanner.js
              module.js:415 Module registered: MMM-NetworkScanner
              loader.js:152 Bootstrapping module: MMM-NetworkScanner
              loader.js:227 File already loaded: moment.js
              loader.js:157 Scripts loaded for: MMM-NetworkScanner
              loader.js:227 File already loaded: font-awesome.css
              loader.js:159 Styles loaded for: MMM-NetworkScanner
              loader.js:161 Translations loaded for: MMM-NetworkScanner
              MMM-NetworkScanner.js:32 Starting module: MMM-NetworkScanner
              module.js:117 MMM-NetworkScanner received a system notification: ALL_MODULES_STARTED
              module.js:117 MMM-NetworkScanner received a system notification: DOM_OBJECTS_CREATED
              module.js:115 MMM-NetworkScanner received a module notification: CURRENTWEATHER_DATA from sender: currentweather
              module.js:115 MMM-NetworkScanner received a module notification: CALENDAR_EVENTS from sender: calendar
              still, all devices are shown offline:
              0_1487415081291_upload-a204f2e9-3ec0-474c-9bf4-f8d6a2eac761
              hth! Thanks for your effort!
                Mykle1 Project Sponsor Module Developer @binderth
                @binderth said in [MMM-NetworkScanner] disable logging:
                This started happening yesterday to me, too. Now only macAddress works. ipAddress no longer works. And it used to work perfectly. I started a new topic. Forgive me for that. I was in a panic. Still am.
                  Mykle1 Project Sponsor Module Developer @Mykle1
                  I spent a good amount of time with this, yesterday and today.
                          		position: 'top_left',
                  			debug: false,
                              		devices: [
                                      	{ macAddress: "bc:9f:ef:bb:1c:de", name: "Dove", icon: "medkit"},
                                      	{ macAddress: "e0:b5:2d:d3:e6:26", name: "BottlePop", icon: "globe"},
                                      	{ macAddress: "0c:d7:46:1e:a0:3f", name: "Donna", icon: "venus"},
                  			{ macAddress: "64:9a:be:e3:83:6b", name: "Nikki", icon: "coffee"},
                  			{ macAddress: "90:b6:86:d2:16:99", name: "Jason", icon: "fire-extinguisher"},
                  			{ macAddress: "84:d6:d0:f9:8b:f6", name: "MJD", icon: "child"}
                              		showUnknown: false,
                              		showOffline: true,
                              		keepAlive: 180,
                              		updateInterval: 10,
                              		residents: ["BottlePop"],
                  Here are my cells phones using macAddress because ipAddress no longer works for me. With residents: set as above, BottlePop appears online always, even when the phone is powered off for 20 minutes. If I set residents as such, [“BottlePop”, “Dove”, “Donna”], then BottlePop blinks on and off about every 10 seconds. If I have residents set to [], then each device goes online briefly and then offline until the device is used again
                  • michael24hM Offline
                    michael24h
                    @Mykle1 said in [MMM-NetworkScanner] disable logging:
                    icon: “venus”}
                    What are material icons?
                      Mykle1 Project Sponsor Module Developer @michael24h
                      @michael24h said in [MMM-NetworkScanner] disable logging:
                      Dunno, but you can choose any of the icons at this site for use with MMM-NetworkScanner
                      http://fontawesome.io/icons/
                        michael24h
                        material icons?
                        full set icons (Library),
                        I need airport extreme icon
