    [MMM-NetworkScanner] disable logging
    16 Posts 5 Posters 8.5k Views 6 Watching
      binderth
      I’m running MM in pm2 and therefore get mm-out.x.log files. Is there a way to disable the logging for MMM-NetworkScanner? Would be nice to have a trigger for logging.
      as I configured 30sec. interval I get this every 30sec! ;)
      MMM-NetworkScanner received SCAN_NETWORK
      MMM-NetworkScanner is scanning for mac addresses
      MMM-NetworkScanner is scanning for ip addresses [ { ipAddress: '192.168.xx.xx,
          icon: 'mobile',
          online: false },
          icon: 'mobile',
          online: false },
          icon: 'mobile',
          online: true,
          lastSeen: '2017-02-17T12:44:27.577Z' },
          icon: 'mobile',
          online: true,
          lastSeen: '2017-02-17T12:44:27.578Z' } ]
        pugsly
        Just noticed this myself, that the pm2 logs were getting huge. I scan every 10 seconds, and all those scans were being logged.
        Only running on a 8GB SD card
          binderth @pugsly
          @pugsly said in [MMM-NetworkScanner] disable logging:
          got a 16GB, but still! ;) You could activate a logrotation in pm2:
          $ pm2 install pm2-logrotate
            pugsly @binderth
            @binderth Im guessing that this somehow rotates or makes new logs for anything running on pm2?
            Any config steps for this besides just installing it?
              binderth @pugsly
              @pugsly jepp, this rotates the log (like Linux-logs or log4j): have a look here:
              https://www.npmjs.com/package/pm2-logrotate
              this eliminates the need to buy a new SD Card every month (just kidding), but leaves the initial problem open: how can I remove those log-entries, because if I don’t Need them after setup, they’re just filling the log, leaving me scrolling for other stuff I need to have a look at while debugging or whatever. Perhaps there is a switch, but I don’t see it…
              • I Offline
                ianperrin
                @binderth, @pugsly
                There is a (currently undocumented) debug config option in the module which minimises the logging. By default it should be set to false, but you can explicitly set it yourself
                i.e. debug: false,
                In earlier versions it had little effect, but in the latest commit, it should significantly reduce the volume of logging.
                See how it goes
                “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
                  binderth @ianperrin
                  @ianperrin I don’t get anymore logging from MMM-Networkscanner after git pull & npm install, but I also don’t get to see my devices, they all seem offline.
                  			module: 'MMM-NetworkScanner',
                  			position: 'top_right',
                  			header: 'Binder Handys',
                  				devices: [
                  					{ ipAddress: "192.168.xx.x", name: "S", icon: "mobile"},
                   					{ ipAddress: "192.168.xx.x", name: "A", icon: "mobile"},
                  					{ ipAddress: "192.168.xx.x", name: "T", icon: "mobile"},
                   					{ ipAddress: "192.168.xx.x", name: "D", icon: "mobile"},
                  					showUnknown: false,
                  					showOffline: true,
                  					showLastSeen: false,
                  					keepAlive: 180,
                  					debug: false,
                  					updateInterval: 30,
                  in the mm-out-0.log:
                  Connecting socket for: MMM-NetworkScanner
                  Starting module: MMM-NetworkScanner
                  MMM-NetworkScanner received CONFIG
                  edit:
                  after changing debug: true, in the config and pm2 restart mm I experience the same behaviour.
                  after deleting the debug-line completely, nothing changes also.
                  I Mykle1M 2 Replies Last reply Reply Quote 0
                  • I Offline
                    ianperrin @binderth
                    @binderth
                    Did you restart the mirror after the upgrade?
                    Are there any errors in the browser console?
                    What happens if debug is set to true?
                      binderth @ianperrin
                      @ianperrin said in [MMM-NetworkScanner] disable logging:
                      as described, I did a pm2 restart mm, the behaviour is the same if debug: true as described.
                      the browser console re MMM-NetworkScanner:
                      loader.js:182 Load script: modules/MMM-NetworkScanner//MMM-NetworkScanner.js
                      module.js:415 Module registered: MMM-NetworkScanner
                      loader.js:152 Bootstrapping module: MMM-NetworkScanner
                      loader.js:227 File already loaded: moment.js
                      loader.js:157 Scripts loaded for: MMM-NetworkScanner
                      loader.js:227 File already loaded: font-awesome.css
                      loader.js:159 Styles loaded for: MMM-NetworkScanner
                      loader.js:161 Translations loaded for: MMM-NetworkScanner
                      MMM-NetworkScanner.js:32 Starting module: MMM-NetworkScanner
                      module.js:117 MMM-NetworkScanner received a system notification: ALL_MODULES_STARTED
                      module.js:117 MMM-NetworkScanner received a system notification: DOM_OBJECTS_CREATED
                      module.js:115 MMM-NetworkScanner received a module notification: CURRENTWEATHER_DATA from sender: currentweather
                      module.js:115 MMM-NetworkScanner received a module notification: CALENDAR_EVENTS from sender: calendar
                      still, all devices are shown offline:
                      0_1487415081291_upload-a204f2e9-3ec0-474c-9bf4-f8d6a2eac761
                      hth! Thanks for your effort!
                        Mykle1 Project Sponsor Module Developer @binderth
                        @binderth said in [MMM-NetworkScanner] disable logging:
                        This started happening yesterday to me, too. Now only macAddress works. ipAddress no longer works. And it used to work perfectly. I started a new topic. Forgive me for that. I was in a panic. Still am.
                          Mykle1 Project Sponsor Module Developer @Mykle1
                          I spent a good amount of time with this, yesterday and today.
                                  		position: 'top_left',
                          			debug: false,
                                      		devices: [
                                              	{ macAddress: "bc:9f:ef:bb:1c:de", name: "Dove", icon: "medkit"},
                                              	{ macAddress: "e0:b5:2d:d3:e6:26", name: "BottlePop", icon: "globe"},
                                              	{ macAddress: "0c:d7:46:1e:a0:3f", name: "Donna", icon: "venus"},
                          			{ macAddress: "64:9a:be:e3:83:6b", name: "Nikki", icon: "coffee"},
                          			{ macAddress: "90:b6:86:d2:16:99", name: "Jason", icon: "fire-extinguisher"},
                          			{ macAddress: "84:d6:d0:f9:8b:f6", name: "MJD", icon: "child"}
                                      		showUnknown: false,
                                      		showOffline: true,
                                      		keepAlive: 180,
                                      		updateInterval: 10,
                                      		residents: ["BottlePop"],
                          Here are my cells phones using macAddress because ipAddress no longer works for me. With residents: set as above, BottlePop appears online always, even when the phone is powered off for 20 minutes. If I set residents as such, [“BottlePop”, “Dove”, “Donna”], then BottlePop blinks on and off about every 10 seconds. If I have residents set to [], then each device goes online briefly and then offline until the device is used again
                          • michael24hM Offline
                            michael24h
                            @Mykle1 said in [MMM-NetworkScanner] disable logging:
                            icon: “venus”}
                            What are material icons?
                              Mykle1 Project Sponsor Module Developer @michael24h
                              @michael24h said in [MMM-NetworkScanner] disable logging:
                              Dunno, but you can choose any of the icons at this site for use with MMM-NetworkScanner
                              http://fontawesome.io/icons/
                                michael24h
                                material icons?
                                full set icons (Library),
                                I need airport extreme icon
                                  michael24h
                                  Dunno
                                  can’t find airport ext. so wifi might do.
                                    Well, that sounds good. They don’t have EVERY icon but I found some that work perfectly for me
