    [MMM-NetworkScanner] disable logging
    16 Posts 5 Posters 8.8k Views 6 Watching
    • binderthB
      binderth @ianperrin
      @ianperrin I don’t get anymore logging from MMM-Networkscanner after git pull & npm install, but I also don’t get to see my devices, they all seem offline.
      			module: 'MMM-NetworkScanner',
      			position: 'top_right',
      			header: 'Binder Handys',
      				devices: [
      					{ ipAddress: "192.168.xx.x", name: "S", icon: "mobile"},
       					{ ipAddress: "192.168.xx.x", name: "A", icon: "mobile"},
      					{ ipAddress: "192.168.xx.x", name: "T", icon: "mobile"},
       					{ ipAddress: "192.168.xx.x", name: "D", icon: "mobile"},
      					showUnknown: false,
      					showOffline: true,
      					showLastSeen: false,
      					keepAlive: 180,
      					debug: false,
      					updateInterval: 30,
      in the mm-out-0.log:
      Connecting socket for: MMM-NetworkScanner
      Starting module: MMM-NetworkScanner
      MMM-NetworkScanner received CONFIG
      edit:
      after changing debug: true, in the config and pm2 restart mm I experience the same behaviour.
      after deleting the debug-line completely, nothing changes also.
      I Mykle1M 2 Replies Last reply
      • I
        ianperrin @binderth
        @binderth
        Did you restart the mirror after the upgrade?
        Are there any errors in the browser console?
        What happens if debug is set to true?
        “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
        binderthB 1 Reply Last reply
        • binderthB
          binderth @ianperrin
          @ianperrin said in [MMM-NetworkScanner] disable logging:
          as described, I did a pm2 restart mm, the behaviour is the same if debug: true as described.
          the browser console re MMM-NetworkScanner:
          loader.js:182 Load script: modules/MMM-NetworkScanner//MMM-NetworkScanner.js
          module.js:415 Module registered: MMM-NetworkScanner
          loader.js:152 Bootstrapping module: MMM-NetworkScanner
          loader.js:227 File already loaded: moment.js
          loader.js:157 Scripts loaded for: MMM-NetworkScanner
          loader.js:227 File already loaded: font-awesome.css
          loader.js:159 Styles loaded for: MMM-NetworkScanner
          loader.js:161 Translations loaded for: MMM-NetworkScanner
          MMM-NetworkScanner.js:32 Starting module: MMM-NetworkScanner
          module.js:117 MMM-NetworkScanner received a system notification: ALL_MODULES_STARTED
          module.js:117 MMM-NetworkScanner received a system notification: DOM_OBJECTS_CREATED
          module.js:115 MMM-NetworkScanner received a module notification: CURRENTWEATHER_DATA from sender: currentweather
          module.js:115 MMM-NetworkScanner received a module notification: CALENDAR_EVENTS from sender: calendar
          still, all devices are shown offline:
          0_1487415081291_upload-a204f2e9-3ec0-474c-9bf4-f8d6a2eac761
          hth! Thanks for your effort!
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @binderth
            @binderth said in [MMM-NetworkScanner] disable logging:
            This started happening yesterday to me, too. Now only macAddress works. ipAddress no longer works. And it used to work perfectly. I started a new topic. Forgive me for that. I was in a panic. Still am.
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Mykle1
              I spent a good amount of time with this, yesterday and today.
                      		position: 'top_left',
              			debug: false,
                          		devices: [
                                  	{ macAddress: "bc:9f:ef:bb:1c:de", name: "Dove", icon: "medkit"},
                                  	{ macAddress: "e0:b5:2d:d3:e6:26", name: "BottlePop", icon: "globe"},
                                  	{ macAddress: "0c:d7:46:1e:a0:3f", name: "Donna", icon: "venus"},
              			{ macAddress: "64:9a:be:e3:83:6b", name: "Nikki", icon: "coffee"},
              			{ macAddress: "90:b6:86:d2:16:99", name: "Jason", icon: "fire-extinguisher"},
              			{ macAddress: "84:d6:d0:f9:8b:f6", name: "MJD", icon: "child"}
                          		showUnknown: false,
                          		showOffline: true,
                          		keepAlive: 180,
                          		updateInterval: 10,
                          		residents: ["BottlePop"],
              Here are my cells phones using macAddress because ipAddress no longer works for me. With residents: set as above, BottlePop appears online always, even when the phone is powered off for 20 minutes. If I set residents as such, [“BottlePop”, “Dove”, “Donna”], then BottlePop blinks on and off about every 10 seconds. If I have residents set to [], then each device goes online briefly and then offline until the device is used again
              • michael24hM
                michael24h
                @Mykle1 said in [MMM-NetworkScanner] disable logging:
                icon: “venus”}
                What are material icons?
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @michael24h
                  @michael24h said in [MMM-NetworkScanner] disable logging:
                  Dunno, but you can choose any of the icons at this site for use with MMM-NetworkScanner
                  http://fontawesome.io/icons/
                  • michael24hM
                    michael24h
                    material icons?
                    full set icons (Library),
                    I need airport extreme icon
                    • michael24hM
                      michael24h
                      Dunno
                      can’t find airport ext. so wifi might do.
                      • Mykle1M
                        Well, that sounds good. They don’t have EVERY icon but I found some that work perfectly for me
