    MMM-MLB
    35 Posts 10 Posters 31.7k Views 10 Watching
    • O Offline
      ooom416354
      Can anyone help out in trying to add criteria on only a selected team? I have tried to do it but am not sure exactly what spot in the code this needs to be added.
      if games.game.away_team_name === “Yankees” ||
      games.game.home_team_name === “Yankees”
      Was thinking because games is an array do we need a loop maybe?
      Thanks.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @ooom416354
        @ooom416354 if you can wait for a few days I will teach @cowboysdude how to do it
        O 1 Reply Last reply Reply Quote 3
        • O Offline
          ooom416354 @strawberry 3.141
          @strawberry-3.141 Def can wait, the season doesn’t start until like 4/1 anyway !
          • cowboysdudeC Offline
            Without further delay and a HUGE HUGE Thanks to @strawberry-3-141 I proudly give you ‘focus_on’ ability!!
            You can see all the games in a rotating fashion or just see your favorite team[s]!!
            IF you have the first version installed simply go to your MagicMirror/modules/MMM-MLB directory in a terminal window and type:
            git pull
            New config option:
            focus_on: [“Braves”,“Yankees”]
            Please make sure you put in brackets, capitalize and double quotes if you have more than one team separated by a coma like above.
            See here for complete instructions and ENJOY!!
            Download:
            [card:cowboysdude/MMM-MLB]
            R O Mykle1M D 4 Replies Last reply Reply Quote 1
              rodleland @cowboysdude
              @cowboysdude WORKS LIKE A CHARM. AMPED. thank you!
              • O Offline
                ooom416354 @cowboysdude
                @cowboysdude love it!!! amazing work!
                  @cowboysdude
                  You’re a freakin magician and a guru! :clap_tone1:
                    @Mykle1 said in MMM-MLB:
                    @cowboysdude
                    Yes with a lot of help from a very good guy! :baseball:
                      jimmrr
                      @cowboysdude
                      Hi, i’ve tried to install this on my magicmirror running on a pi zero, the module will not load in the browser. Any ideas? I have node v6.10.0 and npm 3.10.10.
                      pi@raspberrypi:~/MagicMirror $ node serveronly
                      Starting MagicMirror: v2.1.0
                      Loading config ...
                      Loading module helpers ...
                      No helper found for module: calendar_monthly.
                      All module helpers loaded.
                      Starting server op port 8080 ...
                      Server started ...
                      Connecting socket for: MMM-MLB
                      Starting module: MMM-MLB
                      Ready to go! Please point your browser to: http://localhost:8080
                        strawberry 3.141 Project Sponsor Module Developer @jimmrr
                        @jimmrr i guess you use the midori browser, which cant handle es6 and this module makes use of es6 features
                          Durnumosis @cowboysdude
                          @cowboysdude Thank you so much for your work on this module! I was digging through the code to see how you did it and noticed there’s some code for getting the MLB standings. Is this something that you are actively working on? It would be great to see the scores as well as the standings. Thanks again for a great module!
                            cowboysdude Module Developer @Durnumosis
                            @Durnumosis Well yes I am working on that part :) I’m running into snags so it’s going to be a while… still trying to figure it all out :)
                            Of course the standings is part of the voice part [MMM-voice]… I am also working on a standalone standings module… no voice required…
                            • O Offline
                              ooom416354
                              Question guys, I have the focus_on set to “Yankees” but today they happen to be off so all I see is the header, with the MLB logo and the text MLB Scores 04/20/2017. Is there a way to hide that if the team that is set in the focus_on is not playing that day?
                                cowboysdude Module Developer @ooom416354
                                @ooom416354 I will have to check into that. :) It’s going to take a little while.
                                • O Offline
                                  @cowboysdude no problem, figured it would be a bit difficult
                                    @ooom416354 Just from a time aspect :) My business is burying me right now… it’s that time of the year… ;)
                                    • O Offline
                                      @cowboysdude ha i know the feeling. Thanks again!
                                        shanecrozier
                                        It loads and shows scores and such but no logos not even MLB. Both are set to true
                                        Any ideas ?
                                          cowboysdude Module Developer @shanecrozier
                                          @shanecrozier I only have one… I just deleted and reinstalled on mine and it’s working fine…
                                          SO in the MMM-MLB directory make sure the icon folder is there ;)
                                            shanecrozier @cowboysdude
                                            @cowboysdude yes it is already checked that and it has all the icons in it
