    Family Info Board
    Scheduled Pinned Locked Moved Showcase
    40 Posts 19 Posters 62.8k Views 33 Watching
    • W Offline
      Wedee
      As I have already done for many, just shoot me a PM with your email address and I will send the custom.css and background.
      • L Offline
        lucallmon @Wedee
        @Wedee can you post your custom.css file?
          Padilla187
          this is perfect!
            Padilla187 @Wedee
            @Wedee don’t want to be a wierdo but I fell in love with this I Just shot you a pm
            • O Offline
              Orca
              @Wedee : How did you the trick with several calendars? Could you please share some infos for me?
              Thx
              • L Offline
                lucallmon @Orca
                @Orca simply clone the module for the calendar and change the settings for login.
                • O Offline
                  Orca
                  @lucallmon: Can you give me a hint how to clone this module. I’ve copied the folder into …/modules and named it calendar1, but only black screen.
                  Thx
                  • W Offline
                    Wedee
                    No need to duplicate the module, in the config.js just repeat the module config but point to the second calendar settings.
                    • Y Offline
                      yawns Moderator
                      You have two possibilities with the calendar module.
                      Option 1:
                      This shows one block and mixes both calendars, sorted by date
                      		module: 'calendar',
                      		header: 'both calendars'
                      		position: 'top_left',
                      				url: 'http://www.whatever.....xx.ics',
                      				symbol: 'calendar',
                      				url: 'http://www.justanother....zz.ics',
                      				symbol: 'calendar',
                      Option 2:
                      This show calendar1 sorted by date and then shows calendar2 sorted by date, but in a seperate block with a seperate header
                      		module: 'calendar',
                      		header: 'calendar1'
                      				symbol: 'calendar',
                      		module: 'calendar',
                      		header: 'calendar2'
                      				symbol: 'calendar',
                      JohanbaJ 1 Reply Last reply Reply Quote 3
                      • O Offline
                        Orca
                        THX, that did the trick.
                          dsegel
                          Another request for you to post your css for calendar_monthly…I’m not having much luck getting it formatted widely enough.
                          • E Offline
                            emos
                            Very clean.
                            Can i ask, how did you manage to create horizontal lines for all the modules?
                            • W Offline
                              Wedee @emos
                              @emos I believe its just a function of my CSS forcing column widths (width: xxxpx;). As the headers of the module are usually set to “float” the forcing of a width makes them span the entire column.
                              I have not touched the mirror in about a year - it just runs.
                              • E Offline
                                emos @Wedee
                                @Wedee Thank you for your reply.
                                Do you mind sharing your main.css and custom.css with us? It looks too damn good ;)
                                W G 2 Replies Last reply Reply Quote 0
                                • W Offline
                                  Wedee @emos
                                  @emos Shoot me a PM with your email and I will add you to the dropbox share i have of the files.
                                  • I Offline
                                    IndyMac @Wedee
                                    @wedee I like your design. I’m just getting started on my MagicMirror. Do you mind adding me to the Dropbox share? Thanks!
                                    • G Offline
                                      Galm @emos
                                      @Wedee : Hello Wedee -> i send you a PM with my email address. Would it be possible for you to share your main.css and custum.css? thanks a lot
                                      • MeatHeadInkM Offline
                                        MeatHeadInk
                                        @Wedee I messaged you with my email address awhile back as well.
                                        • W Offline
                                          Wedee
                                          I edited the main post with more info… sorry it took so long.
                                          • JohanbaJ Offline
                                            Johanba
                                            @Wedee, Thanks for taking my message.
                                            I am crazy about your format, but coping the Custom.css just crash my MM completely.
                                            Will someone please share their Main.css, Custom.css and config.js with me on jbarkhuizen@gmail.com
                                            I will appreciate this
                                            Johan
