    Family Info Board
    Scheduled Pinned Locked Moved Showcase
    40 Posts 19 Posters 71.3k Views 33 Watching
    • W Offline
      Wedee @emos
      @emos I believe its just a function of my CSS forcing column widths (width: xxxpx;). As the headers of the module are usually set to “float” the forcing of a width makes them span the entire column.
      I have not touched the mirror in about a year - it just runs.
      • E Offline
        emos @Wedee
        @Wedee Thank you for your reply.
        Do you mind sharing your main.css and custom.css with us? It looks too damn good ;)
        W G 2 Replies Last reply Reply Quote 0
        • W Offline
          Wedee @emos
          @emos Shoot me a PM with your email and I will add you to the dropbox share i have of the files.
          • I Offline
            IndyMac @Wedee
            @wedee I like your design. I’m just getting started on my MagicMirror. Do you mind adding me to the Dropbox share? Thanks!
            • G Offline
              Galm @emos
              @Wedee : Hello Wedee -> i send you a PM with my email address. Would it be possible for you to share your main.css and custum.css? thanks a lot
              • MeatHeadInkM Offline
                MeatHeadInk
                @Wedee I messaged you with my email address awhile back as well.
                • W Offline
                  Wedee
                  I edited the main post with more info… sorry it took so long.
                  • JohanbaJ Offline
                    Johanba
                    @Wedee, Thanks for taking my message.
                    I am crazy about your format, but coping the Custom.css just crash my MM completely.
                    Will someone please share their Main.css, Custom.css and config.js with me on jbarkhuizen@gmail.com
                    I will appreciate this
                    Johan
                    • JohanbaJ Offline
                      Johanba @yawns
                      @yawns
                      Hi, I copied this to my Config.js
                      Then I get a syntex error on the position in both scenarios
                      Appreciate the support
                        sdetweil @Johanba
                        @johanba could you post the ‘what you copied’…
                        back two pages and can’t find it…
                        • W Offline
                          Wedee
                          I imagine the Custom.CSS failure is related to the fact that its calling for an image. I would remove the two lines related to the Background and see if it works then. Other than some colors and of course the forcing of the column widths there is not really much in the custom.css
                          In the config.js I sent you via email - you will see I changed to using the module MMM-Profilepicture pointing back at localhost to host backgrounds there. It is much cleaner easier to use. I also switched from wunderlist to todoist for the todo list…
                          I have not done much other than change the background for many years now - Wife is asking for a refresh, and we picked up a Narrow hutch someone was throwing away that with a coat of paint some new handles and a new monitor will make for an excellent info board - so once that is refinished i will start anew again but this time the screen will be in portrait.
                          Good luck and happy learning
