    [ORDER CLOSED] Two way mirror order in Germany
    Scheduled Pinned Locked Moved Solved Hardware
    558 Posts 80 Posters 2.9m Views 60 Watching
    • G Offline
      gustav1976 @tomster
      @tomster said in [ORDER CLOSED] Two way mirror order in Germany:
      @Goldjunge_Chriz
      Have the mirrors been picked up yet by the art forwarder? The guy called me last week just to tell me to call me again last Sunday to determine the actual delivery. So far I haven’t gotten a call back.
      exactly what happened to me as well. I haven’t heard back from the delivery guy.
        Sennahoj82
        I am curious how the first experience is with the mirror. Please let us know.
        • G Offline
          Goldjunge_Chriz
          Yes the mirrors were picked up today. He goes first to Berlin. He will contact everyone else for an appointment. During the next week, all will be delivered. My garage is now empty :)
            ace0024 @gustav1976
            @gustav1976 said in [ORDER CLOSED] Two way mirror order in Germany:
            @Goldjunge_Chriz
            same here!
            • G Offline
              Goldjunge_Chriz
              @tomster @gustav1976 @ace0024
              The shipping company says that the tour program for next week is not yet finished. But all mirrors are delivered next week, the sequence of the cities is only not fixed yet. They will inform you on Saturday (@Ali Baba and @ferby09 already know, as these mirrors are still delivered tomorrow)
              • G Offline
                Goldjunge_Chriz
                I also wonder that there are unfortunately no pictures yet. Here are a few new photos of me at different times of the day (daylight, room lighting, dark) to shorten the waiting time. I baptized the glass “MagicGlass” :D
                • Y Offline
                  yawns Moderator @Goldjunge_Chriz
                  @Goldjunge_Chriz said in [ORDER CLOSED] Two way mirror order in Germany:
                  I opened the crate, checked the mirror glass for any damage (no damage found :thumbsup: ) and closed the crate again to avoid any impact on the glass.
                  And I’m pretty sure no one wants to see unboxing pictures
                  • G Offline
                    Goldjunge_Chriz
                    I’m sure, of the 35 delivered mirrors is one or the other mirror already in use ;)
                    • O Offline
                      olexs
                      @Goldjunge_Chriz what sort of display do you use for your mirror?
                      I have got my glass from @Woody, the pickup was smooth, perfectly packaged, all is well. The performance, I’m not completely 100% convinced yet… it is way better than my previous mirror film solution, but quite a lot darker than a “normal” mirror that hangs in the same room, even when the display behind it is turned off. With the display on, the backlight of the LCD makes the reflection a bit less prominent still. I presume an AMOLED would be ideal for this with a perfect black, but any backlit LCD is going to give off some light on its black areas.
                      The mirror is facing with the protective film side outwards, the unprotected side towards the screen. Protective film is of course removed :)
                      I’ve taken a few pictures of it, it actually looks a bit better in the pictures than it does IRL:
                      (ignore the wires and the lack of a frame, it’s very much at prototype stage still)
                        broberg Project Sponsor @olexs
                        @olexs now, I don’t have this glass on my mirror, but in my experience the reflection part will become much better when there is no light coming from the back as it does now! :) (Even the tiniest amount of light from the other side lessen the reflection!)
                        • O Offline
                          olexs @broberg
                          @broberg You mean the small bit on the left side of the mirror? I’ll cover than with a black backpane then, if that makes such a difference. Otherwise, all the light coming in behind is from the monitor only, 3 of edges are flush to the monitor frame (I made a mistake when taking the original measurements, the mirror is 1cm too wide… but that I can live with, the frame will cover the edges eventually).
                            @olexs it actually looks like there is a space between the glass and the monitor frame, but I could be wrong :)
                            • O Offline
                              olexs @broberg
                              @broberg No, the mirror sits on the metal of the LCD panel framing, held in place (temporarily) with some tape. There might be some very tiny space between them where the frame isn’t perfectly even - I guess I could try putting some black foam or paper in between there to have the mirror pressed on as flush as possible. Ultimately, I think I’ll have to build the frame sooner rather than later - that will completely cover the sides and ~1cm of the front on each edge, there should be no room for any light bleed from the outside after that.
                              G 1 Reply Last reply Reply Quote 1
                              • G Offline
                                Goldjunge_Chriz @olexs
                                @olexs
                                I use a Led monitor from the manufacturer dell.
                                The degree of reflection depends, of course, also on the light conditions in the room. A perfect mirror for all possible exposure modes is not available due to the special effect. The effect of a spy mirror comes through the refinement and therefore there are so many different transmission values. A spy mirror can and will never be an exact copy of an “normal” mirror. But this Spy mirror is the best mirror I’ve seen so far and I’ve really tested a lot. It simply offers the best compromise of all application types. You can’t buy a car that has 1000 hp and only 2 liters of petrol consumption ;)That can not even be built by the worlds best car manufacturer, if you understand what I mean :) the mixture is the most important ;)
                                Does your room have daylight? Can you adjust the lamps? You just have to play a Little with the light conditions :) your picture confuses me also because the font Looks so blue. In my mirror it is for example absolutely white. Please try some different Settings until you find the best solution for you :)
                                A G 2 Replies Last reply Reply Quote 0
                                  Advokaten @Goldjunge_Chriz
                                  @Goldjunge_Chriz
                                  On the latest pictures you posted, what size is your monitor? And what size is your glass? :) Your monitor appears to have a very black black. It looks great!
                                  • G Offline
                                    Goldjunge_Chriz @Advokaten
                                    @Advokaten
                                    22 inch 16:10. Mirror size is 0,9m x 0,6m ;)
                                    • G Offline
                                      Goldjunge_Chriz @Goldjunge_Chriz
                                      @olexs
                                      Here is a comparison picture with a normal hand mirror. The Spy mirror is a little bit darker but that did not troubled me personally.
                                        Ali Baba
                                        Was ist dass denn für ein ominöses Transportunternehmen welches die Spiegel verteilt? Bei mir hat heut schon wieder mal einer angerufen und den Liefertermin von heut auf Ende der Woche verschoben. Er wollte auch wissen wie groß das Teil ist und ob es in eine Wohnung oder Haus geliefert werden soll. Mir schien es als hätte der das Teil noch nicht mehr. Oder ich habe ihn schlecht verstanden wegen seines starken Akzents… Si nun wart ich halt auf Freitag. Nur doof das man immer jemand aktiviert der dann auch da ist um dann wieder zu sagen sorry aber könntest du Freitag noch mal…
                                        • G Offline
                                          Goldjunge_Chriz
                                          Also auf mich haben die Jungs eigentlich einen soliden Eindruck gemacht. Der Geschäftsführer ist ein deutscher und spricht auch perfekt Deutsch. Sein Geschäftspartner, der für die Fahrten zuständig ist, ist wohl polnischer Abstammung. Aber wie gesagt beide haben einen guten kommunikativen Eindruck hinterlassen und auch der Fahrer wohnt seit Jahrzehnten in Deutschland und spricht auch ordentliches Deutsch. Ich denke er hat wohl nur die Ladeliste, die ich ihm gegeben habe (und worauf die Telefonnummer steht), in der Hand gehabt und dich angerufen und wollte die Spiegel nicht extra auspacken um die Größe herauszufiltern. Deshalb wohl auch die Frage. Werde das natürlich ansprechen, wenn da ständig Termine verschoben werden. Der Transport kostet ja schließlich auch einiges und ist nicht gerade billig.
                                          • G Offline
                                            Goldjunge_Chriz
                                            Also ich habe nochmal mit ihm gesprochen. Ihm ist leider ein Kunde kurzfristig abgesprungen, der auf deiner Route lag. Somit hätte er extra 300 km einfach nur für deinen Spiegel fahren müssen. Da er jedoch ende der Woche eine andere Auslieferung in deine Richtung hat, verbindet er es damit. Ich denke, das kann man nachvollziehen. Gerade auch unserer Umwelt zuliebe ;)
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 25 / 28
